Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Ask your small, random, track-related questions here
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 02-25-18, 10:14 AM
  #4926
krispenhartung
krispenhartung's Avatar
Bikes: S-Works Venge Dura-Ace DI2, KTM Strada 4000, Fuji Norcom Straight 1.3 (TT), Fuji Track Elite, BMC Trackmachine TR02
Quoted: 100 Post(s)
Liked 3 Times in 2 Posts
Originally Posted by SyntaxMonstr
Yup. Exactly.
I think this is what I'm using:
https://www.amazon.com/Oursunshine-L...tainers+travel
krispenhartung is offline
Old 02-25-18, 10:42 AM
  #4927
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
Originally Posted by krispenhartung
Definitely no reason to buy those expensive gels. Same for electrolytes. People spend thousands on that stuff and you can make it in your own kitchen with salt and lemon/lime juice. For in-race fueling (not just recovery), I know many guys on the road side who just use dextrose, which I mention above as a simple sugar that absorbs quickly. I have a hard time eating and breathing on the bike, so I tend to just put my fuel in my water. I do the math on what my carb needs will be and put that much dextrose in my water. Honey is good too, which is a combo of fructose and dextrose (which converts to glucose in the blood). So dextrose is your most efficient "main line" carb to restoring glycogen in the muscles. You can buy these little squishy, re-usable bottles that will hold about 5oz of liquid and put both honey and dextrose in them. Bam! There you go.
You may want to have a read through the "cramping" thread and read up on electrolytes. Not because of cramping, but that there is more than just sodium and the other minerals play their parts too.
taras0000 is offline
Old 02-25-18, 11:42 AM
  #4928
krispenhartung
Quoted: 100 Post(s)
Well, I did mention electrolytes, so I should probably follow through with my philosophy on them. I don't use them. I've done centuries in 95-100 degrees, 40K TT at 103 degrees, and didn't need them. I've never cramped once on a ride, workout, or race. Most of the stuff that is in those electrolyte powders you can find in "real" food. So between a good diet and proper hydration, I've have no need to take electrolyte supplements.
Old 02-25-18, 04:11 PM
  #4929
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
If you don't need to supplement with them, then you don't need to. It's still a good read to know what and how electrolytes work in the body.
On the same note, just because not taking something doesn't produce a negative effect on you, doesn't mean that you wouldn't benefit from taking it. Look at how many supplements you're already downing that can all be basically had from "real food". In other words, you would be fine not taking the stuff and just eating real food, but you take it because you see a benefit from it.
Old 02-26-18, 12:56 PM
  #4930
MrMinty
Bikes: Cannondale Caad8, Claud Butler Roubaix, Raleigh Equipe
Quoted: 14 Post(s)
Can I use an alloy stem with carbon bar or would I be better going for carbon/carbon?
MrMinty is offline
Old 02-26-18, 01:05 PM
  #4931
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
no worries mix/matching. If you go carbon on carbon it's best to use some carbon fibre grip paste.
Don't overtighten
Morelock is offline
Old 02-26-18, 06:49 PM
  #4932
Godsight
Bikes: Felt TK FRD
Quoted: 59 Post(s)
Even with aluminium, always use a torque wrench for seatpost, handlebar and stem.
Godsight is offline
Old 03-06-18, 10:27 AM
  #4933
krispenhartung
Quoted: 100 Post(s)
Pursuit grips for 3T Vola LTD Bars
I just picked up a new set of 3T Vola LTD bars for my Fuji Track Elite...lovely bars. The handles on these pursuit bars are not long at all, and using normal, even thin bar tape is sort of awkward. Is anyone using or can recommend a rubber of silicon bar grip that will basically roll on the bar and not require wrapping? Same on the aero bars, though I'm using very thin Fizik tape that looks and feels decent.
Old 03-06-18, 10:45 AM
  #4934
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
I just use electrical tape on my bars (base and extensions) and find it plenty grippy. If you wanted something more tacky than that a roll of Hockey tape works well. (and is cheap and comes in lots of colors/designs.)
Morelock is offline
Old 03-06-18, 11:44 AM
  #4935
krispenhartung
Quoted: 100 Post(s)
Great tip. I'm going to try the hockey tape. thanks
Old 03-06-18, 01:13 PM
  #4936
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Also consider Lizard Skins (or another brand) baseball bat tape. That's what I'm currently using on my Scattos. They come in varying thicknesses and can be found at most big sporting goods stores (Dick's, Hibbets, etc...). Someone here turned me on to it.
It's shorter than normal cycling grip tape.
carleton is offline
Old 03-06-18, 07:21 PM
  #4937
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
I don't use a torque wrench, but similarly enough, I keep turning until I hear the "click".
Old 03-06-18, 07:26 PM
  #4938
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Use the white tape. The glue on hockey tape will creep through the fabric, and the black tape will get black glue all over your gloves.
