Go Back  Bike Forums > Bike Forums > Framebuilders
aluminum forks
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
aluminum forks
Old 06-20-19, 09:43 AM
edscott.
edscott.'s Avatar
Quoted: 28 Post(s)
Liked 5 Times in 4 Posts
aluminum forks
Steel forks are slightly curved forward for a reason, the resilience of steel and the curve format provide a certain amount of flexibility and shock absorption. Aluminum does not flex, it rather will fatigue and eventually break.
So is there any good reason to use an aluminum fork, besides the low cost?
edscott. is offline
Old 06-20-19, 10:17 AM
Nessism
Nessism's Avatar
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times in 337 Posts
Too many assumptions. The curve in a fork doesn't serve much if any functional reason other than to create offset/rake; crowns are typically designed so the fork legs exit parallel to the steerer, so the rake/offset is created by curving the blades. A straight leg fork and a curved fork using the same fork blades and offset will perform virtually if not identical.
Aluminum as a material is more flexible than steel by a 3X factor per unit of material. Early aluminum frames were quite flexy as were aluminum forks; forks made by Kinesis and SR Sakae were quite soft and absorbent, to the point that racers didn't like them. As time went on aluminum frames were beefed up, to an extreme in many cases, as a hedge against breaking. Aluminum forks stayed in the market but there wasn't a ton of advanced design refinement done, partly because carbon became all the rage.
So to answer the question, there is nothing wrong per say with an aluminum fork but as always, the devil's in the details. The fork can be designed to be either stiff or soft, there is no definitive narrative when it comes to such things.
Nessism is offline
Old 06-20-19, 03:01 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
My screwed and glued AlAn All Aluminum Fork had raked blades , it was the lower head lug that cracked first ..
fietsbob is offline
Kimmo
Framebuilders
22
01-14-14 03:15 AM
NcA13
Singlespeed & Fixed Gear
20
10-16-12 02:28 PM
cycleheimer
Bicycle Mechanics
5
11-01-10 08:45 PM
sabazel
11
10-03-10 12:34 PM
squirtdad
Classic & Vintage
9
07-28-10 10:05 AM
