Triplizer (Tripleizer, Triplelizer)
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
There's enough of a gap between the teeth of the granny and the outer tabs/bolts for the chain to sit? Or is the spacing basically equivalent to running a triple outer and granny with no middle, resulting in a large tooth-to-tooth spacing between rings?
Here's the way I see it. Approximating 4mm tabs and 8mm chainring spacing, and using the outer teeth as a reference of 0mm chainline:
0mm - Outer teeth
-2 to -6mm - Spider tab
-8mm - Normal double inner, this is only 2mm away from the tab, so the chain will hit the tab
-12mm to -16mm - Granny position on a triple, 12mm is for standoffs that need additional spacers. There are 8-12mm between chainrings, so there's a large risk of skating or the chain actually going between the rings.
0mm - Outer teeth
As I mentioned, in my case, this was the only 130BCD I could easily pull off the shelf and attempt to run the triplizer as the outer ring and effectively move the 74BCD granny to be in the space occupied by a traditional inner. I believe if my crank arm did not have the platform for mounting a 74BCD chainring, this set-up would work perfectly. I wish I had an unmounted Shimano 130BCD to attempt this on. I'm pretty certain it would work on this Dura Ace crank.
However, I'm not planning to pull it off the bike to service the BB until after Christmas, so it would be a long wait for the OP to get an answer. I'd like to encourage @Byepsycho to try his Willow set up in a similar way on his Centurian crankset.
Again, just a boomer's two cents FWIIW for a millennial. YMMV.
Bob
Bob
Quoted: 237 Post(s)
Liked 83 Times
I'm just not seeing it. I can't see any way the chain would clear the spider tabs if the inner ring were pressed up against the inside of the spider tabs instead of below the teeth. The chain needs room to both sides of the chainring to sit on the chainring. If you manage to put a 30t on a 130bcd crank, the teeth will be right around where the chainring bolts and the tabs are, and without being spaced in, they will be pressed up right against the tabs, leaving no room to the side.
If you lay a chainring flat on a table, then you can't put on a chain on it without lifting it. If the chainring spacing is kept the same, then the granny ring is being pressed up against the insides of the tabs the same way it would be if you put the ring on a table. It only works with the bigger inner ring because it overhangs the tabs.
^^^ I'm not sure how you're envisioning this. The tripleizer replaces the inner chainring, and becomes the middle chainring. The drop down tabs on the tripleizer ring go in between the spider arms. The inner chainring bolts onto the tripleizer tabs using stand off spacers to get the correct spacing and room for the chain.
WRT to everyone else telling the OP to go for it and learn by trial and error. That's typically good advice and true. Just fair warning that this may not be easy or cheap. Spindle swaps and triple conversions could be a big pain even in a well equipped shop with boxes full of various sizes bottom bracket spindles. I do agree that if the the OP does this DIY, best to start by putting the newly reconfigured crankset on the existing BB. It might fit, and if it doesn't, it will show you how much extra space is needed.
Likes For Salamandrine:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Well said and summarized, sir.
Let is remember that even in a normal installation, there is a spacer placed between the spider tab and the inner ring, so as to enable the correct ring spacing. If the tripleizer is used as the outer ring, then one must simply increase the size of the spacer by the thickness of the crank arm where the outer ring bolts up- perhaps 5 to 7 mm, depending on the particular crank. This assumes there are no other protrusions cast or forged into the crank arm itself that might interfere with a smaller ring than originally designed for.
I can forsee circumstances where a very larger spacer might result in an inner ring that is inadequately supported-especially if being used energetically by a particularly stout rider, but generally this should work just fine.
Likes For rccardr:
It might potentially work with certain cranks if they have enough undercut to the spider. Some early 90s aero cranks for example. I still don't like the idea. Would probably require grinding away the inner chainring ledge of the spider.
Quoted: 237 Post(s)
Liked 83 Times
aka: Dr. Cannondale
Liked 3,404 Times
As it were.
So to speak.
Quoted: 237 Post(s)
Liked 83 Times
I believe you misunderstand either my meaning or the construct involved. There is no phantom middle ring, it is essentially set up as a double. So the spacing between outer ring and inner ring (remember, there are only two rings in this example) is no different than the spacing between normal rings on a normal double.
As it were.
So to speak.
As it were.
So to speak.
Likes For Kuromori:
Quoted: 765 Post(s)
Liked 660 Times
Wait, what? Is there really talk of using the triplizer as the outer ring and the granny as the inner ring of a double? The best way to see why that won't work is to try it.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
aka: Dr. Cannondale
Liked 3,404 Times
Quoted: 765 Post(s)
Liked 660 Times
I suppose I should, but I might not--I only skimmed this thread after the subject line caught my eye, so I may misunderstand what's really going on. But here's an approach I used to set up a triplizer and granny ring as a double. I realize this isn't the BCD under discussion here, but the same approach would work, I think.
