Installed new fork, but everything is Loose
Old 06-10-05, 06:18 PM
Simko
Indecisive rookie
Bikes: Nishiki Rally
Hey all, installed new fork, but stuff is loose, like, the little rings you need to pry off in order to take the old fork off wont re tighten, do i need to smack them with a hmamer? or whats the deal?
Simko is offline
Old 06-10-05, 06:32 PM
Bikewer
Well.... First, more information. What kind of fork? What size? "The rings you have to pry off..." You shouldn't much have to "pry" anything. Are you talking about the bearing seats for the headset?
What kind of headset are you using, and what size?
Installation for older threaded forks and headsets is quite different than the more modern "aheadset" type.
Bikewer is offline
roadfix
hello
roadfix's Avatar
Quoted: 193 Post(s)
Liked 115 Times in 51 Posts
Before you smack anything......best if you took it to your LBS and have them take a look...
roadfix is offline
Old 06-10-05, 06:34 PM
midgie
midgie's Avatar
Bikes: 2004 Raliegh Retro Glide 7(green of course), 2005 Stingray Pea Picker 2005 Specialized Hardrock 2014 Trek Crossfit
I don't know about the hammer, I've never used one on the headset. Theres a tool more like a 2" pipe, and it smacks it all at once. Less chance of damage. Did you check Sheldon's website?
We're gonna have the hap, hap, happiest Christmas since Bing Crosby tap-danced with Danny ****ing Kaye.~Clark Griswold
midgie is offline
Old 06-10-05, 07:36 PM
Simko
Indecisive rookie
aaaaaaaaaaaaah its a manitou shock set "answer" 1.25" pipe
um theres this ring and i think its the bearing cover .... ill takee pics in the morning.
Simko is offline
Old 06-10-05, 08:48 PM
AndrewP
Bikes: Peugeot Hybrid, Minelli Hybrid
https://www.parktool.com/repair_help/...readless.shtml
AndrewP is offline
Old 06-11-05, 09:03 AM
Simko
Indecisive rookie
guys do i need those specialty toools to do that kinda stuff?
Simko is offline
Old 06-11-05, 09:37 AM
phidauex
Spoked to Death
phidauex's Avatar
Bikes: Salsa La Cruz w/ Alfine 8, Specialized Fuse Pro 27.5+, Surly 1x1
You don't need them all, though they help.
If you are replacing the fork, but not the headset, then you can leave the bearing cups in the frame instead of removing them. You'll need to remove the crown race from the old fork, and put it onto the new fork. Removal can be touchy, but gentle tapping all around the bottom of the race with a punch and hammer can ease it off. But remember that EASEing it off is key. You can press it onto the new fork in a similar manner, or by using a piece of pipe that will just barely slide over the steer tube and allow you to use a hammer to lightly tap the race into place on the new fork.
Other than that you'll need a way to set the star-fangled nut in the new fork after it has been cut to length. You can get away with threading a bolt through the nut, and then using the bolt to tap the nut down into the fork with a hammer, though that is touchy business, and you might mess your first one up. When in doubt, have the LBS do it.
And finally, read read read the park instructions and whatever other instructions you can find, and if you don't understand what is going on, take it to the shop. It'll be cheaper to have them do it right than to have them fix what you broke and then do it right. If you are new to mechanic'in, a fork isn't where you want to start.
peace,
sam
phidauex is offline
