Help needed for finding a replacement rim!
Quoted: 20 Post(s)
Hi All, These are my current rims: Wheeltech TD26 by Alex Rims (can't find much info about these online). I need to replace the rear wheel as it is cracked (cracks on the rims around a few spokes)
It's a 700C disc brake rim with quick releases. What do I need to consider other than the size of the wheel when choosing a replacement? I'll likely migrate over the cassette and rotor (if need be). My knowledge of rims is limited so any help is appreciated!
Here is my bike: https://www.bikes.com/en/bikes/whistler/2015 (Must select Whistler 70 when on the site)
Thanks all!
Thanks all!
Really Old Senior Member
That's a "semi standard" disc wheel for 135mm spacing & 8-10 speeds.
10mm axle.
10mm axle.
Pay attention. What didn't you understand about-
Ignore list for you......because you deserve it.
