Go Back  Bike Forums > Bike Forums > Framebuilders
50mm Butt Seat Tube
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
50mm Butt Seat Tube
Old 06-14-19, 06:35 PM
TiHabanero
Quoted: 700 Post(s)
Liked 65 Times in 43 Posts
50mm Butt Seat Tube
Any potential issues having a 50mm butt at the seat post end of a seat tube?
TiHabanero is offline
Old 06-14-19, 07:43 PM
dsaul
Quoted: 251 Post(s)
Liked 40 Times in 30 Posts
Only 50mm of the seat post is supported and the lower part of your top tube/seat tube joint will be on the thin part of the tube. How big of an issue will depend on how far the seat post extends out of the frame. The potential for cracking at the ST/TT joint is probably minimized by the fact that this is a lugged frame. There still could be some seat post creaking issues with the minimal amount of support and the end of the post moving around in the butted area when the post flexes.
dsaul is offline
Old 06-14-19, 10:58 PM
unterhausen
Randomhead
Liked 44 Times in 39 Posts
can you shorten the BB end? What tube is it, Spirit?
unterhausen is offline
Old 06-15-19, 08:34 AM
unterhausen
Randomhead
Columbus makes a spirit seat tube with a 70mm top butt, so they seem to think that is enough. I'm pretty sure they expect you to cut off the bottom. I suspect that 50mm will be enough without issues. I am not sure that DB seat tubes are worth it, the top butt certainly adds a little more uncertainty to extracting a stuck seat post.
One thing that I should have done on my SFL frame that had a stuck seatpost is to cut off the seat post to the length of the top butt. Seat posts nowadays are really long, and there is no need for that. BITD, I think they usually had 50mm minimum insertion, but nobody inserted them much more than that.
Old 06-15-19, 04:05 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1780 Post(s)
Liked 64 Times in 49 Posts
Trek has sold thousands of bikers with a significant diameter reduction at the top of the ST. I forget how much post it actually clamped but it's no more then the width of a hand. Being a small guy I have a lot of post in my frames even after chopping off a couple/three inches. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 06-19-19, 06:58 PM
TiHabanero
Quoted: 700 Post(s)
The tubing will be Columbus SL. Seat post will be up out of the frame about 6 inches and will end inside the frame near the end of the butt. I think it will work OK as I am using a lug at the joint.
