Steerer Tube Length
King Among Runaways
Bikes: 2004 Bianchi Pista, Cannondale Track, Soma Pake, Schwinn Breeze
Steerer Tube Length
Ok.
So, I just bought a new track frame to replace my old conversion. The conversion was a 55cm while the new frame is a 57cm. What are the chances that I will be able to swap the fork from the 55cm to the 57cm? I know I could wait the 4 days for the frame to arrive and just see if it works, but I'm at work and was curious. Thanks.
King Among Runaways
Threaded.
I sort of figured there were too many variables to take into consideration.
Better than you since 83!
Bikes: Fixed Gear 79 Schwinn Sprint
If its too long you can always use spacers and make it work...if its too short then you're a bit SOL.
King Among Runaways
The too short is what I'm concerned about.
If it's too long I'll just cut it down to length.
Rebel Thousandaire
Bikes: Public D8, Yuba Mundo (cargo), Novara Buzz (1-speed, soon to be 2-speed w/ a kickback hub), Xootr 1-speed folder
Too Short could definitely be a problem.
King Among Runaways
Ok then.
Assuming it is too short, which I am a feeling it will be, can anyone recommand a good, inexpensive steel 1in threaded fork - either black or chrome - other than the BikeWorks NYC one.
Bikes: DW
i'd also look into which threaded headsets have the lowest stack height. it may be cheaper to get a new headset than a new fork, if there's a lower one available.
King Among Runaways