Installing a Triplizer as a Compact Double - Red Clover Components
--Ogden Nash
--Ogden Nash
aka: Dr. Cannondale
Liked 3,404 Times
Aha. NOW I understand. Thanks so much!
Freewheel Medic
Liked 2,196 Times
Last night I almost bought an orphaned right side crank arm (a double) in order to try out what I've suggested, but decided even if it was just $20, I didn't need to spend the money. All we need is for the OP to chime back in and tell us what solutions seem to make the most sense. I even went on another search through my spare cranksets, but to no avail, the only 130BCD one I have that is not currently mounted to bike--- is pictured above. 'Tis the season and I don't have time to remove one from one of my existing bikes to attempt something I doubt I'd ever need.
So--- OP--- please come back and respond to our suggestions and guidance.
P.S. I can almost guarantee my suggestion could work on a Single Speed 130BCD crank arm. There are several relatively inexpensive options on ebay including this one which I almost bought.
Bob
Bob
...and where is our OP newbie who could try out what I suggested with his/her Centurian/Shimano 130BCD crankset?
Your suggestions may confuse succeeding generations of inexperience mechanics.
Although, you may have turned my first post into a presumptuous tangent, I still love you for all you do for us younger, internet trolls - "no matter what mom says".
Thanks for always going the extra mile for me. ♡
...I've tried attaching the Triplizer where the big ring belongs, but the crank arm makes it impossible to then attach the granny ring to the Triplizer's screw holes. The only way I can envision this working is by attaching the Triplizer to the back side of the spider; attaching the granny ring to it; and recentering the chainline by getting a BB with a longer spindle.
I'll take a picture to illustrate what I described.
Also, please pardon my delayed response.
I've tried commenting, but I keep getting an error notification about not having enough posts to reply.
I hope this goes thru.
P.S. Thanks to everyone else who chimed in.
There's a great deal of options and opinions on here for me to reference, and I hope it helps others in the future too.
I'll post pics of the final product and the steps that worked for me.
Thanks, again, O.G.s!
Freewheel Medic
Liked 2,196 Times
OP--- @Byepsycho oh how you have made my heart leap with joy that you came back and responded! I'm so sorry that you've experienced technical challenges with BF. That's a bummer!
When I tried to mount mine, I discovered that I needed to attach the one nut/bolt loosely on the 74BCD that sits under the crank arm to the 130BCD triplizer, before slipping both rings into place. When you do so, install this one with the nut under the arm and the screw side facing towards the frame. After you do this you should be able to attach the remaining four 74BCD nuts/bolts and the five 130BCD nuts/bolts.
Looking forward to your pictures and thank you for taking some good natured "chiding" from your 62 year old internet "dad."
P.S. I have a single 27 yo daughter living in the Nashville area who is gainfully employed. Looking?
Bob
Bob
Quoted: 350 Post(s)
Liked 122 Times
As others have said, a triplizer on the outside of the spider won't work. The chain will either hit the spider when down shifting or the outer bolts will hit the inner ring. If increasing the gap between the rings to solve this, then the chain will fall between the gaps.
Also, if the existing chain line was already 43.5mm on the double, and using a triplizer on the inside as the new outer, then you'd have to move the crank 8mm outward or 16mm spindle length.
Likes For tomtomtom123:
Quoted: 765 Post(s)
Liked 660 Times
Dear 'dad' from another brother,
Yes, as noted, the idea of attaching the triplizer in the outer position was doomed from the beginning. In fairness to you, though, that's really not obvious until you try it--at which point it becomes very obvious (as you discovered).
But as I noted in my previous post, you can install the triplizer in the middle-ring position in combination with a triple spindle, and then put some kind of a chainring guard or "bash guard" in place of the outer ring. You can make a bash guard from a worn-out chainring pretty easily, or buy one. Cyclocross riders use them, and they're available, and not expensive, in most common BCDs. It works well and looks good. If you don't mind the setup looking a little weird, you don't even need to use the bash guard, which is basically cosmetic.
--Ogden Nash
--Ogden Nash
Bikes: 1973 Schwinn World Voyageur | Francesco Moser SL | 1984 Ross Utopian | St. Etienne 531 | 1981 Peugeot PK10 | 2015 Cannondale SuperSix | 2012 Felt F65X
Quoted: 54 Post(s)
Liked 51 Times
What amazing timing as I almost ordered the 46T Tripleizer for the outer ring of my Shimano 600 and then this thread was found. I too wanted to make a sub-compact double but realized that without the 50.4/80 BCD it almost needs to be a triple to get the range.
