View Poll Results: Sizes that Dahon Boardwalk can use
20 x 1.00
0
0%
20 x 1.25
1
33.33%
20 x 1.75
1
33.33%
20 x 2.00
1
33.33%
Voters: 3. You may not vote on this poll
Tyre Size for Dahon Boardwalk
I have one Dahon Boardwalk and I have doubt about the minimum and maximum size of the tyre.
20 x 1.00
20 x 1.25
20 x 1.35
20 x 1.5 (Fabric Default)
20 x 1.75
20 x 2.00
Which possibilities it is OK for this bike???
thank you,
Mateus
20 x 1.00
20 x 1.25
20 x 1.35
20 x 1.75
20 x 2.00
thank you,
Mateus
I recommend measuring the frame, for tire clearance.
all are fine from my perspective , you just cannot choose..
I have a 406 20" wheel bike , came with 47 wide , 1.75"
I have a set of the slightly narrower 40, or 1.5" for my next set..
schwalbe marathon greenguard for puncture resistance ..
heavy duty 'thorn resistant' inner tubes so I don't need to top up the psi so often
I think of putting a high pressure tire (> 40 psi) and with a measurement smaller than 20 x 1.5 that was what came from the factory on the bike.
I know if I put more than 1.5, I have to be careful not to grab the tire.
Stardust
20"x2.0 will not allow to use fenders
Brompton é o meu sonho de consumo, quem sabe um dia.
Brompton is my dream of consumption, who knows someday.
Quero colocar uma largura na bike abaixo dos 1.5, a minha ideia era colocar um pneu 20 x 1.00 ou 20 x 1.25 para rodar na cidade, no caso Barcelona.
A minha boardwalk rodou muito ai no Rio de Janeiro com o meu pai. E agora está comigo na Espanha.
Yes, I know that, but I'd rather keep the fender because I want more agility and speed.
And this bike I used to go to work.
Stardust
go surf in aliexpress and buy some high quality hubs and doublewall rims.
following on from above...
451 is a larger narrow rim- skinnier tire combination in the nominal 20" wheel category ..
then you need a different brake because the rim is larger diameter..
406 to 451 is a radial difference of 22.5mm ....
In the past someone found an adapter for Direct pull brakes , V type.. frame pivots..
some one had made, for the purpose.. Online link.. picture, offered..
Stardust
the mainstream solutions for this propouse are:
R$ 100,62 | Litepro aluminum bicycle V brake extend converter SP8 20inch to 451 Birdy to 20inch bike frame V brake adapter bmx parts
https://s.click.aliexpress.com/e/cK0nJAQc
and
R$ 49,94 | Litepro aluminum bicycle V brake extend bike brake adapter birdy refit BYA412 to16inch, SP8 to 451, bmx parts
https://s.click.aliexpress.com/e/crZIEU3O
