Frustrating Tire Bulge
Bikes: CAAD10 5, Trek 1000 Alpha Series
I recently built up a cyclocross bike and I am having an issue with tire bulge. On my Alex R500 rims I have put Kenda 700x30 cross tires and keep getting tire bulge in the front wheel no matter how hard I try to seat the tire correctly. No issues whatsoever with the rear wheel. At first I thought there was an issue with the rim itself but it appears fine to me and when I take off the tire and tube and reinstall the bulge happens in different areas.
Is this safe to ride on?
Quoted: 4172 Post(s)
Liked 3,792 Times
Are you sure that the tube's double thick valve base is not trapped between the rim and tire bead? Or any part of the tube is trapped? Yes, exchanging the tires F-R might give more info. Andy.
Location: southeastern PA - a mile west of Philadelphia
As concerns any other portion of the inner tube being trapped, he’d have to be trapping the front inner tube time after time, and while this is possible, it’s not likely to repetitively and persistently happen, so it sounds more like he has a defective tire, in which case, I’d return it.
However, swapping the front tire for the rear and vice versa is an excellent method to establish that the tire is defective regardless of which rim it’s mounted on, and I always do this prior to returning any defective tire, so swapping them is an advisable protocol.
Quoted: 5703 Post(s)
Liked 2,432 Times
Question - when you say the bulge happens in a different place, is that a different place with respect to the rim or valve? Or in a different place on the tire with respect to the tire's label?
Knowing that would separate a possible tire defect from a seating problem.
FB
Chain-L site
FB
Chain-L site
What is the condition of the rim tape? Does the tube have patches?
Everything everyone said + mark the tire & rim . Change tire to different wheel & or rotate on rim .I've Had this happen on ocassion , mine were the tire had defect
good luck
good luck
Bikes: ritcheys{2** rm blizzard Geo elrick drop frame and acollection of parts bikes in waiting
stiction , use baby powder on tube , tire and rim . Put pressure info at valve , inflate . Same place ?
Retro Grouch
Bikes: Yes
A 30mm tire on an Alex R500 rim is nearing the recommended max, but isn't a safety issue. It does mean however that you may have problems getting tire to seat evenly around the rim channel; if this is the problem you will notice the tread of the tire has a considerable wobble from side to side when you spin the tire. When I run into this problem I usually go to a plastic rim strip (Velox makes a good one), which is slicker and thinner so the cord can slide into the channel easier; baby powder or soapy water may also work if you don't have a cloth rim strip.
finally got around to taking off the tires and inspecting the situation. the bulge definitely is coming from one of the tires at the same spot. looks like i need a new tire.
bike whisperer
Quoted: 1520 Post(s)
Liked 716 Times
Kenda is a bit of a cheap and nasty brand, IME.
If you can spare the bucks for Continentals they definitely tend to be worth the money.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1111 Post(s)
Liked 243 Times
Kenda is not a cheap and nasty brand, while certain models of tires may be low costing and thus cheap and nasty but most manufactures offer cheap and nasty models. My longest mileage least number of flats I ever got from a light weight road tire was the Kenda Konstrictor, this was a great tire which quite frankly surprised me! I wore out one set with about 5200 miles and only had 1 flat the whole time and that happened in the last 1000 miles, I still have 3 other sets on 3 other bikes that are going strong, though I don't ride those other bikes much.
Also I have a Kenda Kwest tire on a MTB that's been on that bike for about 8 or 9 years and while it's only seen about 1800 miles of earth, it's seen 8 or 9 seasons on the trainer. This tire has no cracks either from age.
