Looking for Giant Halfway owners to verify something
We have a Giant Halfway that the hinge lock comes undone while riding. Of course, this is unacceptable. The one Giant dealer we visited was clueless about the bike. Upon inspection, it appears there is supposed to be a screw or bolt in the frame feature that hinge lock grasps. Attached is a photo with the feature circled.
I'm hoping that a Halfway owner will look on their bike and tell me what they see there.
Thanks much.
Thanks much.
Hello
Sorry no Halfway, but they cool bikes.
1. The hole is not threaded
2 The clamp and the shaped protrusion have similar shapes (one being male the other female) to maximize contact area.
This makes me think that a screw does not go there.
I suspect that the clamp tension may be adjusted by the nylock lock nut on the end of the spring shaft. But I am not sure.
Suggest you test, but if it doesn't work be sure to return it to its original position
Quoted: 380 Post(s)
Liked 106 Times
You might want to read this and see how to do it as this is an original owners manual. Roger
https://www.manualslib.com/manual/37...ay.html#manual
PS there are other sources for this on Google.
After taking another look, the hole in question IS threaded. Will attempt to post more and better photos later.
Really need a response from someone who either owns or has access to or knows someone with a Halfway to take a look..
Hello
Don't loose site of the primary objective, that is having a secure hinge clamp.
Its apparent from the photo that there has been no metal to metal contact in the area of the hole since the paint is in good condition.
I would speculate that the area may be for a small piece of cushioning plastic. Dahon uses some HDPE on one there hinge types.
If adjusting the clamp spring tension with nyloc on the spring shaft gives insufficient tension , experiment with cushioning materials in the area of the whole.
I had a halfway but sold it to a friend several years ago, nice bikes
Here are some more pictures that may illustrate the situation better. Then again, hard to capture what is or what is not going on when the clamp is closed.
