Beautiful Campagnolo NOS Rims - Please Diagnose Potential Problem
Quoted: 18 Post(s)
Liked 58 Times
The accompanying photo tells the story. Beautiful Campy NOS Delta Strada XL Chromium rim...not so easy to find in clincher style. I am well-informed, but not an expert. Please diagnose the gap...does it present a danger or any other problem? It looks like there's a solid weld holding this rim together; moreover, I understand that spoke tension holds the rim together once a wheel is built. However, as you can see, the rim side walls do not connect...hopefully from the photo you can see that a piece of paper or other similar object could slide into the gap.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Weight weenies used to have us pull the connecting pins out of rims to make them lighter.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,928 Times
I had a pair of those once, laced to me Sherrif hubs. another guy at work tacoed his rear wheel Delta wheel. I took mine apart and traded them to another guy inthe shop for some Mavic tubular rims. they were nice rims and built up I just didn't want any unwanted mechanical issues. provided you don't lace them radially (which Campi did not recomend at the time) you should be OK
Sugar "Kane" Kowalczyk
Bikes: Ruckelshaus Randonneur, Specialized Allez (early 90's, steel), Ruckelshaus Path Bomber currently being built
Common enough with Campy rims. If it's a 36 hole rim, it'll pull together once laced and tensioned. 32 hole will do the same, to a lesser extent.
Quoted: 3464 Post(s)
Liked 2,831 Times
I think I would make some hardwood blocks, drive a nail through the two adjacent spoke holes and clamp it in a vice before building it up.
Agree with miamijim... it is already sleeved and once built nothing it will happen. Have even raced with rims like yours back in the day. Good luck.
ps: have you tried to join it together a little bit more? , if are 36 spokes i have a Brand new pair like those ones, mines are omega strada blah blach. PM if you want them.
