Battery Evaluation ideas
Old 06-24-18, 09:12 AM
Rickcol
I recently bought a used bike with a 36v 10AH battery. I suspect the battery is bad. Here is why;
- despite charging, never get more than 3 out of 5 battery statuslights.
- no load bat voltage before ride = 36.9v
. After easy ride = 36.1v
- riding under full power, lose power until I start cracking again
advise appreciated
Rickcol is offline
Old 06-24-18, 11:16 AM
Doc_Wui
Doc_Wui's Avatar
Quoted: 340 Post(s)
Liked 275 Times in 192 Posts
You didn't mention the type of battery, whether lead-acid, or lithium. If the latter, there are several types. On is about 38V at full charge, while the more common types would be 42V at full charge. Your charger might have its full charge voltage printed on the label.
For sure, if it's a lithium battery built with the 18650 cells, that should be 42V at full charge, Your numbers indicate a weak battery.
Any replacement will work, but getting one that fits the current mount iis the first pronlm.
Doc_Wui is offline
Old 06-24-18, 12:29 PM
Rickcol
Yes, it is lithium battery. Yukon trails sells a replacement for $339 ... so my used bike was not such a bargain after all.
Rickcol is offline
Old 06-25-18, 07:21 AM
unterhausen
Randomhead
Liked 3,694 Times in 2,516 Posts
my general prejudice is that people sell used ebikes after they find out what a battery will cost, and they need one. I'm sure that's not always the case, but there are an awful lot of poorly made lithium cells being sold
unterhausen is offline
Old 06-25-18, 11:19 AM
Nelson37
Quoted: 43 Post(s)
A used ebike battery should be considered as almost worthless.
Now, it is possible that all ten strings are only charging to 3.69V. There are other possible combinations.
HOWEVER - That number is suspiciously accurate for 9 (NINE) strings charging to 4.1V each. One dead cell is Exactly what happens when a lithium battery is left uncharged for an extended period of time, and the single cell powering the BMS system is completely discharged and becomes permanently dead.
It is often possible to replace the single cell, and/or charge it individually and slowly with a single-cell charger, and bring the battery back to life. Careful monitoring is required, and replacement is best safety option.
Next question on replacement pack is attachment mechanism for the replacement pack and whether or not additional connections and/or an internal controller are also involved. 36V 10 amp is a pretty low-range pack.
Nelson37 is offline
Old 07-28-18, 10:08 PM
speedy25
Bikes: Specialized, Trek, Diamondback, Schwinn, Peugeot
Quoted: 160 Post(s)
Liked 53 Times in 43 Posts
I do have the Grinspector to actually measure battery output under a load. I'm currently working on making various adapters to fit a bunch of different batteries.
A graphed output of power over time can confirm if a battery is anywhere near what its claimed rating is.
-SP
speedy25 is offline
Old 08-06-18, 11:59 AM
nfmisso
Nigel
nfmisso's Avatar
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times in 6 Posts
take look on Amazon and eBay for a replacement 36V 10Ah ebike battery, they are currently in the mid $200s.
nfmisso is offline
Old 08-06-18, 06:44 PM
Khb
Bikes: Stromer ST-1; Gary Fisher SAAB edition; Dahon Speed D7; Motobecane Grand Touring 1972
Quoted: 38 Post(s)
Anyone used a service to rebuild? https://ebikemarketplace.com/blogs/news for example, purports to rebuild.
Khb is offline
coolio
Electric Bikes
8
07-02-16 08:56 AM
rapattack
Electric Bikes
10
03-03-16 04:57 AM
Jimbo397
Electric Bikes
6
08-03-12 11:45 AM
bobn
1
11-23-11 02:47 PM
John Phoenix
Electric Bikes
1
11-13-10 12:46 AM
