Light Bicycle Wheels
Old 07-17-19, 04:47 PM
  #701
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
Originally Posted by Sy Reene
So.. dumb question time.. why is there such a thing as a J-bend spoke? What purpose do they serve?
https://www.artscyclery.com/ask-a-me...t-pull-spokes/
Marcus_Ti is offline
Old 07-17-19, 05:00 PM
  #702
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4736 Post(s)
Liked 1,532 Times in 1,003 Posts
Thanks! Informative article. As relates to the LB, handmade and bladed option spokes available, it seems (?) that there would be no advantage to going with JBend, right? At least insofar if they could ship a few extra spare spokes for the correct lengths needed.
Sy Reene is offline
Old 07-17-19, 06:01 PM
  #703
Kimmo
Kimmo's Avatar
Quoted: 1529 Post(s)
Liked 718 Times in 510 Posts
Yeah, that page makes some reasonable points... although I'd say that whole thing about tuning the wheel's compliance by varying the spoke pattern is a bunch of wank. Like tying and soldering, it makes no difference - a spoke is either radial or tangential; very little tangent is required to adequately transmit drive and braking (for discs only of course; tangential spokes on a rim braked front do nothing except allow a pair of crossed spokes to slightly share load).
As for round straight-pull spokes, they shouldn't even be a thing. Also, almost all proprietary steel straight-pull spokes can be replaced with standard ones with little if any disadvantage beyond the ends of the bladed sections being in different places.
It puts more strain on the spoke heads, so very occasionally one will fail there, but I'd put that down to manufacturing flaws.
Folks can argue about whether it makes much difference to durability, but there's no disputing that straight-pull hubs are much sleeker and more aero, and thus, most importantly, sexier.
Kimmo is offline
Old 07-17-19, 08:26 PM
  #704
WhyFi
WhyFi's Avatar
Quoted: 20810 Post(s)
Much easier to make hubs/flanges for J-bend than straight-pull.
WhyFi is offline
Old 07-19-19, 10:22 AM
  #705
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Mack hubs arrived from Poland in three weeks.
Rims were ordered from LB almost five weeks ago and have not arrived. I'm not worried or upset. Just want to get this done and do some riding.
Thinking out loud, I guess I should order some Black Prince pads too.
-Tim-
TimothyH is offline
Old 07-19-19, 10:26 AM
  #706
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
-Tim-
Have they been shipped?
noodle soup is offline
Old 07-19-19, 11:07 AM
  #707
TimothyH
- Soli Deo Gloria -
Shipped 7/3.
Edit: I just checked tracking information. There had been zero updates since 7/4 but lots of activity since yesterday, the 18th when the rims apparently passed customs at JFK airport in New York City. Bottom line, the rims are at my local post office today.
-Tim-
TimothyH is offline
Old 07-19-19, 12:54 PM
  #708
TimothyH
- Soli Deo Gloria -
Stealth graphics were ordered. This looks like white.
Do these look like stealth or white to you guys?
TimothyH is offline
Old 07-19-19, 01:11 PM
  #709
WhyFi
WhyFi's Avatar
It looks like I'd be getting busy with some peeling.
WhyFi is offline
Old 07-19-19, 02:34 PM
  #710
63rickert
Quoted: 1090 Post(s)
Liked 332 Times in 248 Posts
You don't want to be riding on sidewalls. At all. Don't do it.
You are doing beta testing. Wide rims changes everything and absolutely no one knows all the answers, or even all the questions. Until ISO speaks on the issue (which could be a while) the only authoritative guide is ETRTO. They say no more than 17mm internal width on the rim for a 25mm tire. 20mm rims don't work for them until the tire is 32mm. ETRTO is very conservative. If you and the rim and tire mfrs follows their guidance there will never ever be a problem. Riding outside their guidance you get what you get and you can tell us how it worked.
If cornering hard is what you do it makes little sense to use lower pressure in front. Downhill cornering all the weight goes to front. Cornering of any type involves deceleration and will transfer weight to front. Front/rear pressure differential is for getting maximum wear out of your tires.
63rickert is offline
Old 07-19-19, 02:54 PM
  #711
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
You may want to read the following linked article.. especially near the end above the rim/tire compatibility charts. Evidently ETRTO now can allow a 25mm tire on up to a 21mm internal width rim (tubeless hooked rim), but they now tie what's possible to maximum inflation pressures.
https://engineerstalk.mavic.com/en/t...ght-rim-width/
Sy Reene is offline
Old 07-19-19, 03:08 PM
  #712
TimothyH
- Soli Deo Gloria -
Well, speaking with Paul at Light Bicycle customer service, apparently what is seen in the photo above is their idea of stealth. I decided not to get into a discussion of the semantics of the word stealth, if only for the sake of peace, but they don't look to stealthy to me. Maybe I was thinking of "Ghost." I did suggest that they drop the term stealth and just say that it is gray.
To his credit, Paul stated that he had personally applied and peeled the graphics himself and that they come off reasonably easy. He also offered a set of decals in another color for no charge.
So yeah, had I know I would have ordered with no graphics. I'm not sure I want to peel them, at least not yet. I can always do that later.
Advertised weight is 435 g +/- 15 g.
24 hole...
20 hole...
-Tim-
TimothyH is offline
Old 07-19-19, 03:31 PM
  #713
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
-Tim-
Hmmm... the ease of removal seems a bit contradictory to what's said on their ordering page?
"Road rims use super light waterslide decals (glossy black). The decal is very thin and applied under a clearcoat so they are non-removeable."
