Inner tube concerns
Quoted: 9 Post(s)
Inner tube concerns
Hi all,
So I've recently bought my fist bike and also ordered a couple of spare inner tubes to take with me when I go for a ride.
The tubes have arrived the other day and I though it's better to check if they are alright (don't want any nasty surprises when dealing with a flat on the side of the road).
I have inflated both tubes and they seem ok in terms of holding the air in - no punctures, haven't deflated in 24 hours or so.
However whilst one tube looks perfectly fine in terms of its shape - nice perfectly circled tube, the other one looks a bit weird. As if it has "swollen" in some parts, imagine a snake that has swallowed a couple of mice and a couple of rabbits with few minute intervals (sorry couldn't think of any better way to describe how the inflated tube looks).
Question - is this normal or should I send it back to the retailer and ask for a replacement? It seems to me that the rubber of the tube is thinner or softer in some parts and harder/thicker in others. Will it even up when fully inflated to the max pressure inside the tyre? I have only inflated them very slightly, only to see if they hold the air in.
Quoted: 1572 Post(s)
Liked 644 Times
Wouldn't blip my radar.
My current peeve with inner tubers is valve stem length. Are they the right length to match your rims?
I don't think I have ever inflated a brand new tube before it has been installed. However, after a patch is a different story. I have seen where the 'weld', or casting seam I guess, on the rubber doesn't quite inflate the way everything else does along with the patched area. I would ride it, doesn't phase me a bit. The tire and rim is going to dictate shape in the end.
Quoted: 9 Post(s)
Thanks for confirming that it's normal for the tubes to inflate to different shapes though. I agree they should be fine once between the rim and the tyre.
Likes For Doug64:
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 343 Post(s)
Liked 242 Times
Most of the tubes I've inflated post patching have done this. When you install the tube in a tire, it will inflate to the shape and diameter the tire will allow.
Likes For Wileyrat:
Likes For Retro Grouch:
Quoted: 644 Post(s)
Liked 1,539 Times
The tire will distribute the pressure evenly. No worries. I don't think I've ever seen a tube that was somewhat misshapen when inflated on it's own.
Quoted: 174 Post(s)
Liked 177 Times
Hi all,
Quoted: 174 Post(s)
Liked 177 Times
Negative.
How are you getting all of the air out of those tubes after inflating them? New tubes come perfectly wrapped-up and completely deflated so they’re as compact as possible and ready to fit neatly inside your jersey pocket or saddle bag. I wouldn’t ruin that on the off-chance that they’re defective.
Quoted: 2544 Post(s)
Liked 3,021 Times
In my experience back when I worked in bike stores, the tubes that people bought and took home to fix their first flat had a mysteriously high rate of failure. Tubes from the same lot that we used for repairs in the shop always worked fine for us.
Likes For Trakhak:
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,539 Times
Likes For Kapusta:
I stupidly bought a bunch of tires with the wrong valve stem length and didn't realize it until 3 years later that I opened up the packaging...
Quoted: 1074 Post(s)
Liked 295 Times
Don’t think I’ve ever had a verified flat out of the box. I have had a batch of Geax tubes with a thin streak that would stretch unevenly and burst either on inflation after install, or very soon after install. Would probably have caught that earlier if I’d inflated them prior to install.
I’m reasonably sure though that I’ve had faulty valves straight out of the box.
Still, either have been so rare that I generally mount tubes untested. By overwhelming majority, it works.
