2003 Fuji Team
Bikes: Raleigh C500
2003 Fuji Team
Does anyone have input on 2003 fuji team I can get it for $1000 with full ultegra only negative seems to be lacking carbon seatstays, or is that a negative. This would be my first road bike. here are the specs and a picture from fujis website.
Frameset
Sizes 49cm, 52cm, 54cm, 56cm, 58cm, 61cm, 64cm
Color(s) Screaming Red/White
Main frame X-Fusion Quaternary phase alloy, custom butted and shaped with PowerDiamond down tube, integrated head tube, Double water bottle mounts
Rear triangle X-Fusion Quaternary phase alloy butted seatstays and chainstays, Fuji forged road dropout with replaceable derailleur hanger,
Fork Fuji 1 1/8" Full Carbon Road for integrated
Drivetrain
Crankset Ritchey Pro Road, 6061 forged alloy with 5180 alloy CNC 39/53 chainrings
Bottom bracket Shimano Ultegra Octalink, 109.5mm
Pedals N/A
Front derailleur Shimano Ultegra, 31.8mm
Rear derailleur Shimano Ultegra, 9-speed
Shifters Shimano Ultegra 9-speed Shifter/Brake, Flight Deck compatible
Cassette/freewheel Shimano Ultegra, 9-speed, 12/23
Chain Shimano CN-HG93
Wheelset
Ritchey Aero Pro OCR, 24/28H with DT spokes
Tires Vittoria Rubino Pro with Kevlar bead, 700 x 23c
ultralight presta tubes
Features
Brake set Shimano Ultegra
Brake levers Shimano Ultegra 9-speed Shifter/Brake, Flight Deck compatible
Headset Ritchey Logic Zero Integrated Pro Road with conical hollow alloy 25mm spacer
Handlebar Ritchey Logic Pro 31.8mm Road, 7075 Triple Butted Alloy
Stem Ritchey Logic Pro 31.8mm Road, 6 degree
Tape/grip Fuji custom cork wrap
Saddle Fuji UltraLite Racing with Titanium rails
Seat post Ritchey 3-D forged Pro road, 250mm
Seat clamp Fuji Ultralite alloy, 31.8mm, Lazer etched
Others 7075 alloy water bottle bolts
Weight 16.8lbs./7.5kg.
Specifications are subject to change without notice.
Frameset
Drivetrain
Pedals N/A
Wheelset
Features
I'm Melting.....
Bikes: Like everyone else, this changes from time to time.
I just bought the '04 model at my local Performance bike. I shop in there A LOT, and was able to get it for $1100 out the door. Overall I like Fuji bikes, I have 3 (about to go down to 2- my '03 Finest AL sold on eBay). For a first bike I don't think you will have any complaints, and the groupo leaves you with very little to upgrade except for maybe seatpost/saddle/handlebars.
Fuji 2003 Team derailleur hanger.
Hi,
I need a replacement for my Fuji 2003 Team derailleur hanger. Can anyone point me out to any direction or send a link where I can purchase within the U.S.
THANK YOU IN ADVANCE.
Throw the stick!!!!
Get on ebay and search Fuji derailleur hanger. There are only a few options so you will be able to match yours up to one pictured. I had to do it not too long ago for a 2006 Fuji SL1.
I may be fat but I'm slow enough to make up for it.
Likes For LowCel:
