What bottom bracket size /model do I need?
Bikes: Charlescen
Hello people, so I'm working on a bike build and got a frame recently second hand but when I measure in the inside tube, it doesn't add up, so bit confused.
Frame is Giant defy advanced 1(2014) Medium. From online specs it says Shimano press fit, but no sizing. I'm also using Shimano 105 cranks, if that helps.
Appreciate the help!
SE Wis
Quoted: 2744 Post(s)
Liked 3,390 Times
Shimano 105 cranks covers about 20 years and numerous generations and BB types. You'll need to be a bit more specific.
Everything from this.
https://velobase.com/ViewComponent.as...34a99&Enum=115
To this
https://bike.shimano.com/en-EU/compo.../crankset.html
https://bike.shimano.com/en-EU/produ...M-BB72-41.html
To this
SE Wis
Liked 3,390 Times
https://si.shimano.com/pdfs/dm/DM-FC0003-06-ENG.pdf
https://productinfo.shimano.com/#/co...453&acid=C-455
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Moving to Mechanics Forum
Keep the chain tight!
Quoted: 2026 Post(s)
Liked 1,096 Times
The FC-5800 is a Hollowtech II design with the spindle built into the driveside crank arm so the spindle length is fixed. The matching bottom bracket has external cups and you need the press-fit version which is SM-BB72-41.
duganator
Bicycle Mechanics
10
09-22-18 09:31 PM
amgarcia
General Cycling Discussion
5
06-14-12 10:56 PM
