Pedals Turn But Rear Wheel Doesn't
I occasionally will ride my oldest bike. It's a Raleigh hybrid and I suppose that I keep it around for sentimental reasons. The other day while taking it out, I immediately began the descent of my sloped driveway while shifting and although I was able to turn the pedals (which of course turned the cassette in the rear), my rear wheel wasn't being "driven" by my work. I might have resolved it by a momentary pedaling backwards, but to be honest, I'm not 100% sure. Right or wrong, after it began working again, I did take it out for a 10 mile ride and experienced ZERO problems.
For those who have had this happen before, is it likely to recur?
The rear cassette has eight cogs, and from the YouTube video that I watched, the problem was probably pawls that momentarily slipped/slid over the ratchet perhaps due to accumulated gunk in the grease over the years. What would you expect your LBS to charge you to clean and regrease this wheel if I brought them the whole bike?
On another note, when do you decide it's time to get rid of your older bikes?
It probably is the pawl. Remove the freewheel using the appropriate tool (Park’s Tool is pretty good about tool pictures and applications). Soak in mineral spirits or simple green, either blow out or spin and let dry. Then use a light oil to lubricate it back up inside.
As to how long to keep a bike? There are plenty of folks here who have 50 year old + bikes. My daily commuter is 30 years old. Some people have the money to trade a bike every couple years. Me personally, if I like the bike can keep it going indefinitely.
Quoted: 1002 Post(s)
Liked 237 Times
The hub pawls sound like the problem as you stated.
Inside the rear hub there are pieces that engage the wheel when the chain is pulling the cassette forward. But they disengage when you're not pedaling, so the wheel can still spin without the chain moving.
The question is why?
Are they just gunked up with old grease? Is the hub broken and needs to be replaced or repaired?
Even if the hub had the be replaced completely this shouldn't be a terrible expensive repair. And the shop should be able to give you a reasonable estimate right away. But of course they could take it apart and realize that not only was the hub broken but so was something else, which would add to the cost.
Still....this should not be terribly expensive.
I am potato.
Quoted: 1764 Post(s)
Liked 1,578 Times
Tub of axle grease & a good cleaning. Super easy if cartridge bearings & the freehub slides right off.
Otherwise if freewheel &/or cup/cone you might as well pull the axle & service the cup/cones axle bearings, pawls, etc, all in one shot & be done with it for the next few years. Any shop ought to equipped to do this with minimal turn around time if you don't have the tools. And buying tools for a one time job doesn't make a lot of sense.
I say this because if the pawls are sticky, theres no telling how old dried, or congealed the grease is. Congealed grease would indicate a long time since anything back there was serviced.
Quoted: 521 Post(s)
Liked 227 Times
If it is a really old bike it has a freewheel. Newer bikes come with a cassette. You can easily tell the difference because there is no lock ring on a freewheel but there is on a cassette. This video shows the cassette lock ring at around 30 seconds into the video
. If you have a cassette, then you have a freehub beneath the cassette and that contains the pawls. I have old bikes with both and there is no way I would throw away a bike because I needed to replace either a freewheel or freehub.
No bike shop in their right mind disassembles a freewheel or freehub to access the pawls because there are a skillion small bearings inside and they fall out when it is opened. You can buy an old style freewheel on eBay for between $10 and $20 for an 11-28 or 11-34 in 7 or 8 speeds. Just make sure it is really a freewheel and not a cassette as many sellers don't seem to know the difference. Ditto for the freehub which should be under $20. The only problem is having the tool to remove either the freewheel or cassette and freehub. Freewheels are a particular problem as there are different tools for different brands of freewheel.
52psi
Quoted: 790 Post(s)
Liked 800 Times
Age doesn't really play into the decision-making process.
Liked 2,910 Times
Half way there
Quoted: 985 Post(s)
Liked 879 Times
Just a thought: Do you think you might have been in a really low gear when you started your driveway descent? If so, you could have had the sensation of pedaling without drive when it really was that your cadence couldn't catch up.
Quoted: 1572 Post(s)
Liked 642 Times
8-speed so probably a free hub bike. Also, it's been idle for awhile.
Quick and dirty:
1. Take off your rear wheel. set it horizontally across a trash can with the cassette facing up.
2. Spin the cassette with your fingers. Notice what rotates and what doesn't.
3. Dribble some WD40 into the crack between the moving part and the stationary part of the free hub body. Give it time to soak in.
4. When the cassette spins freely in one direction and immediately locks up when spun in the opposite direction, you're good.
Quick and dirty:
The problem is, with age the grease hardens up and eventually prevents the pawls from moving freely. Even with a freehub, sometimes you can squirt light oil into the works without disassembling it and get it working properly again.
Thanks for all of the replies guys. And to Moe, I thought that at first but when the driveway leveled out and my coasting had almost stopped entirely I was still pedaling with no affect. It was messing with my mind for a moment like how could this be happening?!?!
