New chain for old bike
Bikes: 1978 Schwinn Traveler III (original owner)
I have a 1978 Schwinn Traveller III 10 speed and I am looking for a good - inexpensive replacement chain. Any suggestions?
Thanks.
Thanks.
Really Old Senior Member
Any generic 5-8 speed chain will work.
Quoted: 6193 Post(s)
Liked 4,808 Times
Don't let the 5-8 speed thing throw you. It's referring to the number of gears on the back freewheel or cassette. If you don't ride your bike a hundred miles a week, then virtually any brand you find should be a "good" chain.
I'd go with a Bell chain from Walmart or Academy Sports. Many here will lambast me for that, but as I said if you aren't putting that many miles a week on the bike, why spend more. Although a really good brand isn't that expensive either.
Oh, make sure you size the chain to your old one. Replacement chains are typically too long and have to have a few links removed.
BITD 10 speed is 5 by 2 anyb3/32" wide chain will do But by noe you also need a new freewheel
5 speed freewheels are still made
have any bike shops around.. you have to remove the old, to fit the replacements..
that takes special tools,.... 'freewheel removers' are many . bike shop has an assortment..
So found a Bell Links 500 for $7.30 and a KMC Z8.1 for $7.07. Any preference...$. I also found a SRAM PC 830 for just a bit more at $9.95...
Liked 4,808 Times
For me it'd be which one can I get the quickest. As you've found, none are budget busters. KMC is one of the most popular mfr's for chains.
Quoted: 1819 Post(s)
Liked 1,693 Times
Any of those chains should be fine. However, if your old chain was badly worn you may discover that your freewheel may also have to be changed. If you discover that your chain slips under pedalling load on one or more of your rear cogs you will also need a new freewheel
Thank you for all of your help. I'll have to see if cogs are worn...
oldlugs
Classic & Vintage
21
01-20-11 09:47 PM
LivelyChorus
Bicycle Mechanics
7
02-01-10 05:48 AM
