Compass tire rolling resistance
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Compass has been independently tested for rolling resistance: https://www.bicyclerollingresistance...-jon-pass-2018
I have the Compass 700x32 Stampede Pass on a vintage Cyclocross bike. This bike gets used on chipseal and limestone paths and the tire is reliable. I'll be the first to admit, it's on this bike for aesthetics. It's natural tan sidewall is perfect on a lugged Italian bike with Campagnolo. But it's not a rugged tire for any kind of gravel and my vintage Cyclocross bike doesn't get abused. Several other of my vintage bikes use the tanwall Vittoria Corsa G in either the the 700x25 or 700x28. This is my favorite tire for vintage road bikes.
I have several tires that are faster rolling on chipseal & gravel that are more rugged than the Compass tires. The Vittoria Hyper is a great all-around tire for 50/50 road/gravel. Like the Hyper, the slick Panaracer Gravelking is both rugged and fast rolling. I also use the 700x28 Continental 4000 S II, this tire measures 32mm wide on a 24mm wide rim. The 4000 S II is more rugged than the Compass tire, but like the Compass tire, it's not ideal for challenging gravel. It has incredibly low rolling resistance, however.
The 700x38 Hutchinson Override is fast rolling and is rugged enough for almost any gravel. You can have it all, if your willing to use a tubeless tire that is nearly a slick.
The Bon Jon would be a great tire to use if you wanted to validate the rank order accuracy of these drum tests. It performed abysmally on Tom Anhalt's drum as well.
Meanwhile, these results don't seem to square with Tour's test apparatus, which on a good surface had the Bon Jon at 6bar seeing lower rolling losses than the GP4000SII at 7bar (Jarno's data has the reverse by about 3 watts).
BQ's own measurements suggest that the drum tests are perhaps inaccurate in how they capture the crr effects of tread compound, and that they significantly overemphasize it.
It's all a big mess. Makes me want to get a power meter, really.
Unprotected tires on rough/loose surfaces need to be wide enough to not have lots of sidewall exposure. I haven't had any trouble offroad with my Rat Traps, but they're also enormous and so rarely need to be run at very extreme drop.
I think Stampede Pass would be one of the more difficult Compass tires to ride on its namesake, if that road is still the way it was last summer.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
But how does it fare on the suppleometer?
Genesis 49:16-17
Genesis 49:16-17
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Can be a good tire if you don't care about puncture resistance.
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
I have to wonder if the differences seen on these rolling resistance tests are actually noticeable on the road or just bragging rights. Kind of like which hub spins the longest. Do you really notice a difference?
Bearings are much less significant... a different order of magnitude in their effect.
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times
I’ve been using Compass Extra Lights for a few years now with two flats over that time; one pinch flat I caused when I first got these tires by going too low on air for the conditions while testing tire pressures, the other due to glass on the road that’d get most any good performance tire. Neither was a surprise. And now that I’ve said that I’ll get a flat tomorrow...
Tire pressure matters for longevity on gravel, especially the larger jagged variety. Mind the sidewalls. I’ve found I need less pressure than originality thought for good performance on the road and off. Lower pressure allows the tire to better conform to surface irregularities rather than fighting against them. To a point, of course, and that needs to be balanced to road miles for a given route, etc.
I’ll need to replace my second pair due to high mileage rather than some failure on the road/trail unless I’ve jinxed myself here (I probably have). YMMV, but I’ve had a good experience with them. The cost spread over the mileage has worked out, especially considering I very much enjoy their ride feel. I also coast faster downhill than my riding buddies.
FWIW, the friend I ride with the most has been using Soma Cazaderos for about the same time I’ve been using Compass ELs and has had many more flats over that time. There’s more at play than just tire construction in my opinion.
Calamari Marionette Ph.D
Meh. I'm skeptical about some of these laboratory results.
So, is it a just OK rolling touring tire, or one of the five fastest tires in the world?
Recently, the German magazine TOUR published a table showing the ‘five fastest tires in the world.’ We are excited to see our Compass Bon Jon Pass 700C x 35 mm tires on this list, in the company of the fastest racing tires. A 35 mm-wide tire on a list that otherwise includes only tires between 23 and 26 mm wide!
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
They'll measure 20 watts or so lost on the drum, but what about the hundreds of watts that might be dissipated in the rider's body on bumpy roads?
