SRAM Apex 1 vs Rival 1
Hi Guys,
Looking to build up a Surly Cross Check and am having thoughts about which group set (mainly derailleur and shifters) to use for the build as I'll most likely be using SRAM NX MTB cranks.
Has anyone had experience with either group set? I've seen a video or two of people showing the mud build up in an APEX 1 derailleur, but have also heard good things. Any input will be greatly appreciated. Just want something reliable and heavy duty.
Thanks!
Thanks!
Also... Did you mean the NX has a terrible RD? Or the crankset is bad..? Would you recommend other cranks? I feel like I can use any SRAM crank for the build. Looking for a 1x setup.
Thanks again.
Bikes: Kona Unit, Kona Kahuna, Kona Dew DL, Scott Big Jon, Trek Checkpoint ALR4, KHS Urban Soul, Haro Team Issue, GT Force Expert Carbon, Bernardi Quadra.
Quoted: 31 Post(s)
Liked 48 Times
I'd go for Shimano GRX, Shimano's stuff is simply better imo and you can add a Deore, SLX or XT crank if you need a mountain bike crank.
Quoted: 353 Post(s)
Liked 92 Times
Got it. Thanks for the reply. So you'd recommend going for a Rival RD I'm assuming.
Thanks again.
Thanks again.
Thanks all for the replies. I think I'll stick with Rival for the RD, an NX crankset with a GXP BB and most probably a Shimano XT cassette.
So the Rival derailleur will work with the 10-42 Shimano cassette?
