Elemnt Bolt issue
Elemnt Bolt issue
My last ride shows on my Elemnt Bolt computer (the computer is about 5 years old now and has always worked just fine) but that last ride will not appear in my History on the Elemnt APP on my iPhone. Everything is synced up and updated (and i restarted everything and re-synced too). no clue what happened as everything worked just fine with all of this for years. ideas?
Quoted: 6196 Post(s)
Liked 4,811 Times
Do another ride and see if it shows up. Maybe your device thinks you are simply taking a break and is waiting for the ride to continue. <grin>
If after twelve or so rides, that don't show up, you might consider it time to replace. If it has a way to do a factory reset, then try that at some point.
I had a ride on my Garmin 530 that didn't send to Garmin Connect about the first of last month. I saw that it was having trouble with it, but I had other things to do after the ride. A day later I looked for it and it was gone. First ride I ever lost on my Garmin's in over 12 years of using a Edge 500 and now a Edge 530.
I didn't stress out about it. It's just a ride.
I've had issues from time to time with my Bolt syncing and it always cleared itself up eventually. Lately it has been working just fine. Mine is also 5 years or so old. The battery doesn't seem to last as long as it once did, but still lasts a few rides. Or maybe my memory doesn't last as long and I just forget to charge it regularly enough?
This happened to me and Wahoo suggested to swipe down on the ride screen to trigger the upload. I've done this a few times. Sometimes the ride uploads quickly and sometimes it takes time.