...yeaaaa, putting "compass tires" and "rolling resistance" in the same sentence effectively ignores the point of Jan Heine's existence.
If you want a comfortable, fast tire with decent puncture resistance - you'll love Compass tires.
If you want your tires to roll at x watts +/- 8finity bar demon pressure - you may never find happiness.
Bad example
Quoted: 828 Post(s)
Liked 214 Times
Yes. The Compass tires weaned me off sewups. Great, great clincher tires.
Quoted: 910 Post(s)
Liked 288 Times
A 32mm wide tire is a good size for the kind of C&V bike ideally being used at L'Eroica events. These include the Peugeot PX10 or Motobecane Grand Record. These models with centerpull brakes and indented chainstays can fit a 32mm wide tires in many cases. Larger gravel tires are usually impossible to fit on most C&V bikes.
For rural gravel roads on a modern gravel or Cyclocross bike, the tubeless 700x36 Donnelly MSO is a good choice. I currently use the 700x38 tubeless Hutchinson Override and the 700x40 Vittoria Terreno dry.
Quoted: 3015 Post(s)
Liked 3,804 Times
What I wonder is how Compass tires compare to the other half dozen or so boutique re-branded Panaracer tires currently being sold. I'd assume most of them or about the same if not identical. Comparing weights probably gives a good idea of what casing was used.
Bikes: Yes
Quoted: 301 Post(s)
Liked 15 Times
I would much rather have a 4000 s2 in 32mm than the compass tire tested. The 4000 rolls with far less resistance and is far better than Compass tires for resisting punctures. Compass tires are essentially old tech compared to the 4000 s2. S2 is a much better compound. I have tried compass tires and was completely unimpressed. Better tires are available for ess money. For awhile the compass tires were the only offering in the bigger tire for touring but in the last couple years they have been outclassed.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,841 Times
Do these tire widths and terrain generalizations on the tires discussed - also apply to their tubulars???
I run:
Schwalbe 30mm (no knobs) for reasonably maintained, hardpack off-road;
32/33mm (with knobs) for lesser maintained off-road or anything off-road with twisty descent.
A mountain bike (clinchers) for anything tougher, choosing either rigid or front suspension, depending.
edit: I'm in the camp that says these rolling resistance figures that everyone worships are nebulous at best, misunderstood by many. Fine for laboratory analysis, mostly useless on the road (unless you are racing at a highly competitive level).
I run:
Liked 2,568 Times
Panaracer Pari-Motos tick all the boxes without extreme prices, so I am pretty content on the 650B front.
I was interested in the "Fairweather for Traveler" 700C tires at first, but their prices keep inching up toward Compass's.
I scored a good deal on a pair of Compass Naches Pass tires last fall -- gonna try those on my 26" bike soon. If I get addicted to those, I may have to buy a few extras as there doesn't seem to be much like them for that wheel size.
FWIW I ran Fairweather Travelers pretty much all of last year. Nice tires, and they are clearly a step up from Panaracer Paselas. Very smooth ride. Surprisingly good off road. I got some Gravel Kings recently. I'm kinda thinking they're the same tire. We shall see. They don't come in gum wall like the Compass and Fairweather tires though.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I have 2 sets of Bon Jon Pass tires that I really like.
Commence to jigglin’ huh?!?!
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
While the Compass tires are made by Panaracer, they are not re-branded Panaracer tires. The design is from Compass, unique to their tires. Panaracer is the contractor who makes them for Compass.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
I love the ride and performance of my 28 & 32mm Compass tires, and recently reached 3000 miles on my first pair! (with only one flat) I have no reason to try any others, and at that mileage, not even cost is a consideration. YMMV... I'm a lightweight and always default to the clean part of the travel lane.
I have not tried their "extra lights" as the standard casing is plenty fast (and light) enough for me.
That is quite an assumption.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I have the Compass Rat Trap Pass (2.3") tires on one bike, and I must admit they feel slow. It is really hard to get over that "oh these tires feel so slow!" feeling. I know, I know, according to tests they are no slower than narrower tires. But they sure feel slow.
Dynamo hubs are the same; if you turn the axle with your fingers, you feel a lot of resistance. If you put them on your bike and ride, you feel this vibration. When you feel these things, you conclude this thing you're feeling must be slowing you down. Tests show that it doesn't slow you down much at all; but it's very hard to believe it.
www.rhmsaddles.com.
www.rhmsaddles.com.
