Original Hyperglide Chain Connector Pin Removal & Reinstallation?
only here for the "LIKES"
Quoted: 1642 Post(s)
Liked 2,235 Times
7 speed, Hyperglide cassette rear hub.
I want to break the low mileage original Hyperglide chain on my Bridgestone. It still has the factory waxy type coating on it, but it is very dusty from having sat around for the better part of 3 decades.
I want to remove the chain to do a thorough deep cleaning, probably a wax lube, then reinstall the chain.
One of the pins is noticeably different from the others, see pic. I am presuming this is the original connector pin, and I'd like to maintain as much originality on the bike as possible. If I drive this pin out, can I reinstall it?
Or would I be better off picking a different spot on the chain to remove a pin/link and installing a quick link. I realize this option would allow for easier future removal / servicing.
Bikes: 2011 Handsome/ Twin Six Speedy Devil, 2006 Soma Groove, 1991 Haro Impulse Comp, 1987 KHS Montana Pro, 1986 Ross Mount Hood, 1986 Mongoose ATB, 1985 Shogun Prairie Breaker I, 1973 World Voyageur, 1941 Schwinn DX "Klunker"
Quoted: 83 Post(s)
Liked 96 Times
Edit: https://mikesbikes.com/products/hg-c...AaAmREEALw_wcB
Likes For MrK.:
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
Although MrK. gives good advice, a chain cleaning 'in situ' is easier than swapping the stoopid Shimano special pin. I think my closeted dislike for Shimano began with those chains.
Quoted: 1946 Post(s)
Liked 2,008 Times
Your LBS might have some pins. I use the HG 7/8, 9, and 10 use different pins and like MRk says, leave that pin in the photo alone. Story is that the holes hold that pin just fine but if you drive a replacement into that slot, it may not hold very well.
Quoted: 790 Post(s)
Liked 1,760 Times
I would just pop the HG pin and that link and replace it with a KMC 7/8 master link have done this on several bikes no issues.
Likes For zukahn1:
Quoted: 790 Post(s)
Liked 1,760 Times
Also I would advise against much chain cleaning beyond whip down if the chain as vintage and good as described heavy cleaning will take off the HG finish on the chain and likely make it worse.
The early Shimano UG and HG chain tools had a shallow recesses on the opposing face of the tool. This allowed you to put the chain back together without squishing the bowed out plates. These chains could potentially 'break' if joined back together with a standard VAR or Cyclo etc chain tool. I'd imagine there's still a modern equivalent for those that want to use those stupid special pins, or for really old chains with no special pin.
I don't think it's relevant if you're just splitting the chain and using a quick link.
