Whats your fav chain lube?
Bikes: caad 10
I was told by a wrench at my LBS, use wd-40 with rag to clean chain after ride, then lube with what he rec FInish Line ceramic wax.
I ride all in the counrty very dusty,sandy roads.
What do you use for smooth and quiet opearation of your drivetrain?
Also any cleaning tips other than wd-40 and a rag
Cheers
Chris
Caad-10
Cheers
Chris
Caad-10
Should Be More Popular
Quoted: 22603 Post(s)
Liked 8,929 Times
It probably doesn't matter.
A lot of folks here say WD40 has NO place on a bike chain. Others swear by it.
I am not smart enough to know.
I just drip my favorite (Prolink) on it, then wipe off the excess. Some folks do this after every ride...I do it every few hundred miles.
What really matters the most is that you wipe off the excess lube and the lube on the OUTSIDE of the chain...that just attracts grit. You want the lube to be on the INSIDE.
Use the search function for tons of lube threads, they pop up every couple of months.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Pro Link. After the first time I clean the chain and apply Pro Link, I never have to clean the chain again. Just wipe it down and apply a little more Pro Link once a month (more often during bad weather).
It's like riding a bicycle
Liked 8,929 Times
Thanks for reminding me, my lube is prolink too. I don't know where that triflow brain fart came from.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Also, I've been told that they have improved Triflow since I tried it (and subsequently got a chain caked with grime) in the mid 90's, but Pro Link works great for me so I have no reason to switch back.
Quoted: 1109 Post(s)
Liked 1,200 Times
I've been using Chain-L for about 1,000 miles this summer and, even after riding through the rain a couple of days ago, the chain looks and sounds good. That was my only rainy ride though, I'm pretty much fair weather.
I did wipe the outside of the chain w/ mineral spirits a couple times within the first couple of weeks to get the sticky lube off, but haven't touched it since, about 1.5 months ago. It looks like a normally lubed chain, not pristine, but not filthy.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
Finish Line Dry Teflon Chain Lube.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Godfather of Soul
Bikes: 2002 Litespeed Vortex, 2010 Specialized Tricross Expert,2008 Gary Fischer Hi Fi Carbon, 2002 Specialized S-Works hard tail, 1990 Kestrel KM 40
Quoted: 3376 Post(s)
Liked 5,525 Times
shedding fat
Extra Medium Member
Phil's Tenacious. Simple. Awesome.
Droping the hamer since '86
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
Another vote here for Prolink. And I clean occasionally with mineral spirits.
I'm bigger guy, and I do a lot of climbing. I get 3k miles out of my chains in a dry climate.
Quoted: 40 Post(s)
Liked 9 Times
KMC X10SL chain.
Rock and Roll Gold.
Drip it into links every other week. Wipe clean.
Remove chain for thorough cleaning every other month. Degreaser. Soak in R'n'R Gold. Q-tips in-between links to remove all crud.
Smooth shifting, quiet running.
Rock and Roll Gold.
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 92 Post(s)
Liked 109 Times
A special mix of gear oil, Pedro's synthetic chain lube, 90W tranny oil, and 5W30 Pennzoil synthetic motor oil.
My little squeeze bottle with the metal needle applicator is getting low, so I'll fill it with whatever's handy and add to the mix.
