12-32 freewheels becoming obsolete?
12-32 cassettes becoming obsolete?
Are 12-32 cassettes becoming obsolete. Everywhere they seem to be out of stock or overpriced compared to 11-32.
For some reason I'm unable to edit the title, should be cassettes not freewheels.
Quoted: 2026 Post(s)
Liked 1,096 Times
Yes 12xanything cassettes are getting hard to find. My favorite 12x27 10-speed is out of production and nearly impossible to find and 12x30 10-speed is getting hard to find. I don't understand this fixation with 11T cogs unless you are using a 46T big chainring or smaller.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I’ve a 12-32 eleven speed on my gravel bike. I combined the cogs from an 11-32 and a 12-25. I used the remaining cogs on my trainer.
Probably the only way is to get any two cassettes containing 14, 16, 18, 21, 24, 28, 34 cogs including appropriate spacers and then combine as one needs.
Turns out 8 speed drivetrans were starting to become obsolete since 2007.
https://www.bikeforums.net/fifty-plu...olescence.html
Liked 2,568 Times
The 11-32 would actually half-step beautifully with 45/42, for what that's worth...
RUSA #7498
Originally Posted by noglider
You found a thread from 2007, but Shimano had already released 9-speed in 1996: https://en.wikipedia.org/wiki/Shimano#Road_groupsets
Apparently it took quite a long time for the market since 1997 for 9 speeds to reach the bottom of the barrel social backwater then.
Liked 2,568 Times
Actually 11-32 cassette should be better since there isn't unnoticeable 7%/5% gap between 18T and 16T sprockets.There is 7%/12% instead which is almost too noteceable but better.
I might even remove the 11T sprocket and use it as a spacer between the hub to improve the chainline if this is technically possible.
Quoted: 18378 Post(s)
Liked 4,512 Times
11:32 gives a 2.91 gearing range
To get the same with 12T, one needs a
12:35
And, a bigger cassette, derailleur, chain, etc.
You can adjust your top end gearing by using a smaller chainring.
12:35
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Seems as if one gear would be enough for an ebike.
Quoted: 350 Post(s)
Liked 122 Times
https://thecycleclinic.co.uk/product...r-shimano-sram
https://www.miche.it/en/prodotti/str...mato-10sh.html
https://www.miche.it/en/prodotti/strada/cassette-pignoni/light-primato-11sh.html
https://www.miche.it/pub/media/productattach/t/a/tabella_compatibilit__primato.pdf
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
If I'm understanding you correctly, it likely wouldn't be possible (at least not without significant modification). Most of the lockring sprockets, like the 11T in this case, have "end caps" to their splines, which means they won't slide all the way on to the freehub. You can slide them on a few millimeters and then they'll stop at the spline "end cap". You sometimes have to shim a cassette if it's loose even after tightening -- because the lockring sprocket will continue to compress the cassette cluster only until it bottoms out on its "end caps".
Liked 762 Times
You said you wanted to use the 11T sprocket as a "spacer between the hub". I understand from that that you want to place it as a the innermost sprocket on the cassette (which would not work). The other thread talks simply of omitting the smallest sprocket if the cassette "hangs off" the freehub body or you don't otherwise want it, which certainly is possible.
Back to my reply, I must not be understanding correctly your intent of a "spacer between the hub".
