Convert Fixed to single speed PLEASE HELP
Old 04-29-20, 02:46 AM
jeffreydeguia
Quoted: 11 Post(s)
Hi new to the forum, pretty novice at cycling as well. Essentially, need help because COVID got people stealing bikes left and right and fell victim. My pure fix w/ the flip flop hub was taken at home, but a buddy gave me his fixed gear, but it's not freewheel! How do I convert my back wheel/hub to make it freewheel? (I bike for commute mainly and casual riding wth baby daughter) please help! I also want to put disk brakes on her, if anyone would be so kind? Thanks in advance!
jeffreydeguia is offline
Old 04-29-20, 03:25 AM
Trevtassie
Quoted: 1188 Post(s)
Liked 1,154 Times in 640 Posts
Take off the lockring and sprocket, a freewheel will screw straight on to the same thread the sprocket came off.
Trevtassie is offline
Likes For Trevtassie:
Old 04-29-20, 07:54 AM
AlmostTrick
Tortoise Wins by a Hare!
AlmostTrick's Avatar
Quoted: 1549 Post(s)
Liked 941 Times in 504 Posts
And you can't feasibly install discs on a frame and fork that was never designed for them.
AlmostTrick is offline
Likes For AlmostTrick:
Old 04-29-20, 08:22 AM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Note that you can install the freewheel with your hand and tighten it with the chain, but if you ever want to remove it you’ll need the appropriate tool.
caloso is offline
Old 04-29-20, 09:36 AM
acir71
Bikes: Mongoose Maurice FS 2011 fixed gear, custom 2017 Haro Master Flatland bmx, Contrast FL475 mid school flatland bmx
Quoted: 15 Post(s)
Liked 11 Times in 10 Posts
Correct me if I'm wrong, I thought the thread surface width (on the hub) for fg cog & freewheel are different? I do notice that flip flops aren't the same on both side, the fg side has a 2 tiered thread size- the cog thread (inner) is bigger in diameter (same as the freewheel) while the lock nut (outer) one's smaller? I assume the freewheel won't sit in nicely if you install it on the fg side, only abt half of it's thread will contact the hub thread since fg cog is only abt half the width of a freewheel? Or is it ok to have it like that?
acir71 is offline
Old 04-29-20, 10:54 AM
AlmostTrick
Yeah, it's ok. There's still enough threads to properly hold the freewheel.
This is why "fixed" "fixed" hubs are best. Both sides have the double threads allowing a lock ring. One can then run any cog/freewheel combo they choose.
Old 04-29-20, 12:15 PM
Mikefule
Quoted: 99 Post(s)
Liked 115 Times in 78 Posts
Remember the sprocket/freewheel is clockwise to tighten, the lock ring is the opposite.
Mikefule is offline
Likes For Mikefule:
Old 04-29-20, 01:29 PM
jeffreydeguia
Quoted: 11 Post(s)
Hoping this reaches all contributors on this thread but thanks to all! So based on your replies, are these pieces and tools (i can't upload a pic) all the things I would need to purchase?
  • Singlespeed or track wheel
  • Cog of appropriate size
  • Lockring
  • Lockring wrench
  • Chain whip or chain pliers
  • Grease
  • 15mm Socket Wrench
How would know which sizes or they all pretty much standard?
my chain looks little worn too, I heard that it's highly advised to change that during this process, advice?
Old 04-29-20, 01:34 PM
caloso
caloso's Avatar
If you are going to have a freewheel, I would recommend front and back brakes. If you are going to keep it fixed, you really just need the front, although having both doesn't hurt.
caloso is offline
Old 04-29-20, 01:38 PM
jeffreydeguia
Quoted: 11 Post(s)
any advice re: putting brakes on my fixie?
Old 04-29-20, 03:59 PM
AlmostTrick
  • Lockring
  • Lockring wrench
  • Grease
Wait, in your opening post you said the bike your buddy gave you is a fixed gear and you wanted a freewheel. Now you want a cog and lock ring? And a wheel? What do you actually have and what do you want? Does the bike have any brakes on it now?
Old 04-30-20, 10:30 AM
Mikefule
Quoted: 99 Post(s)
Yes: do.
