Drywall Anchors for bike rack
Old 04-23-19, 02:15 PM
rgr555
Quoted: 94 Post(s)
Hi I'm wondering how many of you are using dry wall anchors for your bike rack. Since the stud is off-center I will need dry wall anchors.
The ones I purchased were recommended https://smile.amazon.com/ITW-Brands-...ct_top?ie=UTF8
For this bike rack: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
The zinc screws are rated for 50lbs per job. The bike is no more than 25lbs. I'm just paranoid it will rip out of my walls or fall. There are mixed reviews, some people say "don't hang on dry wall", others say "get good dry wall anchors and it'll be fine". What do you guys think?
rgr555 is offline
Old 04-23-19, 02:32 PM
Ogsarg
Bikes: 2009 Specialized Roubaix, early 90's Giant Iguana
Quoted: 256 Post(s)
Liked 43 Times in 27 Posts
Those will probably work fine but if it were me, I'd cut a piece of 1/4 or 1/2" plywood that I can screw into the studs and then put the racks on that.
Ogsarg is online now
Old 04-23-19, 02:41 PM
KLiNCK
Optically Corrected
KLiNCK's Avatar
Bikes: 2012 Specialized Sirrus , 2012 Specialized Roubaix Comp
Quoted: 92 Post(s)
Liked 18 Times in 10 Posts
I mounted a similar bicycle rack/hanger to drywall using the heavy-duty "expanding" style of anchor. Works great - no problems.
KLiNCK is offline
Old 04-23-19, 02:56 PM
MSchott
Bikes: 2017 Specialized Roubaix Sport SL4
Quoted: 59 Post(s)
Liked 14 Times in 10 Posts
Second this. It's just safer and more secure. Why take chances with a multi thousand dollar bicycle? My bike gets hung by the wheels from large padded hooks screwed into the ceiling studs of my garage.
MSchott is offline
Old 04-23-19, 02:59 PM
MagicHour
MagicHour's Avatar
Quoted: 74 Post(s)
If I was hanging a bike rack on drywall I'd probably go with toggle bolts - but I tend to overdo things... or the board/studs across approach above.
MagicHour is offline
Old 04-23-19, 04:01 PM
Maelochs
Maelochs's Avatar
Bikes: 2015 Workswell 066, 2014 Dawes Sheila, 1983 Cannondale 500, 1984 Raleigh Olympian, 2007 Cannondale Rize 4, 2017 Fuji Sportif 1 LE
Quoted: 5453 Post(s)
Liked 118 Times in 79 Posts
If you were bent on doing a direct-to-wall mount, posts #3 and #5 are the way to go. If you really want security, mount a piece of plywood to the studs.
Maelochs is offline
Old 04-23-19, 04:09 PM
bobwysiwyg
bobwysiwyg's Avatar
Quoted: 673 Post(s)
Liked 34 Times in 27 Posts
Third this. I do tend to over engineer though.
"Skepticism is the first step in critical thinking." -- Me
bobwysiwyg is offline
Old 04-23-19, 04:34 PM
jimincalif
Bikes: '96 Trek 850, '08 Specialized Roubaix Comp, '18 Niner RLT RDO
Quoted: 499 Post(s)
Liked 35 Times in 18 Posts
Do you live in earthquake country? Here in SoCal I try to consider how things will behave when bouncing. I'd go with the other suggestions about mounting wood to the studs. I did this with the hooks in my garage that needed to land between two ceiling joists.
jimincalif is online now
Old 04-23-19, 04:42 PM
rgr555
Quoted: 94 Post(s)
Thanks for the tips.
Going to get two Ez Anchor Toggle Bolts for 100lbs which actually provide up to 180lbs.
More than enough for 25lb.
This is for an entryway in a condo (minimalist) so dry wall anchor only way to go.
If anyone has gone this route and still had the bike rack fail please let me know! I just don't understand the risk of a 25lb bike on a mount that can hang 180lb on dry wall.
rgr555 is offline
Old 04-23-19, 09:02 PM
woodcraft
woodcraft's Avatar
Quoted: 1038 Post(s)
Liked 43 Times in 25 Posts
Drywall anchors pretty much suck, 'tho they have their place.
If you screw a nice 1x board across the wall, the rack can go where it needs to,
and it will be easier to patch the holes if you remove it later.
woodcraft is offline
Old 04-24-19, 01:17 AM
C9H13N
Bikes: Cervelo S1 2009
Quoted: 8 Post(s)
You're going to feel really stupid when someone bumps your hanging bike and rips the anchors through the drywall. Just because they are rated for more than the bike weight doesn't mean they are appropriate.
