Too big and strong for the frame. Suggestions?
No more spinach.
Likes For Salamandrine:
Quoted: 634 Post(s)
Liked 444 Times
Thanks for all the feedback.
Thinking right now
Single speed with freewheel for less frame stress.
Cannondale could be an option as even a complete bike is cheaper here in PDX than the Surly frame. But as aluminum, rear spacing is Not adjustable.
Varsity is bombproof but man Varsities are going for way more than I would expect, even during a bike boom.
lets see what Young Spadoni says to all of this......
Thinking right now
Quoted: 2338 Post(s)
Liked 2,827 Times
No, I’m not. It’s Mr. Spadoni the Youngest, who is 6’ 3” and tips the scales at something north of 200. He calls me today, after he had ridden to work. His question today was about the frequency of seat tube / bb separations. Seems he had just suffered his second one in a little over a year.
While he has ridden vintage bikes in the past, these failures have come on a lower end fixed gear bike that he has written for the last two years. The switch to fixed came after he realized that he did not have the temperament to fiddle with shifters and cleaning chains. With the fixed, if he had air in the tires, he would get to work on time.
The bike came from a local shop, and they have stood behind everything that he has broken, in addition to the frames. But clearly he needs to upgrade before the shop has had enough and clamps him into a work stand or something else to maintain their profits.
so here’s the question: do I try to find another frame and we build up something solid? Or does he just buy something new? Likely it would still be fixed, as he likes the feel of the ride. In either case, it will be parked on the street so it can’t be too high end, and he does need fenders. I am kind of inclined to the first option but need help in keeping things simple because I an not the one that will do most repairs.
any suggestions.
any suggestions.
if he insists on fixie (have a son like that) consider gettng a quality frame either used vintage and if need be use a singulator for chain wrap, or someting like the soma rush https://www.somafab.com/archives/product/rush or a surly steam roller https://surlybikes.com/bikes/steamroller
another option (knowing kids, even big adult ones) is a vintage geared bike that will take fenders and find a gear he likes and then tell him not to bother shifting
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Maybe find something that is tough, but will also have great ride quality. Basically, anything in Columbus Aelle, Chromor (Matrix), Thron, SP, SPX...
Quoted: 3361 Post(s)
Liked 3,638 Times
Oh man I forgot about those. If you can find one that would be an awesome bike.
Fixed gear with a chain tensioner is a no-go.
Fenders with track ends can be a PITA, so if you go that route I would suggest a full-coverage front and something like a PDW clamp-on rear fender.
I'd probably go with a good quality vintage roadie and run it fixed. It should have all the right provisions for brakes, fender mounts, and forward facing angled dropouts that make taking the rear wheel out with fenders a non-issue and allow you to get proper chain tension without a tensioner.
Quoted: 800 Post(s)
Liked 753 Times
Quoted: 1608 Post(s)
Liked 2,216 Times
A Langster might work from around 2010
[url=https://flic.kr/p/CquLb9][im2010 Langster Steel 61cm, on Flick
No light weight at 22lbs as shown.
Quoted: 2363 Post(s)
Liked 1,749 Times
^^^^^ 32-spokers might not be apropos.
So Young Spadoni drops by today. I tell him what sage advice the denizens of BF offered on his next bike and showed him a couple bikes on CL that he could consider when he was ready to buy a new steed. He left, and I expected to hear nothing for months. The lad likes to ponder before acting. But not this time. A few hours later, he texts me to say he has bought a Cannondale! With multiple speeds! And functional brakes! I am still awaiting photos, from the drive side, of course, to further I D said bike, but as Squirtdad suggested, kids will surprise you. This one sure did.
Likes For Mr. Spadoni:
I'm 6ft 3in tall, and in my younger days, when I was far more fit, I was around 280 lbs, now I'm closer to 400 and I lost an inch or so of height. Back then I used to break frames, break cranks, and wipe out freewheels all the time. The frames were usually broken either where the downtube meets the bottom bracket or across the chainstays just behind the BB.
One broke mid headtube but it broke early on in the frame's life so I more attested that one to be a defect.
Cranks were the hardest to take as they usually hurt when they broke, the frames would give me a warning and usually get me home unless it completely separated at the stays. I had one later Raleigh separate its rear stays at the seat tube.
I didn't ride fixed gear though, I'm not sure how that comes into play with frame strength but I could see it being hard on cranks.
Quoted: 331 Post(s)
Liked 332 Times
Hardening Aluminium to be avoided by the gorilla.
If you have a breaking frame problem, stay away from Al bikes - especially second hand . Al work-hardens and it will crack if you exceed its yield strength and will simply crack with no warning.
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
Or handlebars.
Or seat posts.
Or steering stems.
Quoted: 4806 Post(s)
Liked 3,931 Times
Single speed from fix gear is a BIG step down if he has fallen in love with riding fixed. If I had to make that choice I'd stick to gears despite fix gears being my number one the past 40 years.
I'd look at exactly where and why the frames are breaking. Shouldn't be happening; at least not until a few years of hard riding have happened Too short a seattube (that saves the work of mitering the tube to fit the other tubes)? Faulty BB shell?
Possible solutions for your son - an older style track bike. Those bikes are built to handle strong 200 pound riders in competition. (Well not all but the bikes used in Velodrome fleets, yes. The Fuji track bikes of not that many years ago have been used as fleet bikes by many velodromes. I've seen very big and strong national riders show up at our local Alpenrose track and rent Fujis rather than fly with their bikes.) If there's a track nearby, call them and ask about such bikes.
I had a co-worker who went through Miyata after Miyata in the early '90s. Always broke at the brake cable exit on the top tube. Miyata always honored the warranty but he spent real time without his transportation for a 20 mile each way commute. I've heard since that many of those early internally cabled Miyatas broke, Yes, he was big and strong, but like your son - still ...
Edit: MIssed the second page. Oops.
Ben
Ben