Sy Reene is offline
Old 07-19-19, 03:52 PM
  #714
63rickert
Thank you. I did want to read that. My information was coming from a post by Jan Heine just two weeks old and had presumed that since he is making tires he'd be using current info. In any event the discrepancy here points out how fluid the situation is and how fast things are changing. ETRTO is a stopgap, really wish ISO would speak.
Different width rims do change how the tread faces the pavement. Figuring out all the variables is complex. Complex for the manufacturers and really hard for those who use the product.
Old 07-19-19, 03:56 PM
  #715
63rickert
Hmm, re-read the Mavic engineerstalk posting and saw it is dated September 2015. The chart Heine reproduced is straight from ETRTO and in identical format to the chart from Mavic. Frankly, I am puzzled.
Old 07-19-19, 06:54 PM
  #716
TimothyH
- Soli Deo Gloria -
Thanks. I didn't notice that.
Something is wrong with that claim because these were not waterslide decals under clearcoat. I peeled them off about an hour ago. They are simple stickers and came off very easily.
-Tim-
TimothyH is offline
Old 07-19-19, 07:14 PM
  #717
TimothyH
- Soli Deo Gloria -
Most of you guys are using Black Prince pads?
My concern is wet weather performance. Are the Black Prince pads good in the wet? What about the Yellow King?
I'm used to Koolstop salmon on alloy wheels and so have some pretty high expectations about how a wet weather pad should work.
I'm asking out of ignorance. This is my first set of carbon, rim brake wheels.
-Tim-
TimothyH is offline
Old 07-19-19, 07:29 PM
  #718
Marcus_Ti
Marcus_Ti's Avatar
-Tim-
Probably just plain outdated info. Products and processes change.
Granted was kind of punk to mess it up, especially with global shipping being slow. Least they tried to make it right.
Old 07-21-19, 12:31 AM
  #719
smashndash
Quoted: 850 Post(s)
Liked 344 Times in 247 Posts
I admit I sort of knew these were murky waters when I bought these wheels - and that’s what intrigued me the most. I won’t starve if I end up having to sell these wheels, thankfully, so if these wheels turn out to be unviable, I’m ok with that.
I assume you saw that updated chart from mavic about rim widths vs tire widths. 28c is approved for upto 25mm rims. The ratio of tire to rim is close enough for me that I’m not worried about inflation - especially since I don’t weigh very much.
What is confusing, though, is that it’s unclear what a 25 or 28c tire is supposed to measure to. GP4k, GP5k, Sworks Turbo and P zero tires all measure differently on the same rim despite having the same or similar nominal widths. For example, I would not run a 25c GP5000 on these rims because they are quite narrow. A 28c GP5000 is closer to a 25c P zero. Regardless, I am not worried about inflation issues for the time being.
I would certainly be riding on sidewall if I put a 25c P Zero on a 21mm rim - an approved ETRTO combination. I don’t believe that a 2mm increase in rim width is to blame for 3-5mm of sidewall use on either side of the rim. However, the jump from 17mm to 23mm is enough that I can feel the sidewall a lot earlier (or at least I think I can), which concerns me. This entire issue has not been even remotely addressed by the bike industry. I’ve never even seen tread width addressed as a measurement. The ETRTO probably has not standardized tread width - an obviously important element of tire construction. In the meantime, it may be wise to avoid tires with overly narrow treads like the P Zero. This is an utter failure on the part of the bike industry, in my opinion, because mountain bikes went through the exact same issues and yet the road tire industry refused to learn from them.
I run my front tire low for extra traction on rough descents. Not really for equal wear.
I’ll shut up for the meantime about this whole sidewall issue. I think I’ve blabbed enough about it and people get the point. Let this thread resume LB related queries.
smashndash is offline
Old 07-22-19, 06:00 AM
  #720
TimothyH
- Soli Deo Gloria -
What direction should the grooves in the brake track face?
For those who have grooved graphene brake track on wheels built by Light Bicycle, which way do they face, open end or closed end toward the direction of rotation?
I have the rims but don't know which side the freehub should be on when building them.
-Tim-
TimothyH is offline
Old 07-22-19, 07:20 AM
  #721
yunusemreboz
Bikes: Sedona Black Code 9
Liked 2 Times in 1 Post
This is the first time I've seen these.
yunusemreboz is offline
Old 07-22-19, 07:31 AM
  #722
Rides4Beer
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times in 414 Posts
-Tim-
I'll get a pic this evening, I want to say closed end toward the front.
And those are definitely not the waterslide graphics, those are just regular stickers.
Rides4Beer is offline
Old 07-22-19, 10:06 AM
  #723
superdex
staring at the mountains
superdex's Avatar
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times in 112 Posts
Pretty disappointed.
I know you already peeled, but I'm playing catch up. Those look like crap. Like a new logo design --or an old one, and those are definitely stickers. Maybe the graphene-track rims don't get the same clear-coat decal treatment, or you got a beta logo set. shrug. I'd be peeling away too. Oh, and that's definitely white. Can't wait to see them in action--
superdex is offline
Old 07-23-19, 06:16 AM
  #724
TimothyH
- Soli Deo Gloria -
Light Bicycle emailed the graphic below.
As suspected, the grooves point in the direction of travel.
TimothyH is offline
Old 07-23-19, 10:37 AM
  #725
saverin
Quoted: 14 Post(s)
Liked 4 Times in 2 Posts
Has anyone tested the performance of the grooved brake track? wondering if it provides any improvement in performance over the std 'high temp' brake track.
saverin is offline
