Why does my fork feel like garbage when a wheel is in it??
Old 08-26-15, 10:14 PM
eicca
Professional Noob
eicca's Avatar
Bikes: Frankenbike III (Cannondale Jekyll Carbon Team)
I scored a 2004 Boxxer Race 180mm dual-crown for $20. It's beautifully smooth... Until I put a wheel in the dropouts and then it feels like crap. I don't even have to put the axle in it, I just set the wheel in the dropouts and suddenly there's stiction all through the first few inches of travel and it's nasty. What on earth could be causing that?
eicca is offline
Old 08-26-15, 10:19 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6866 Post(s)
Liked 227 Times in 185 Posts
Overhaul it and find out.
fietsbob is offline
Old 08-27-15, 04:21 AM
cny-bikeman
Mechanic/Tourist
Bikes: 2008 Novara Randonee - love it. Previous bikes:Motobecane Mirage, 1972 Moto Grand Jubilee (my fave), Jackson Rake 16, 1983 C'dale ST500.
Quoted: 477 Post(s)
+1 Guessing at possible causes is useless. You still have to check things in person, and the fork you have is irrelevant - you say nothing about the headset, what type of wheel is installed, etc.
There's no such thing as a routine repair.
Don't tell me what "should" be - either it is, it isn't, or do something about it.
If you think I'm being blunt take it as a compliment - if I thought you were too weak to handle the truth or a strong opinion I would not bother.
Please respect others by taking the time to post clearly so we can answer quickly. All lowercase and multiple typos makes for a hard read. Thanks!
cny-bikeman is offline
Old 08-27-15, 04:45 AM
reddog3
Quoted: 9 Post(s)
Sounds as if something is causing binding when the wheel is installed. First thing I'd check is locknut spacing. Too long or too short which either spreads or compresses the fork legs.
reddog3 is offline
Old 08-27-15, 04:54 AM
FBinNY
Quoted: 4346 Post(s)
+1
without a wheel the lower stanchions are free and align perfectly with the upper, so action is very smooth. With the wheel in, they are constrained and so may not align perfectly causing stiction. Check the axle width, and for anything that might be causing misalignment, and correct so that the lower stanchions are deflected as little as possible and you should see real improvement, though it may never be as nice as whn there's no wheel.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 08-27-15, 05:59 AM
reddog3
Quoted: 9 Post(s)
First off- I don't know squat about suspension forks nor do I have any experience with them. Just trying to think logically.
I realized these may be a thru axle type, so I'm not sure how one mounts a wheel without the axle. So, what happens if you clamp the axle in place without the wheel? If it's still smooth you can verify that nothing is wrong alignment wise (legs out of plane, crowns bent, fork brace bent or broken, etc). If it's the wheel itself causing the problem, measure the dropout spacing in the position it works, and duplicate this width at the wheel, whether it's locknuts or inserts. A couple thou difference will bind the fork. I'd also check DO alignment. Since it's dual crown, I'd also check crown alignment, and correct as necessary. You just gots to do your thing.
reddog3 is offline
Old 08-27-15, 08:46 AM
eicca
Professional Noob
eicca's Avatar
Ok. Thanks for all the responses. I was planning on a complete overhaul but just wondered if anyone had experience with this kind of issue and knew of a most-likely cause. I'm hoping realigning everything will do the trick because the front wheel is brand new and I don't see the fork being bent. I'll keep y'alls posted
eicca is offline
Old 08-27-15, 09:40 AM
FBinNY
So you know, it all can be on or very close to spec and still cause the issue you have. Sometimes it's actually better when the thru -axle is in place and all is tight. But a small variation between fork and hub width can cause some (acceptable) stiction, that may feel bad wrong in your hand, but be fine in the field.
I wouldn't sweat it for now, and analyze it when all is together and tight.
FB
Chain-L site
FBinNY is offline
Old 08-27-15, 09:44 AM
mconlonx
Str*t*gic *quivoc*tor
mconlonx's Avatar
Quoted: 6991 Post(s)
Liked 40 Times in 29 Posts
Chances are whoever you scored it from had the same issue?
Sounds like some kind of alignment issue.
Rebuild and replace seals and bushings.
Could be the upper and lower clamps are torqued out of alignment somehow -- with the wheel in the slider, undo the pinch bolts holding the stanchions at the upper clamps, then re-torque to spec.
When you have it completely disassembled, use a flat surface to double-check that the stanchions aren't bent.
On that same flat surface, check that the lower isn't torqued out of plane as well.
I know next to nothing. I am frequently wrong.
mconlonx is offline
Old 08-27-15, 07:09 PM
eicca
Professional Noob
eicca's Avatar
So I secured the wheel, loosened the lower crown stanchion bolts and upper crown steerer bolt, cycled the fork a bunch of times, and it's much better. It's still a little bit sticky, but also in need of an oil change. Thanks for all the help, I'm excited to have it working.
eicca is offline
Old 08-30-15, 12:52 AM
eicca
Professional Noob
eicca's Avatar
Update: I changed all the oil today and came to the realization that the Boxxer just couldn't do it anymore. So I traded it and my old dropper post for a 2009 Domain 318 which I haven't even gotten on the bike yet and I already love. Smooth as a Pike, I'll tell you that.
eicca is offline
Old 08-30-15, 07:40 AM
bradtx
Bikes: Cannondale, Trek, Raleigh, Santana
Quoted: 304 Post(s)
Take a look at this: https://www.sram.com/sites/default/f...rviceGuide.pdf
Brad
bradtx is offline
Old 08-30-15, 09:12 PM
eicca
Professional Noob
eicca's Avatar
See my previous post
eicca is offline
Old 09-08-15, 03:46 PM
eicca
Professional Noob
eicca's Avatar
So thread revival, interestingly my friend's Totem Coil and Domain Single Crown both do the same thing. Buttery when empty but choppy with the wheel. I wonder if there's something related to the fact that it's a coil fork causing this behavior
eicca is offline
Old 09-08-15, 10:33 PM
FBinNY
No, it's related to the overall precision of the parts involved. Smooth action depends on excellent alignment of the upper and lower struts. Unloaded that's not an issue, since each strut can float to the aligned condition. But when you tie the ends together at the bottom using the axle or QR, that can pull one or both off the aligned condition, and cause binding.
If nothing else, it should make you appreciate the skill involved in making trombones.
FB
Chain-L site
FBinNY is offline
PeregrineA1
Classic & Vintage
21
02-26-17 06:08 PM
mwl001
Hybrid Bicycles
0
06-06-14 02:48 PM
greaterbrown
Northeast
0
04-12-13 05:28 PM
sbskates
Training & Nutrition
0
01-29-10 10:54 PM
sillygirl
Road Cycling
11
04-19-05 06:28 PM
