Disc brakes are now the default on road bikes and no one cares
Quoted: 3949 Post(s)
Liked 7,296 Times
You're full of worthless commentary. Ever come up with any valuable advice, like discs are better in the wet, or better for heavy riders who might find rim brakes inadequate for steep, winding descents? They have advantages for some, but not all riders and probably not the majority. They mainly contribute to more dealer profit.
Bikes: 2017 BMC Roadmachine 01 Enve wheels, Sram red etap,Cinelli Vigorelli single speed, 2009 Cannondale Capo, 2016 trek Domane 6.9, disc and Di2, 2016 Scott Scale 710, 27.5 plus tires and boost rims
Quoted: 110 Post(s)
Liked 203 Times
A few years ago I did a cold, wet ride down from Craggy Gardens to Town Mountain road in NC. I was with a guy with disc brakes, I had rim brakes. Side by side, compared to him , I had essentially no brakes. Up until that morning I just accepted the noisy unpredictable performance of rim brakes as the way it is.
I am almost 100 % hydraulic discs now and can't see buying another rim brake bike unless I go vintage.
"ready to navigate"
"ready to navigate"
Likes For bykemike:
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
Discs are becoming increasingly stock on new bikes without any optional choice for rim brakes. For better or worse the argument for or against disc becomes day by day increasingly moot. Just an observation, not a thumbs up or down on disc brakes.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
https://www.amazon.com/SHIMANO-BR-CT...-28&th=1&psc=1
Or twelve
https://www.amazon.com/Sunlite-Alloy...255251&sr=8-39
Or one hundred and fifteen
https://www.amazon.com/Paul-Componen...255251&sr=8-51
Or whatever you can scavenge from the calcifieds
Genesis 49:16-17
Genesis 49:16-17
5.5 kg vs 6.9 kg on a climb? I'll take the 5.5 kg bike any day all day if i'm doing this for a living.
Quoted: 1088 Post(s)
Liked 1,024 Times
Why care? Dual pivots were heavier then single pivots and were bulkier, yet other then cane creek 200sl the only single pivot by 2000 were the cheapest of the cheap. Weight and chunky didn't matter since the stopping was night and day. Going down major hills in the Catskills one would stop and the other would lightly modulate speed and a decent basic cable disc setup stops better still not to mention the ease of using hydraulic. I can remember squealing down muddy slopes hoping my cantis would slow my cross bike and the discs do. Loaded touring with rim brakes is just fun in the wet, especially the game of will or won't it stop in time. Maybe this has to do with me being a clydesdale and needing brakes that really stop but discs are the best to me. I've been struggling the last week with the possibility of buying a DeRosa carbon frame and fork NOS from 2008 or so, only 700.00 and my size which would be sweet. But its the same age as my steel Carrera, probably doesn't ride that much better and it doesn't have disc which I know I want on my next bike. The whole disc, 142mm thru axle does result in a much stiffer wheel that feels really balanced as well and I think disc rims look better to boot.
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
Liked 9,456 Times
Liked 9,456 Times
The disc-brakes-were-foisted-upon-us narrative always amuses me because of how much it just doesn't ring true in my case.
I bought a gravel bike with mechanical discs. I liked it well enough, but decided to upgrade to hydro when I found a good price on a kit. After the install, I was immediately hooked and there was no going back. I've bought two hydro disc road bikes since. I've heard similar "why didn't I do this sooner?" stories from others, much more so than, "eh, I can take it or leave it." "These are horrible and I'm going back to rim brakes!" is almost unheard of, IME.
So foisted? Not so much. I, and many others like me, have been enthusiastic adopters.
Likes For WhyFi:
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
For my part, disc brakes have just always looked better. Moreover, mainly riding in mountains where hills can get very steep, it's a must for me.
Likes For eduskator:
Quoted: 8279 Post(s)
Liked 9,033 Times
ugh as it is, there are still LOTS of disc bikes struggling to go under 6.9 kg, while almost all rim brake bikes are having to add heavy components to meet the 6.9kg minimum requirement. So no, not every UCI rider has to adhere to the same weight. It's more like rim brake bikes are forced to add weight. And like you said, the tech is there (and people are already doing it) to go to 5.5 kg.
