Where can I find oval chainring in 44T 110BCD 5 bolt for middle/outer position?
Quoted: 350 Post(s)
Liked 122 Times
I want to put an oval chainring on my double crank 74/110, which has both chainrings on the inner side of the spider flange.
I want 44T, for 110BCD 5 bolt.
Where can I find one?
The problem is that most I've seen are wide/narrow for single.
The ones for double/triple are usually much bigger than 44T for a 110BCD, and normally the ones for outer double have them on the outside of the spider flange.
Bikes: 3Rensho SuperRecord Export, Bridgestones MB1 RB1 XO2, Colnago Super, Medici GranTurismo, Schwinn Paramount, Olmo Competition, Raleigh Portage, Miyata 1000, Stumpjumper, Lotus Competition, Nishiki Maxima, Panasonic DX6000, Zeus Criterium
Quoted: 30 Post(s)
Liked 82 Times
Death fork? Naaaah!!
PM me.
Top
Top
Oval rings have gotten out of fashion, at least for road, so not sure about supplies.
110 BCD, can fit down to 34 teeth. I have a double in 50/34 5x110BCD, very common now, and can sometimes be bought for not much more than a chainring; Mine was $65, including new external bottom bracket bearings (requiring a special wrench).
Are you leaving the ring on the 74 BCD in place?
I'd love to find a hollowtech II style crank like my 50/34, but with also a 74 BCD on the inside for a triple crank, not seen any yet, triple cranks are out of fashion with huge cassettes in fashion.
Quoted: 501 Post(s)
Liked 436 Times
Quoted: 405 Post(s)
Liked 430 Times
I'm pretty sure that there were 44/34/24 110x74 Biopace cranksets back in the day. NOS or take-off rings shouldn't be that hard to find, and MTB outers tended not to get used much.
--Shannon
--Shannon
Quoted: 501 Post(s)
Liked 436 Times
Not crashing, just lack of ground clearance. My MTB crashes were mostly over the handlebar, while my road bike crashes have been mostly sliding off to the side. (Stepping off the back, or failing to unclip, don't count as crashes, do they?)
Quoted: 350 Post(s)
Liked 122 Times
Quoted: 350 Post(s)
Liked 122 Times
Have you looked at the absolute BLACK range?
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
With the small oval you might have problems arise with the chain bouncing onto the chainstay. The ovals with the small diameter really accentuate this, especially as one gets to the middle of the freewheel/cassette in back. On my Miyata 1000 with a 28 biopace it was quite annoying and kinda unexpected frankly. A 12-28 on this 1989 model with the 48-38-28 front didn’t really get super low either. The small oval rings felt very strange too, while I wasn’t really bothered by the larger sizes.
Quoted: 350 Post(s)
Liked 122 Times
There are 2 other models if you check the catalogs with 110/74 with asymmetric 4 bolts.
I have a sugino OX 110/74 BCD 5 bolt double.
The French manufacturer Spécialités T.A. was founded in 1947 and for decades they have been producing MTB, Road and Track compatible chainrings. As of late, TA has also dipped into the oval chainring market, making them a great alternative to three largest component manufacturers.