Some people ride without brakes, relying on skidding. Not having brakes is illegal in some jurisdictions. It will be a factor in any liability decision following an accident. Brakes are designed to decelerate the bike without breaking traction, and without sacrificing rubber from the tyre. Better to have brakes and never use them, than not have brakes and find that you need them one day.
A front brake is considerably more effective than a back brake. This is because the act of braking transfers more weight (and therefore traction) to the front tyre, meaning the front tyre gains grip and the rear tyre loses it.
You can therefore ride fairly safely with just a front brake, relying on back pressure on the pedals to slow the rear wheel. One associated risk is that in bad conditions (wet oily road, grit, mud, gravel, ice) if you lock your front wheel, you will certainly fall off. If you have a back brake and you lock your back wheel you still have a good chance of regaining control.
The front brake is easy to install and set up. A simple side pull calliper brake is good enough for most purposes.
The rear brake, although useful, is more problematic. If you change your sprocket size, you will need to position the rear wheel slightly further forward or backward to keep the chain tension. You can probably change by 2 teeth before you find that the rear brake blocks are in danger of catching the tyre or spokes — either of which would be a Bad Thing. You can of course add or remove links to the chain, which is a 5 minute job, but not something you'd want to do if you flipped the back wheel round to change ratios at the road side on a long ride.
Personally, I have front and rear calliper rim brakes on my fixed, and typically ride for hours without touching the brakes — but I know they're there if I need them. I never skid deliberately, but I try to use the drive train to control my speed. I know that I would ride faster in some circumstances if I was willing to use the brakes, but this is a game I play for my own satisfaction. The brakes are for emergencies or when all else fails: long steep descents and the like.
So, definitely fit a front brake, and probably fit a rear brake. Side pull calliper rim brakes are the easiest option, and should be easy to fit to any frame designed for road use.
Mikefule is offline
Likes For Mikefule:
Old 04-30-20, 10:37 AM
stevel610
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 365 Post(s)
Liked 457 Times in 240 Posts
  • Lockring
  • Lockring wrench
  • Grease
A less expensive route would be to take your rear wheel to the local shop, have them remove the fixed cog and put a freewheel of appropriate size on. It will be about 15 minutes of labor, and done right.
Buy the freewheel from them. A Shimano will probably be less than $25. They might not even charge to take the old cog off and install. But don't give them a hard time if they do, they are suffering during these times.
stevel610 is offline
Likes For stevel610:
Old 04-30-20, 03:50 PM
Mikefule
Quoted: 99 Post(s)
Short term less expensive because at the end of it, you have the result, but have gained no knowledge, and no tools, so next time you'll have to pay as well.
The right tools are an investment. Bikes are not complicated machines to work on, unless you buy the complicated parts the market tells us we need (hydraulic brakes, etc.)
Mikefule is offline
Old 05-01-20, 11:29 AM
jeffreydeguia
Quoted: 11 Post(s)
sorry for the confusion, i'd like to reiterate, I'm noobie. I inherited a fixie, no brakes, and I want to change to freewheel w/ disk brakes. And I basically have zero tools to complete the job, so i'm also on the market for the proper tools (which I'm unsure which ones to buy)
Old 05-01-20, 11:35 AM
jeffreydeguia
Quoted: 11 Post(s)
This is why I joined the forums, I'm trying to gain at least a tidy bit of knowledge to up my skills so in the future I wont need to run to the shop, any luck you can share me on which tools I need to purchase as well? Thanks in advance everyone for all the help again!
Old 05-01-20, 11:59 AM
TugaDude
TugaDude's Avatar
Quoted: 586 Post(s)
Liked 612 Times in 447 Posts
What is the exact frame that you have? Reason I ask is it will help us if we know what it is. As was said above, unless it is already set up for disc brakes, forget about it. There are adapters where you could add a disc brake to a front fork, but I wouldn't go there, especially if it isn't a sturdy steel fork.
So that leaves conventional caliper brakes. And whether those are viable is based upon which frame you have. Some fixed-gear frames aren't conducive to adding brakes and some will accommodate brakes but only with some drilling or other preparation. Then there is the issue of brake reach. It really is more complicated than just "adding brakes".