If, as you say, some are struggling to get under 6.9, it probably isn't by much. And, if that's true, then lowering the minimum to 5.5 would obviously put those people at a 3-4 pound disadvantage. Why would the UCI want to do that? To just eliminate disc brakes from the peloton?
People say disc equipped bikes are 500g heavier than similar rim braked models.I guess you're saying it's more like 2000g?
Liked 9,456 Times
+1
A disc and small caliper within the wheel gives cleaner lines to me, compared to a rim caliper hanging off of the fork/stays like a wart.
Also, in terms of performance, I'll say that the lighter lever effort of hydro is better all of the time, not just when it's wet or whatever.
Likes For WhyFi:
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
A) The bikes the ProTour rides must be retail product
B) Already at those weights...rider weight limits abound, typically 180lbs max--because while lightweight the frames and wheels simply are not structurally strong enough for "normal" people.
Reminds me of the old "If it isn't broken/falling apart at the finish it is overbuilt" tortured "logic".
Liked 9,033 Times
Here is a Cannondale @5.7kg, but not the record for the lightest disc road bike.
https://www.cyclingweekly.com/news/product-news/lightest-disc-brake-road-bike-world-2983
https://bikerumor.com/2018/11/30/201...oes-full-aero/
Supposed to be lighter.
Likes For big john:
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
S-Works Tarmac Disc: 6.6 kg
Likes For Cypress:
Liked 9,456 Times
There are off-the-shelf disc bikes under 6.9. Nothing that a pro world ride would have much trouble getting under that limit.
Likes For WhyFi:
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
And I would happily trade 200-300 grams for the braking feel and performance. Not wearing out $2500 carbon wheels with rim brakes is a huge added bonus.
Likes For Cypress:
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Correct. At most and as a whole for all riders. In other words - I live in the flat lands - I absolutely never need them.
Some live where there is actual elevation. They can use them as a benefit there.
So apologies for using the word need. Should have been 25% of the time they are a benefit.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
I eat carbide.
Liked 1,306 Times
The side benefit for me in the wheel world is that disc brakes have virtually eliminated the customer's obsession with wheel weight. With disc there are so many variables in what the hubs are that weights on the same sets with different setups vary so much that they aren't comparative. Eliminates about a third of the conversation content I used to have to have daily.
Likes For Psimet2001:
Quoted: 626 Post(s)
Liked 701 Times
Understand that the weight thing is a non-issue for probably 99.9% of bike purchases. Even relatively dedicated riders that are buying a good bike for fun and/or commuting aren't going to care. Only the racers (including tri-athletes) and time trials riders care about that level of minutiae.
My first disc brake equipped bike (recumbent), I bought because I had just moved to Seattle and wanted better wet weather performance. That alone was huge to me, and it was quite noticeable. I had good 'wet' rim brakes, but their performance never came close to the performance of discs. My bikes are 99% used for commuting. By the time I put a rack, lights, panniers, etc., the extra weight is a non-issue.
Likes For Notso_fastLane:
Quoted: 4717 Post(s)
Liked 1,882 Times
I'm surprised he hasn't made a comment here yet.
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
I went through a rough patch with a wheel sponsor a while back. I kept cracking their zooty high-end wheels (I corner hard) so I "downgraded" to a higher spoke count with heavier rims and immediately stopped having issues.
Likes For Cypress:
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
Discs
Anecdotally, Im not any slower up big climbs with a heavier disc bike than I was on my lighter rim brake bike.
We have a good climb near me that rises 1300 over about 1.3 miles and I didnt notice a difference after switching to a disc bike that was about a pound heavier. What I did notice was coming down the backside I didnt feel like I had to brake as early or hard and could make the descent a lot faster where my average speed was in the low 40s vs mid 30s on the old bike.
I like disc, modulation and performance in the wet is great and more confidence inspiring
Likes For phrantic09:
