2020-1 Size 56 & 58 Specialized Roubaix handlebar height
I'm trying to find the vertical height from the ground to the top of the handlebar tops of a stock 2020 or 2021 model Specialized Roubaix, with the taller of the two FutureShock spacers installed, in both size 56 and 58. The geometry charts appear to be identical for all models, so any model is ok.
Ideally I could just drop by a local bike shop and measure for myself, but bikes this size where I am (Japan) are practically non-existent, so if someone on BikeForums has a 2020 or 2021 Specialized Roubaix in size 56 or 58 and some time to measure their bike, can I trouble you to measure the handlebar height for me and post the measurement here? Thanks!
Quoted: 6193 Post(s)
Liked 4,809 Times
Charts generally are only showing the measurements to the top of the head tube, maybe headset. So figure the bike will probably come with 30 or so millimeters worth of spacers. But you can call a shop that carries Specialized bikes and I'm sure they'd be happy to tell you over the phone how many spacers that particular model normally comes with when new.
Quoted: 643 Post(s)
Liked 1,526 Times
Just curious but why is the height from the ground important?
Likes For Ogsarg:
Liked 4,809 Times
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Also curious but wouldn't the handlebar height change depending on the stem +/- angle?
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,035 Times
2020 Roubaix Expert (FutureShock 2.0) in 56cm measures 38.5” or 978mm from the top of the bars to the ground with 32mm tires. I have no idea which FutureShock spacer is installed, though.
Likes For MattTheHat:
https://yojimg.net/bike/web_tools/stem.php
Edit: The FutureShock manual on Specialized's website states that up to 15mm of spacers can be added above the duck-billed spacer (diagram 4 on page 3 - link below). That's a nice surprise, and while I could ride either size with a few adjustments, it makes the 56 a more attractive option than the 58 for me.
https://media.specialized.com/suppor...0000134022.pdf
bOsscO
Quoted: 296 Post(s)
Liked 355 Times
Comparing to another bike I have.
I'm assuming the bike is standard, but you can easily calculate how much of a difference changing the stem would make using the calculator below.
Stem Comparison Tool | yojimg.net
Quoted: 1067 Post(s)
Liked 259 Times
Aside from spacers it will depend on stem length, angle, which way it is flipped. There is also the Specialized "hover bar" which can add some height if required.
I doubt many Roubaix owners know its even possible to add actual spacers to their 2020 or 2021 Roubaix. They're going to have either the short or tall duck-billed spacer only installed (see above).
The measurement with the stock stem is easiest to work with, but its straightforward to calculate any differences a non-stock or flipped stem will make.
I'm pretty sure all 2020 and 2021 Roubaixs come with a Specialized "hover bar" as standard.
Quoted: 1851 Post(s)
Liked 679 Times
Comparing handlebar height from the ground from one bike to another is not a great way to measure things. BB height, tire size, fork length, HT angle, spacers, and stem length and angle all factor into the height of the bars, and you could very easily have two bikes with bars at the same height from the ground that fit very differently.
Really hard to get a straight answer to a simple question on this forum...
Liked 4,809 Times
Also, the question you are asking requires someone that has a 2020-1 Size 56 & 58 Specialized Roubaix to see this thread and be interested enough to answer.
Liked 679 Times
Why not just compare the stack and reach of the frames? If it is identical, or close, to your existing frame, then you should be able to get your bars in about the same place/height.
Liked 259 Times
Bar height is really only relevant to saddle height so you can get the saddle/bar drop you want.
So BB height is the only other factor that you mentioned which effects it.
I know the saddle to BB distance I require, the angle of the seatpost, BB drop, wheel diameter, tire size etc. so can calculate exactly how high from the ground the top of the saddle will be. But I don't exactly where the handlebar will be, so don't know exactly how much saddle/bar drop I will get. Stack only gives an approximate.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Stack is pretty accurate, not really approximate. The 58 is 25mm taller. So whatever set up you have, if they're the same...there ya go. You now know the bar height of the 56, sooooo...
Yep, thanks. Already calculated that. Another bar height data point or two would be nice to have as confirmation though...
