Rotor 3D+ Inpower firmware upgrade failed
Old 11-22-19, 07:27 PM
BrianHS
Hi all,
Tried to upgrade my Rotor 3D+ Inpower meter from Ver 2.201 to Ver 2.202 The update failed and now the power meter corrupt. Can still connect with the Inpower software V2.1 & 2.2, but the power meter seems to be stuck in an upload state. Tried reflashing multiple times, but fails to complete. Have had advice from Rotor Support, but nothing they have suggested has helped.
Does any one have an old copy of Inpower software Ver1.4 and previous firmware versions for the 3D+ Inpower meter.
Was working fine with Ver 2.201 firmware before upgrade.
Using a Cycplus Ant+ USB stick in my Win 10 Pro laptop.
Any help would be appreciated.
Regards,
Brian.
NZ
BrianHS is offline
Old 11-22-19, 08:49 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
Try the Electronics, Lighting and Gadgets and forum here. The members there are more likely to be able to help.
HillRider is offline
Old 11-23-19, 05:46 PM
BrianHS
Thanks, posted as suggested.
BrianHS is offline
Old 11-21-20, 02:01 AM
johnhome
Hi Brian,
I encountered exactly the same issue. How did you resolve it?
Appreciate your help!
John
johnhome is offline
Old 11-21-20, 02:26 AM
BrianHS
Originally Posted by johnhome
Hi Brian,
John
Hi John, my problem ended up being the ANT+ USB stick I was using was not compatible. So I purchased a Garmin ANT+ USB stick, and then the software was able to successfully upload the firmware.
Regards,
Brian.
BrianHS is offline
Old 11-21-20, 03:18 AM
johnhome
Regards,
Brian.
Hi Brian,
Appreciated so much on your prompt reply.
You could have saved a life!
I will try out your solution.
John
johnhome is offline
Old 11-21-20, 05:02 AM
johnhome
Regards,
Brian.
Hi Brian,
I just quickly borrowed a Garmin ANT+ from my friend. Yet I still face the same error.
Could you share with me where did you download your Ver2.202 firmware or would you just share your fw file to me?
I got it from here: rotoramerica.com/pages/power-meter-support
Thanks again.
John
johnhome is offline
Old 11-21-20, 05:15 AM
johnhome
Hi Brian,
Thanks again.
John
Hi Brian,
It works now! I have to put the Garmin ANT+ USB stick directly kissing the power crank so that the firmware file could successfully transfer over.
To be safe, I also turned off my Symantec protection just in case it blocks any data transfer.
Hopefully our posts here will be helpful to other Rotor 3D+ INPower users.
Thanks again for your tips and assistance!
You're just my hero of the day!
John
johnhome is offline
Old 11-21-20, 11:23 PM
BrianHS
Hi John,
Great to here. The Garmin ANT+ USB stick is a type M, which is critical to work with the Rotor power meter and software.
Regards,
Brian.
BrianHS is offline
Old 03-17-21, 02:52 AM
Jonnyrevisimo
Easier solution....
Hi all, thanks for thr helpful discussion, however I have found a much easier hack to get the PM to update firmware.
1) Do everything you are supposed to do to set up (connect software etc)
2) place your laptop right next to your powermeter (as close as you can.
3) upload firmware.
After 10-15 attempts and fails with the laptop on my turbo stand I tried this and it worked first time, with my cheap amazon ANT stick.
Jonnyrevisimo is offline
