Torque Specs for SR BB and Crank arms?
Bikes: 2011 Trek Rumblefish, 1993 Trek 5500, 2013 Salsa El Mariachi, 1982 Trek 412
Does anyone have instructions for torque specs or installation of an old Sakae Ringyo bb and crank arms? What is the torque on the square taper?
In reference to my bike:
Trek 412
Trek 412
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
I don't think a lot people worried about torqueing stuff back then, I know I seldom saw a torque in the late '80s when I worked in a shop. I think the whole idea of torque specs on everything grew out of liability issues and replacement/warranty cost the last few years as more and more stuff is made from Ti and carbon fiber. I was always taught that if your using the correct wrench for the job once it stops moving the bolt/nut the torque is generally correct. Which is why a 6mm wrench is 8" long and 15mm is 13" long.
If your really want to torque them I think my early '90s Campi cranks call for around 25 ft lbs.
Nice looking project I guess it is coming back together?
Sugar "Kane" Kowalczyk
Also, thats what I was planning on doing, I think my campy cranks on my trek 5500 were 32ft/lbs. I was going to do something similar. I could look up the torque specs for that particular size bolt and use engineering judgement too.
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 704 Times
Back when I was working in a Schwinn shop, we always had a card stuck to the wall of recommended torque values. Every new bike was checked with a torque wrench.
Park Tools has a reference for the most common torque values: https://www.parktool.com/blog/repair-...s-and-concepts
Jeff Wills
Jeff Wills
Thanks Jeff! Looks like right around 300 in/lbs will do fine.
The Barnett's manual says that if the manufacturer's specs are not available, then follow this for both left and right: "Torque nut/bolt to 390in-lbs (32.5ft-lbs, or 65lbs@6" or 50lbs@8")."
I've usually used one of my three torque wrenches, but I've usually stopped bit short of those specs just because it "felt" right. This discretion included my one set of SR cranks. But (ironically?) it was the SR that I had to torqued down later as it had started to drift off the spline on the drive side. No bother since then. So, I'd recommend the 32 or so ft-lbs.
Vitus 979, Simplon 4 Star, Gazelle Champion Mondial, Woodrup Giro, Dawes Atlantis
Quoted: 964 Post(s)
Liked 1,628 Times
Hope this will help...
https://www.bikeforums.net/showthread...e-Torque-Specs
Remember I extracted this info for good old steel bikes - Not for composite or Weird graph/plastic components...
Or especially " hydride Al2CuHx " ...