TugaDude is offline
Old 05-01-20, 12:22 PM
Mikefule
Quoted: 99 Post(s)
There is no limit to how many tools you can acquire over a lifetime in cycling and other activities. With a few exceptions which are absolutely bike specific (like a chain tool) they all have countless applications in other aspects of life. For example, a good set of metric combination spanners (ring at one end, open at the other), a good set of Pozidriv screwdrivers, and a good set of Allen keys. A 1/4" drive socket set is good for small stuff that you find on bikes. A 3/8" drive is a little more versatile for non-bike jobs, and a 1/2" drive is for bigger jobs like working on your car or motorbike.
Everyone needs a big, a medium and a small adjustable wrench (spanner) but should not use them by default. If you have a proper spanner available int he right size, use it.
Normal pliers, needle nose pliers, and good wire cutters (you can get specific ones for brake cable inners).
A chain whip in the right width for the sprocket. (1/8" or 3/32" for example.) One that is "too wide" will fit a narrower sprocket, of course. A chain whip is sometimes called a "freewheel turner" at least in adverts on Amazon.
If you have a freewheel, a compatible freewheel removal tool.
A C spanner for removing the lock ring. You will need the right size. A C spanner is sort of hook shaped with a tab at the end that engages with a notch in the lock ring.
A decent set of Allen keys.
In addition to a set of Allen keys for the workshop, something like this has many uses out on the road. They come with 3 sizes that you most commonly use.
A pedal wrench, if your pedals have flats where they screw in. Some only have Allen sockets on the blind side. A pedal wrench is a slim spanner of the right size to fit the flats.
A chain tool which can be used for splitting and re-joining chains, and freeing stiff links.
I'm in the UK and can find most of these things at Halfords, or local bike shops. They are also available easily on Amazon. One nice brand for bike tools, although slightly expensive, is Park Tool.
Mikefule is offline
Likes For Mikefule:
Old 05-03-20, 06:54 AM
ted_major
ted_major's Avatar
Quoted: 37 Post(s)
Liked 31 Times in 18 Posts
That’s true, but on the other hand, OP wants to switch from fixed to single speed, so they’ll need a chainwhip and lock ring spanner only once to remove the fixed cog.
It might make more sense to have the shop switch the cog for a free wheel and then when the freewheel needs replacing, buy the freewheel removal tool, which OP might get more use out of.
ted_major is offline
Likes For ted_major:
Old 05-03-20, 09:53 AM
IAmSam
Quoted: 399 Post(s)
Liked 273 Times in 136 Posts
What is it about this group that everybody has to complicate a very simple task?
OP said he has flip-flop hub, so...
The only tools he needs to convert his bike to singlespeed are a 15mm wrench to loosen the tracknuts so he can take his wheel off, and his fingers to screw the FW onto the other side of the hub before he flips the wheel to put it back on
IAmSam is offline
Likes For IAmSam:
Old 05-03-20, 09:59 AM
stevel610
Quoted: 365 Post(s)
Barring having a shop do it, I like your answer.
Also needs to purchase and install brakes.
Old 05-03-20, 10:03 AM
stevel610
Quoted: 365 Post(s)
Didn't realize you needed to add brakes. In that case I will change my suggestion because you are moving into a price area where you could get a new lower end bike for not much more.
YouTube KevCentral, he reviews Walmart and other affordable bikes. Find one in your price range and purchase. For what you are looking for a $100 coaster brake beach cruiser would work fine and be less expensive than the upgrades + tools.
Good luck.
Old 05-04-20, 03:01 AM
jeffreydeguia
Quoted: 11 Post(s)
Sorry fellas had a hectic weekend. Based on everyone's replies (which I'm so grateful for), seems like the more sensible thing might just go to the bike shop and have them convert it for me, rather than spending on the pieces and all the tools
Old 05-04-20, 06:16 AM
catacombs
catacombs's Avatar
Bikes: Kilo TT
Quoted: 13 Post(s)
Liked 7 Times in 5 Posts
You might have some trouble finding a bike shop currently open in your area amid coronavirus.
catacombs is offline
Old 05-04-20, 03:25 PM
jeffreydeguia
Quoted: 11 Post(s)
Yea I was shocked as well when I called learning to find that they're open on Oahu
