Cable tension question
Quoted: 11 Post(s)
Hi all - question regarding cable tension.
I noticed the tension on the FD when it is on the largest sprocket seems pretty stout. Really tight with respect to the tension on the RD when it is on the smallest sprocket.
The main reason I ask is that I wonder if this normal. It’s a 3x7 Shimano set up with EF41 shifters.
My assumption is that it most likely has to do with having 3 on the front (vs 2). I’ve tried to adjust barrel to release some tension but this takes away from its ability to make it onto the outside sprocket.
Rambling on here but more curious about differences in tension on FD and RD at its most tense point.
If you take a look at the cable at the FD, you'll see that when you are on the outside (larger chain ring), the shifter has pulled the cable to full tension to reach it. The inside chain ring (smallest) is at the no tension position.
RD is the same thing, size wise. Smallest cog no tension, largest cog- full tension
Quoted: 11 Post(s)
I understand how the FD and RD work
but just questioning how tight the tension is on FD when it is on largest sprocket. I have checked to make sure there is no artificial resistance within the spring and the cable
path.
More than anything, I don’t want it to affect the longevity of the shifter internally and how it works, etc.
But it is what it is if the tension is normally pretty tight.
path.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Barrel adjusters technically are "cable effective length" adjusters. Moving an adjuster doesn't create more or less tension,it makes the cable housing longer or shorter, thereby moving the derailleur in or out.
Likes For dedhed:
Quoted: 1572 Post(s)
Liked 643 Times
Try this: Look at where your shift cable attaches to your front derailleur. Do you see a little finger that looks like it might be a cable guide? It's not a cable guide. In fact, the cable is designed to go OVER that little finger. That little bit of difference changes the leverage angle of the cable and greatly decreases the amount of cable tension that's necessary.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Yes, IME the front derailleur operates at relatively higher tension than the rear. However, if the high limit is set too tight it can be harder to force the change to large ring.
Quoted: 645 Post(s)
Liked 797 Times
i usually adjust my cables so they’re pretty taut all the time - even at rest - so the first click or two isn’t spent picking up cable slack. I think of them as “guitar string tight”, although I know they’re not actually as taut as guitar strings. My derailleurs and shifters (Chorus 10) are ~ 16 years old and still fine, so in my experience, running cables as tight as possible isn’t harmful
