Fire as paint remover?
So I had this frame that someone had repainted. Poorly. I started to strip it with paint stripper. I used both Kwik-Strip in the blue can and Jasco in the red can with so-so results. It was taking forever and using a lot of product. So I said "Screw this" and made a fire in the fire pit and threw it in. I then went section by section and the paint came off like butter with steel wool. I was done in an hour. So...my question is...why don't I strip every frame like this? It was so easy and essentially free. See before and after photos. First photo is with paint stripper frustration. Second photo is after melting the paint off in the fire.
Likes For krakhaus:
This was a Bertoni frame made with Columbus SL. That being said, the heat from a camp fire would certainly be less that the heat needed for brazing this frame together. So I doubt it would affect the strength of the steel.
Additionally, and as another comment., I can't bring myself to repaint this "electic rose" or "violet mist".
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,458 Times
Beavis approved!
Likes For SurferRosa:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
The frames are double butted so the material is thicker where the braze occurs. Heating the center section of the tubing would be a bad idea.
For a data point from another field, the US department of transportation requires any steel gas cylinder to be removed from service and condemned if the cylinder is heated to a temperature above 650F, which is much less than a frame brazing temperatures. The temperature limit for aluminum cylinders is lower (350F).
Likes For wesley77803:
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
The heat of even a camp fire could change the crystalline structure and bonds of the metals, maybe not drastically, but it has been altered and its strength is compromised to a degree. As a site engineer, for a GC, on DOD buildings, and structures' projects (now retired,) I had to observe and document the entire process if a structural steel pieced had to be field modified, very strict guidelines were laid out, and had to be approved by a structural engineer before proceeding (if you were even allowed to approach the NAVFAC or USACE officers about it.) Mainly it will depend on the particular alloy of the tubes, luge (if applicable,) and brazing materials.
I was teamed with a Supt, that was a metallurgist, in the nuclear power industry, he could really explain this better than I could, and I had to be certified for metals inspections and failure analysis, for my approval as QCPM before each project began, if structural steel and connections were involved. the Supt had been NRC approved for over 20 years, before coming to work for us. Heat treating and failure analysis were kind of his field of expertise and big thing.
There are some very experienced metallurgist and engineers here, maybe one will give their thoughts. Hope that the build turns out well, and that everything is copacetic.
Bill
Bill
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
that would really depend on the intensity of the fire and the frame's proximity to the hottest sections of the fire. if i can cook on a campfire without burning the food, it's safe to assume that fire couldn't be more than 400 degrees. and, 400 degrees is really a hot fire to be cooking on, in any case. would sub 400 really be hot enough to alter the metal? hasn't affected any of my cookware in any notable way
Semper Fi
Liked 358 Times
Bill
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Insane Bicycle Mechanic
Quoted: 797 Post(s)
Liked 694 Times
I've gone to auto parts stores and had them hot tank steel frames to strip the paint. This is caustic soda in hot water- probably not as hot as your camp fire. It gets the vast majority of paint off the frame, only leaving detail work in the corners of lugs and such. It beats messing around with paint stripper goop.
Jeff Wills
Jeff Wills
Bikes: Indeed!
Quoted: 1506 Post(s)
Liked 3,463 Times
Anyone who has thrown a tin can into a campfire knows that a wood fire can get hot enough to seriously deform thin steel. I remember from my wood stove days that wood starts to combusts at about 500f and that the target for a clean fire without visible smoke is around 1,100f. Some air control was generally needed to reach that temperature so I doubt that an open wood fire would get quite that hot very easily.
Brent
Brent
Quoted: 892 Post(s)
Liked 2,052 Times
Brings back memories of working in a heat treating facility in my youth. My part of the shop ran carb pots, and everything was 1500 to 1950 degrees F. One day as i walked through another part of the shop, a guy asked me to help him pick up a heavy shaft he had been straightening. I saw it was not glowing red or white, which to my world meant it was cool. So without thinking I picked it up bare handed. It was 500 F. That was the worse burn I ever suffered.
A roundabout way of saying, 500F is used to soften steel.
Quoted: 1105 Post(s)
Liked 1,326 Times
Yes it's cooler (but a wood fire is not six times hotter - do I need to say that?).
And annealing temperatures for steel are from about 300 up, so no, fire is not a Good Thing for bike frames.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
dude....sounds like your frame is... toast...hahaha
but, frankly.....i think your frame just needs s'more paint.....hohohoho
it'll be one smokin' build....<<<buh doomp....pshhh>>>
yes, well done
yes, well done
Likes For thook:
Quoted: 1607 Post(s)
Liked 2,214 Times
I would not even use a torch to burn paint off!
I think your frame is roasted or a t least toast!
Quoted: 3804 Post(s)
Liked 6,640 Times
Likes For nlerner:
Quoted: 872 Post(s)
Liked 2,271 Times
Quick and easy is rarely the best solution.
Forum Moderator
Quoted: 3085 Post(s)
Liked 6,566 Times
Likes For cb400bill:
Let me clarify. The frame was above the fire, not in the coals. I heated one section at a time for about 1 minute, then removed it to scrape the paint in that section. Each section worked was roughly 6 inches long. The total process, section by section, took about an hour.
Likes For Jicafold:
Quoted: 981 Post(s)
Liked 1,844 Times
See, all of this tripping out about weakening the frame after leaving it in a fire for an hour could have been avoided if you just explained the process earlier. ;P
Likes For Kilroy1988:
True. My apologies. I understand about heat and weakening metal...however, I wouldn't think that it should affect the frame to any dangerous level. I'm not sure if I would do it again or not. It's just that this particular frame had multiple layers of paint and it was taking forever with paint stripper.
