Cannondale touring ultra low speed shimmy
Bikes: Cannondale touring
Hi guy's .
Newbie tourer alert be warned dumb questions may follow.
I have the Cannondale touring ultra 07 did my first tour this year (ok slow starter i know)
Fatty lockout 80 mm fork,mavic 117 rims
this link has a discription of the bike https://www.bikeradar.com/gear/catego...rs_description
Load 10lb each rear pannier 7lb each front ...tent and mat on the rear rack 5 lb in the bar bag.
When starting off the front shimmy's back and forth alarmingly, this soon clears and does not return,indeed the bike handles really well loaded and the off road loaded performance seams great ...my thoughts
1. its me, just week
2. its the frame
3. its the fork.
4. its all of the above
Any thoughts from the more experience would be appreciated.
2. its the frame
3. its the fork.
Quoted: 137 Post(s)
Liked 81 Times
experiment with different loads and see what combo makes it worse. Front only, rear only, bar bag only, no bar bag. When you say "back and forth" do you mean side to side or the front axle actually moves front to back? Maybe it's the front shock pogoing?
Another thing you can do is tighten up all the panniers with extra bungies to see how much of the movement is stuff in the panniers moving independently of the bike.
ghost on a machine
Bikes: Rivendell A. Homer Hilsen, Serotta Colorado Legend TG, Rivendell Roadeo, Surly Cross Check, Surly Big Dummy
Quoted: 7 Post(s)
Maybe try a few more p.s.i. in the tires?
Quoted: 3426 Post(s)
Liked 1,441 Times
I think it unlikely that you are overcompensating, if that was the case you would have gotten used to the bike after less than two hours.
I had a bad problem with handling with my Surly Long Haul Trucker when my front panniers were too far back. When I moved them forward so that the center of gravity was over the front hubs, my problem disappeared.
Cured it
Toady I think i cured this problem ...wich actually may be due to the lock out not locking the top cm on the fork for some reason ....recon for the cartridge in the fork is £172...from TFT Tuned ....so i order a Surly LHT from the LBS in Cappuccino...£300...sell the old frame and i should break even on what a shock service would have cost me and get a real tourer in the deal.
Reads more like you put some reasons to buy a touring frame into a hat, then plucked out this one.
Brad
Brad
The Headshock fork has been an issue almost from day one ...I came from mountain biking and just could not imagine having no suspension, with hindsight the Cannondale system with its 1.5 headtube and very expensive service prices was not the way to go but hey i had fun and learned !
Quoted: 137 Post(s)
Liked 81 Times
aha! So it was a fore/aft movement. $.02, if you like a neutral to quick handling bike the 26" wheel LHT is a better choice than the 700c LHT which is more of a straight line train/bus. I had a 700c 56cm LHT for a couple years then got a 56cm 26"wheeled LHT. The 26" is easier to maneuver at low speeds and hands off riding but still carries a heavy load well.
As much as I like the idea of a Headshock for bad roads a 2.10" front tire can provide some good shock absorption.
Fore aft
Sounds right ...If you hold the front brake on and rock the bike back and forth there is a lot of flex..not in the legs but in the part of the fork running through the head tube which has the built in suspension ...I never noticed it until I loaded it.
Wicki, since you used £, in price quotes,
NB In the UK, you can get a Koga Miyata Signature program bike,
custom parts pick.
delivered to a nearby dealer,
a Thorn- Raven loaded touring specialty bike from SJS,
or A Tout Terrain Silk Road.. German..
All better than a LHT (opining), because They designed around a Rohloff IG Hub,
and in case of Koga , consider the practicality of a Kickstand..
Surly does not, only the Soma another Us importer brand, made in Taiwan,
has a KS plate.
My '04 WTR has 2, 2nd one keeps the front wheel load in check.
Koga Miyata sells complete bikes , most other brands are expecting you
to assemble racks and mudguards and such thru the dealer, at point of sale.
(I had a lucky stroke finding a used WTR, as there is only 1 dealer left ,on those
other coast from here, and they are no longer sold thru that seller)
amongst their options of the signature program, is a suspension fork ,
you said you thought that was important,
Mine was modified at the point of origin, to fit a Tubus Ergo front rack,
to the lower sliders,, machined for the purpose,
and then painted to match the frame color ..
Oh and i think someone, at Koga, in NL, puts your name on the frame..
custom parts pick.
has a KS plate.
Humble pie time
Ok since finding this board and starting this thread I have for the last week soaked up more good information than in the last 10 years of cycling...
I have for years thought the only way to sit on a bike is in the upright cross country/Downhill position, after reading a mind blowing thread on Fit and position I went out and totally altered my bike geometry dropping the stem 30 degrees moving the saddle back over an inch and bringing the grips half an inch inboard each side ....OMG more power better handling no shimmy ....and a large portion of humble pie as I cancel the Surly LHT (luckily they were out of stock) The thread https://www.bikeforums.net/showthread...tion-Discovery was a revelation and blew away my preconceived wisdom about comfort.
Looks like the Cannondale is a keeper after all ...not so sure about the Headshok found a replacement if i want to go that route at Thorne steel bladed suspension corrected fork...costs less than a headshock service!
Apology's for wasting peoples time on this a good search would have done the trick on day one.
