Loading maps on a Etrex30?
Quoted: 4260 Post(s)
Liked 1,364 Times
It really is pretty simple. I own and have used an Etrex20 for cycling navigation the past 7-8 years. This is how I do it to meet my own needs. Others may suggest other options, ad nauseum..and good for them.
1) Download a TRACK from RWGPS
2) Download/install Basecamp to your PC
3) Connect your Etrex to the PC via a usb cable (possibly supplied with your Etrex when you bought it, as mine was)
4) Basecamp will indicate your Etrex is connected.
5) Import your RWGPS TRACK into Basecamp
6) Transfer the track to your Etrex from Basecamp via menu on top (Device>Send to Device).
7) done
Eject your Etrex from the PC, fire it up, toggle to your Track Manager..select the track hit Go and you're on your way. This all sounds busy, but can be accomplished in 5 minutes.
7) done
One can just copy the file directly to the eTrex and avoid a bunch of steps.
The following says to copy the GPX track to \Garmin\GPX.
https://ridewithgps.com/help/garmin-etrex
Liked 1,364 Times
(The latest eTrex works like the Edges.)
Quoted: 3462 Post(s)
Liked 1,468 Times
As I mentioned..I've been using an Etrex 20 for many years and everything you describe has not been my experience. I have an updated background map loaded, I select a track and hit go..I zoom in to a 500 foot scale..and follow the track with all the roads around me completely visible. No muss, no fuss.
There's been a couple Etrex threads lately where some people trash them..from their comments it's fairly easy to see that the trashing's roots lie in the owner not knowing how to use the unit, rather than it not working. Of course they could have a defective unit..who knows.
I have been using these recreational grade GPS units for about two decades if you count the earlier ones with a black and white screen. Use them for bike touring, randonneuring, backpacking, cross country skiing, canoeing, kayaking, and on occasional to drive several hundred miles. When driving long distances, their routing might choke, but otherwise they do pretty well.
On a bike I usually set the zoom scale to 0.2 miles (urban) or 1.2 miles (rural), just because when I try to only use a few zoom scales, it is easier for me to keep track of what is going on. Some times I zoom in much closer (such as going into a roundabout), but overall I have not found any reason to use one of the cycling specific GPS units.
My Garmin 62S got some water in it in a heavy rain while backpacking, not sure how that happened but it still works over a year later. So, do not trust their waterproof rating, mine was not submerged at all, the rating is to withstand submersion for 30 minutes. But I have never had water get in one of mine on a bike.