C9H13N is offline
Old 04-24-19, 01:41 AM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 345 Post(s)
Liked 11 Times in 5 Posts
Originally Posted by rgr555 View Post
https://youtu.be/lHb-Tcvkn7M?t=945
While I'm not a big fan of drywall anchors I do use them quite a lot for work. This video is very informative, thanks for sharing it.
hairnet is offline
Old 04-24-19, 04:58 AM
jpescatore
Bikes: Trek Domane SL6 Disc, Trek 520
Quoted: 141 Post(s)
Liked 10 Times in 10 Posts
Ditto - just run a cheap 1x2 or 2x4 horizontally across the garage wall where you want to hang the bikes, screwed in at the studs, and put the hangers wherever you like along the board.
jpescatore is offline
Likes For jpescatore:
Old 04-24-19, 05:17 AM
ridelikeaturtle
ridelikeaturtle's Avatar
Bikes: Bianchi Ti Megatube, M Alloy Pro, Sprint 76; Amp Research B4; Colnago Crystal; Klein Pulse; Litespeed Catalyst, Fondriest Squadra Corse
Quoted: 310 Post(s)
Liked 46 Times in 33 Posts
Another vote for this, it's what we do when we hang kitchen presses ("cabinets" for Americans), and you can literally swing off them if you like. Make whatever holes are necessary (poking holes with a screwdriver is sufficient for this) to find the studs; then plaster, sand, and paint afterwards if you're doing this where it'll be seen and needs to be "nice" when finished.
ridelikeaturtle is offline
Old 04-24-19, 06:13 AM
WhyFi
WhyFi's Avatar
Quoted: 9078 Post(s)
Liked 233 Times in 142 Posts
It's not the weight that's a problem, so much as the non-static nature - you're going to be constantly hanging, removing and jostling the bike/rack and each of these micro-aggravations are going to dig the anchors further in to what is essentially a paper-lined sedimentary substance. It'll be fine for a year and it might be fine for three years, but there's not much of an excuse for not doing it right when all it takes is a plywood board, some screws and a drill (and maybe a paint roller if you're concerned about the appearance).
WhyFi is offline
Old 04-24-19, 06:35 AM
Maelochs
Maelochs's Avatar
This is sort of what I was thinking---overbuild for the worst possible scenario, not the norm.
I wouldn't have said "stupid," but I know when I hung racks for my bikes I made them tough enough that i could do pull-ups in them---if I didn't weigh so much--because if I slipped or tripped while hanging a bike and ended up pulling down several .... I would feel pretty stupid.
Maelochs is offline
Old 04-24-19, 07:03 AM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 3774 Post(s)
Liked 290 Times in 202 Posts
You could use the best designed wall anchor in the world, and still be greatly limited by the fact that the anchor is inserted into what is essentially compressed chalk between two sheets of paper. Sure, the anchor is rated to whatever weight it claims, but 1/2" sheetrock on 16" centers will fail (in the best case scenario, with a big anchor) around 50lbs.
Drywall anchors are great for things like picture frames and mirrors. I wouldn't hang a coat rack on drywall anchors, much less a bicycle.
DrIsotope is offline
Old 04-24-19, 07:15 AM
rumrunn6
rumrunn6's Avatar
Quoted: 3081 Post(s)
Liked 140 Times in 112 Posts
will the back wheel be off the ground?
rumrunn6 is offline
Old 04-24-19, 09:03 AM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 600 Post(s)
Liked 24 Times in 19 Posts
Ugh - just don't.
Face mount a piece of wood across the span between the studs and just mount your rack to the wood.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Old 04-24-19, 09:12 AM
jimincalif
Quoted: 499 Post(s)
Quite right. Think curtain rods, towel racks and TP holders. None are terribly heavy but they frequently end up loose because of the repeated pulling on them over time.
MagicHour
MagicHour's Avatar
Quoted: 74 Post(s)
That and also wear and tear simply from constant cycles of hanging/removing of bike.
Old 04-24-19, 11:28 AM
Zaskar
Quoted: 188 Post(s)
Liked 6 Times in 6 Posts
I'll um... eleventh what the others said - mount a 1x4 to the studs, put the bike hook(s) wherever you want on that board.
Zaskar is offline
Old 04-24-19, 12:01 PM
Riveting
Bikes: '13 Trek Madone 2.3, '13 Diamondback Hybrid Commuter, '17 Spec Roubaix Di2, '17 Spec Camber 29'er
Quoted: 173 Post(s)
Liked 27 Times in 19 Posts
+1 for comment #2
Riveting is offline
Old 04-24-19, 05:10 PM
rgr555
Quoted: 94 Post(s)
With all the advice here it seems like dry wall anchors, even toggle ones which can hold 200+ pounds, may be too risky and create wear over time on the dry wall.
So I may just angle the bike on a tilt while hung on the stud. The stud 8.5 inches from the wall, and half my bike handle is 10 inches, so there is not enough room unless I tilt the bike. Do you guys know if I can angle the bike on a tilt while hanging it vertically on this specific bike rack without damaging the wheel? (Like tilting your head to the right 10 degrees.)
http://www.racorstoragesolutions.com...-1r-01/288/302
rgr555 is offline
Old 04-24-19, 05:44 PM
VegasTriker
Quoted: 310 Post(s)
Liked 16 Times in 12 Posts
I have a trike that hangs from the garage ceiling over the front of my car. There is no way I would rely on any wall anchor to safely keep the trike from falling on the car. A cheap solution is to go to a home center like Lowes and buy dog eared fence boards for $1.87 (Item # 54224 Model # 146973) . It's 1" X 6" X 6'. That's plenty long enough to anchor it to two adjacent studs with a couple of deck screws. It will hold a bike hoist or the usual bike hooks.
VegasTriker is offline
