shimano disc brake query
Old 07-31-20, 01:51 PM
quindecima
Bikes: Flex, Volkscycle MarkX
Quoted: 26 Post(s)
Liked 12 Times in 5 Posts
I have Deore XT hydraulic levers, can I use the 105 disc calipers?
quindecima is offline
Old 07-31-20, 02:52 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Rumors have it ..
Recently someone posted here their local shop recommended the opposite .. they had a post mount frame & road hydro brifters.
so used an MTB Caliper with them, to have the post mount... rather than direct mount the set came with..
fietsbob is offline
Old 07-31-20, 03:06 PM
quindecima
Quoted: 26 Post(s)
I care less about the mounting, what my shop told me was that there was some kind of difference in how the hydraulic pressure was arrived at and the two were not compatible which sounds like a bunch of BS to me. I had the Shimano 105's mounted and have XT Devore levers and I wanted them to bleed them for me and was told it could not be done.
Old 07-31-20, 03:27 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
Well, the diameters and travel of the master (lever) and slave (caliper) pistons (how the hydraulic pressure is arrived at) have to be proportional as that sets the mechanical advantage. Kind of like using caliper brake levers with V-brakes and vice versa doesn't work well. I do not know about the particular parts but that may be what the shop's "BS" was about. Being as it is a safety issue you might want to know for certain that they are compatible, the shop may be giving sound advice. I am sure they love "don't bother me with facts" customers.
dsbrantjr is offline
Likes For dsbrantjr:
Old 07-31-20, 03:42 PM
vespasianus
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times in 219 Posts
I bet you can. I think for the road discs, the banjo is in the levers and the "olive" end is in the caliper. In the MTB version, the banjo is on the caliper and the olive end is in the lever.
vespasianus is offline
Old 07-31-20, 04:19 PM
quindecima
Quoted: 26 Post(s)
What is Banjo and Olive**********?
Never mind, I figured it out
Old 08-01-20, 02:57 AM
cpach
Bikes: Too many. Giant Trance X 29, Surly Midnight Special get the most time.
Quoted: 532 Post(s)
Liked 312 Times in 236 Posts
It'll probably work with the appropriate hose, but the modulation may not be as intended and without it being on Shimano's compatibility charts they may feel unsure about guaranteeing it. They both use BH90 and have Servo-Wave so it's probably pretty close, though. I've more frequently seen higher end Shimano road levers mated to XTR race and the like to work with post mount frames. If it's all mounted up it shouldn't be any different to bleed.
cpach is offline