I used the tape on my bars, and it's my favourite behind proper Keirin grips. I wrapped once from the top, pulled out a length and twisted it into a "rope", the wound that around back up to the top, the another layer of tape over that down to the corks for bar plugs.
Old 03-06-18, 09:18 PM
  #4939
krispenhartung
Quoted: 100 Post(s)
When you say "white tape", which brand of white tape are you referring to? White hockey tape? Or another. Have you used the baseball lizard tape suggested by Carleton?
Old 03-06-18, 10:38 PM
  #4940
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
White hockey tape. Renfrew brand.
Old 03-07-18, 03:40 AM
  #4941
ruudlaff
Quoted: 85 Post(s)
Liked 11 Times in 10 Posts
Originally Posted by spartanKid
tennis racquet grip tape also fits this role nicely.
100%, I've started swearing by this recently. Basically grippy bar tape with no padding.
ruudlaff is offline
Old 03-08-18, 01:44 PM
  #4942
rustymongrel
Quoted: 70 Post(s)
Liked 5 Times in 5 Posts
I tried and quite like adhesive stair tread for pursuit bars. Since the grip area is so short I don't really want any margin for error and that stuff is basically just adhesive backed sandpaper, definitely no slipping!
rustymongrel is offline
Old 03-09-18, 08:08 AM
  #4943
krispenhartung
Quoted: 100 Post(s)
I got some of this in. Great tip!This stuff works great. I’m using the 1.1mm for the aero bars and 1.8mm for pursuit. I have large hands (guitarist, remember? Ha ha) and so I need a little more to grab on to with the skinny 3T pursuit bars. I got the hockey tape too but I don’t like the feel of cloth on a bar.
Old 03-09-18, 11:49 AM
  #4944
krispenhartung
Quoted: 100 Post(s)
It's the combination of the shortness (length) and narrowness (diameter) of the pursuit bars that gets me given my large hands. I'm not sure at what point in time these short pursuit bars came into vogue. The pursuit bars on my TT bike don't have this issue and they are long enough to get my entire grip on them. And the diameter is an issue because by the time I wrap my fingers around them, there is overlap...meaning I can't actually grip them with full force...yet putting super think tape on a 4 inch bar is awkward.
Old 03-09-18, 02:45 PM
  #4945
Poppit
Poppit's Avatar
Quoted: 111 Post(s)
Liked 5 Times in 4 Posts
Profile aerobar tape? Aerobar grip bar tape
Poppit is offline
Old 03-09-18, 04:05 PM
  #4946
krispenhartung
Quoted: 100 Post(s)
Looks like that would work too. This lizard skin baseball bat tape is nice because it feels a lot like bar tape with a tad bit of padding (but very minimal), but unlike most bar tape, the entire back side is sticky vs. a small strip. Super easy to wrap on.
Old 03-16-18, 04:04 PM
  #4947
southernfox
Quoted: 194 Post(s)
Liked 2 Times in 1 Post
Are track cleat positions largely the same as road (asking as a sprinter)?
southernfox is offline
Old 03-16-18, 04:51 PM
  #4948
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 365 Post(s)
Liked 87 Times in 58 Posts
I try to set up identically but I'd be interested to hear if others have a different idea. Q factor is significantly wider on my road bike, could that change things?
Baby Puke is offline
Old 03-16-18, 08:23 PM
  #4949
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Q-factor wasn't a consideration for me when I set up my cleats. I went with the cleats as far outward (to get a narrower stance) as my feet would allow without hitting the crank. As far as fore-aft track vs. road, my track cleats were set up about 5mm forward. Well, it was actually the reverse, I figured out what was best for track, and set my road cleats further back because I found for longer riders, it was a more sustainable position for road racing. My track shoes would have my calves tire out too soon, so I moved my road cleats back a little.
I never had my bikes set up identically, as I did do enough road racing to warrant a slight change from my primary position which was track.
My road position was 1cm shorter from BB to saddle, and 1.5cm further back. For track I was higher and more on top of the BB. This was cadence related. I would still spin at 105-110 rpm on the road when cruising in the pack, but being further back allowed more glute and hamstring recruitment at lower RPM for climbing and also kept a little more weight on the saddle so my arms wouldn't tire over longer rides. Being over the BB for sprinting allowed better high RPM pedaling. My track position allowed me to apply power effectively from about 2-o-clock down and through to about 5:30, and allowed for a strong upstroke from 7-o-clock to about 10-o-clock. My road position was more effective from about 1:30 through to 4-o-clock, and allowed for more back and up from about 5:30 to 8-o-clock.
It all boiled down to needs for the specific type of racing. I would regularly race crits that were 40-60km in length, and occasionally a few road races that were 60-100km long. This was enough to warrant a change for me. I could've deviated more, but I didn't want to throw off my pedaling mechanics that much when it came to track and sprinting.
Old 03-16-18, 08:44 PM
  #4950
Baby Puke
Quoted: 365 Post(s)
Sounds about right Taras. My roadbike is only for recovery and commuting, so I'm gonna stay same set up as track. Climbing??
