Tubed Clinchers: 25mm or 28mm?
Chases Dogs for Sport
To simplify this thread, assume that I want tubes. (I know that will be extremely difficult for some of you. I've got tubeless on another bike. I've done tubeless for a long time. But I know I want tubed on this bike for a number of reasons.) I've read all the conflicting articles, reports, etc. about tire width, comfort, and rolling resistance. But they all assume equivalent tire constructions (which don't really exist among different sizes, even of the same brand). And a lot of them assume tubeless tires -- i.e., much lower pressures.
So . . . assuming a mix of glassy smooth roads and rough-ish chipseal, would you go with 25mm or 28mm width? (I'm thinking Conti 5000's, if that matters.) Comfort really isn't as important as speed.
Should Be More Popular
Quoted: 22597 Post(s)
Liked 8,925 Times
Likes For datlas:
What about riding with a 25 front and a 28 rear?
25 front might be a better aero pkg with your front rim.
28 in the rear should give you a more comfortable ride
and not sacrifice much if any speed.
Likes For hefeweizen:
(I weigh 175 lbs.)
Quoted: 1743 Post(s)
Liked 1,281 Times
I can't speak to the 28s but I have run 25s on both my road bikes and it's worked well. I know my Guru couldn't accommodate 28s but maybe my CAAD12 . In season I weigh 187 lbs. (FWIW, I discovered Mavic USTs so I don't do either now.)
Liked 8,925 Times
I like 28s, but it is definitely frame dependent. I'm 210 and run 70-75f/80-85r.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
If you can fit them, I love my 28mm GP5Ks with Conti Race tubes, comfortable, fast, and handle great. Mine measure 30mm on 20c rims. Haven't noticed any loss of speed over my previous "aero optimized" setup with 23mm tires. What I have noticed is that I can actually ride faster through rough sections without getting beat up.
Quoted: 874 Post(s)
Liked 2,287 Times
I only have one bike left with 23's and when those tires wear out or I get tired of the fatigue, I will change them to 25's. I have 28's on my Windsor pro and that bike rolls real well , of course that could be due to the Phil Hubs. I like wider tires nowadays comfort is king! I remember thinking that skinny tires were faster and I really don't believe it any more. I do more distance riding now so fatigue = slower , comfort= faster for longer. It does depend on the conditions, bike , and , really important is tire pressure. I was running my tires at 85-90 lbs and now I have backed off to 80 lbs and I feel the difference . I weigh 155.
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
Which wheels are they going on? 25mm GP5K's measure out to damn near 29mm on my HED Ardennes Black wheels (21mm internal width).
Of course, one wildcard is what the respective tires will actually measure on 19mm internal rims. Conti's usually measure a couple mm wide. Maybe a 25mm IS a 28mm. (On my BMC's 21mm internal wheels, 25mm tubeless Conti 5000TL's measure a little over 28mm.)
EDIT: Cypress, I guess I was still typing when you posted your reply. Good point.
For reference . . . I'm putting these tires on my OPEN as a pure road situation. Plenty of tire clearance and I've got wider tires for when that's best (all the way up to 47mm). I'm trying to stay 28mm or narrower for this situation.
Likes For FlashBazbo:
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
Quoted: 733 Post(s)
Liked 815 Times
Likes For cycledogg:
Sunshine
Quoted: 10963 Post(s)
Liked 7,489 Times
Everything ive read(up to cypress' comment) is that the 5k tires measure out relatively true on rims that are 23ish external(so 17-18ish internal). This is different from the 4k tires that are comically larger than stated on basically any rim width.
Not sure if you have seen these, but consider them for tubes. They are lighter and stronger than butyl or latex tubes. Less rolling resistance right there.
https://www.tubolito.com/en/
https://www.bicyclerollingresistance...000-comparison
So the 28mm tire rolled better than the 25mm tire at all PSI.
A 25mm tire at 100psi has the same rolling resistance as a 28mm tire at 90psi, which is closer to how tires will be ridden(wider tire at lower psi). And a 25mm tire with normalized comfort drop to a 28mm tire has the same rolling resistance.
Given that they are effectively the same rolling resistance for multiple tests, why not go wider for more comfort and use the tubolito tubes to reduce rolling resistance even more?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Quoted: 8279 Post(s)
Liked 9,033 Times
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
Running a 25 at 100 PSI on a modern wide rim sees a decrease in performance, and it would ride like junk. My HED's claim that 90 PSI is the max for any size tire on their Plus rims. In HED's tests (which jive with the BRR results) a person of my weight (164 lb) has an ideal 25mm tire pressure of 67 psi.
Sunshine
Liked 7,489 Times
I only early adopt when a product appears to make sense. $35 for an inner tube doesn't pass the "makes sense" test.
Sunshine
Liked 7,489 Times
The reason I listed 25 at 100 is to compare it to 28 at 90 since wider tires are run at lower pressures. I then also included the comfort drop comparison since that measures both tires running at 'proper' psi for the tire size.
Sunshine
Liked 7,489 Times
