Voltaic Fuse 4W solar charger
Old 05-09-16, 05:57 PM
azza_333
azza_333's Avatar
Bikes: A few
Quoted: 100 Post(s)
I'm looking into Dynamo & solar chargers again. I was initially think that if I installed a SON28 with a Busch&muller Lumotec IQ2 Luxos U, so I can charge USB stuff off it. I worked out that I will probably need 3500-4000mah a day. I am concerned that I wont be able to get enough power from the dynamo alone, since I will only be riding an average of 7 hours a day and 15/kmh (9.4mph)
So I was possibly thinking of supplementing the Dynamo power with a Voltaic Fuse 4W solar charger. I have read a few reviews on this online, but non give a real world amp output of the USB port, has anyone tester their own and know the answer?
Also I am assuming the Dynamo will only supply enough power for 300-400mah per hour, is this estimate accurate?
azza_333 is offline
Old 05-10-16, 04:48 AM
BigAura
BigAura's Avatar
Bikes: all steel stable: surly world troller, paris sport fixed, fuji ss
Quoted: 621 Post(s)
Liked 46 Times in 29 Posts
There's much beefier panels I'm interested in the Anker 21W ($56/14.9oz).
BigAura is offline
Old 05-10-16, 08:36 AM
Tourist in MSN
Quoted: 2149 Post(s)
Liked 450 Times in 372 Posts
I think my AXA Luxx 70 Plus is one of the lowest output USB chargers available and I have measured over 500 milliamps out of it when above 20 km/hour. The USB port is under the gray cover on the mounting bracket. I am not sure at what minimum speed I need to be at to get 500 milliamps, but I suspect with your carbon wonderbike that slow speeds is not your concern.
I would expect that most other dedicated USB chargers like the Sinewave or B&M would perform better than mine. And there is more info at these recent links:
https://www.bikeforums.net/touring/10...0-mah-day.html
https://www.bikeforums.net/touring/10...pressions.html
I have seen comments on a cheaper brand USB charger that at higher speeds it will cut out and stop producing power, but I do not recall which brand. If you look at the lower cost brands, look at review comments on the internet to make sure you are not buying one that will not function at higher speeds. At higher speeds, the hub can put out a lot of power and at least one of the cheaper ones cuts out to avoid getting overloaded.
I soldered up a couple of my own do-it-yourself USB chargers but blew out the circuits on the downhills so I gave up trying to make my own.
File Type: jpg
Tourist in MSN is offline
Old 05-10-16, 09:31 AM
arnaguedes
arnaguedes's Avatar
Bikes: Charge Duster Chromoly
I have an anker 8w solar panel and with full sun I have 1Amp
arnaguedes is offline
Old 05-10-16, 09:46 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,308 Times in 821 Posts
so what did the manufacturer of the hub respond , with the answer ?
fietsbob is offline
Old 05-10-16, 04:47 PM
azza_333
azza_333's Avatar
Bikes: A few
Quoted: 100 Post(s)
Nope
azza_333 is offline
BlarneyHammer
Touring
3
05-21-17 08:20 AM
kando
14
08-30-16 08:22 PM
bikeforlife123
18
03-01-16 04:22 PM
christ0ph
8
12-05-11 05:09 PM
marada
Bicycle Mechanics
20
07-06-10 06:47 AM
