Rear shock problem
Rear shock problem
Old 01-23-18, 07:36 PM
rainbow9
rainbow9's Avatar
Liked 2 Times in 1 Post
Rear shock problem
I have a full suspension 20'' folder, similar to a Dahon JetstreamP8. It comes with not adjustable rear shock. I have the bike just over 1 month and noticed, from day one, that rear suspension not working at all. I can't even slightly move (compress)the shaft by pushing saddle down. I took the shock out, and tried to compress it - no luck. I was told by the seller on line, that it takes time for air to leak out to a usable condition... What a bs. Does anyone having similar issue with not adjustable rear shock? Is this can be fixed? Thanks.
File Type: jpg
rainbow9 is offline
Old 01-23-18, 09:44 PM
ttakata73
Bikes: *1998 GT Forte Ti 700c, Totem KDS-D 26" fatbike, BirdyGT 18", Brompton M2LX 16"
Quoted: 88 Post(s)
Liked 5 Times in 4 Posts
Are there any small screws on the thing? I would put on safety glasses and open that a tiny bit to see if any pressure comes out. Beware it might be high pressure and shoot out like a bullet. Maybe do it facing away from you towards a pillow so it catches the screw. If there are no openings then this might just be something that looks like a shock but isn't.
ttakata73 is offline
Old 01-24-18, 01:33 AM
ThorUSA
Bikes: to many
Quoted: 213 Post(s)
Its a blatant copy I assume
If the shock has the same dimension like the dahon quality shock i might be able to help
I have different ones but all are not cheap
ThorUSA is offline
Old 01-24-18, 03:28 AM
jur
Quoted: 321 Post(s)
Liked 7 Times in 6 Posts
Could that be an OEM Dahon rebrand? There's tools much exactly the same. Even the handlepost looks identical.
jur is offline
Old 01-24-18, 05:35 PM
rainbow9
rainbow9's Avatar
Yes. This bike is identical to a Dahon Jetstream P8. But it has18 speed and hydraulic disc brakes. love it.
rainbow9 is offline
Old 01-24-18, 05:45 PM
rainbow9
rainbow9's Avatar
Thanks, Thor. THE Shock is 125mm from eye to eye. I just ordered on line an adjustable air shock of the same size.
rainbow9 is offline
Old 03-05-19, 12:32 AM
Bilal
Same here
Hi. The rear shock on my old jetstream is gone. Would you be able to help and how much will it cost? Thanks
Bilal is offline
Bilal
Same here
Bilal is offline
Old 03-05-19, 01:20 AM
Joe Remi
Bikes: Haibike Sduro Trekking SL, Rivendell Appaloosa, Concinnity singlespeed, KHS mini velo (Japan market), Trident Spike trike
Quoted: 651 Post(s)
Liked 91 Times in 74 Posts
You can contact Thor at thorusa.com or the Folding Bike forum at mtbr.com. He's long gone from this place.
Joe Remi is offline
Old 03-05-19, 08:43 AM
jadi
Very nice. First time I'm seeing a full suspension folding bike hope you can make it work
jadi is offline
Old 03-11-19, 04:47 PM
rainbow9
rainbow9's Avatar
I found an adjustable rear shock 125mm for my bike on ebay. There are several styles you can choose from. I bought me a ''New kind of Shock Kindshock KS A5-RR1 Dual /Solo Air Rear Shock A5-RE 125/150/165mm'' on ebay.
I like it much better then old original I had. It ran around $57 and free shipping.
rainbow9 is offline
Old 03-11-19, 05:47 PM
Bilal
Thanks
Thanks
Bilal is offline
Old 03-19-19, 05:31 PM
Hiclearance
The air shock on my Dahon Groove has lost all pressure. I can have it re-pressurized locally, but what pressure is required??
Hiclearance is offline
Old 03-19-19, 06:47 PM
BromptonINrio
Stardust
BromptonINrio's Avatar
Bikes: Dahon Curve Sturmey Archer Srf8; Brompton Sturmey Archer Srf8; Brompton M6r
Quoted: 161 Post(s)
Liked 35 Times in 28 Posts
depends on your wheight
BromptonINrio is offline
Old 03-20-19, 06:36 AM
rhenning
Quoted: 380 Post(s)
Liked 106 Times in 80 Posts
The place that repressures the shock should know what it is supposed to be. I would ask them and also contact Dahon and get their numbers. Roger
rhenning is offline
Old 03-24-19, 07:24 PM
Hiclearance
Dahon didn't ask my weight when I bought the bike, so I don't see how that would apply......
I've ordered an adjustable spring type shock the same dimensions. That should do the job.
Old 03-25-19, 03:11 AM
BromptonINrio
Stardust
Quoted: 161 Post(s)
well, if you cant see i will show you.
dahons are one size fits all bikes, so you can have rider from 1.50mt and 45kg to 1.90mt and 100kg.
rear shocks need to adjust to riders wheight, to become efective i has to have at least 50% sag.
Now you know a litle bit of your bike.
the spring type of shock will decrease a lot your rider expwrience.
Old 03-31-19, 07:05 PM
Hiclearance
<<dahons are one size fits all bikes>>
That's exactly my point. Dahon supplies a bike that must fit all weights, with a shock absorber that isn't readily adjustable. The shock absorber has warnings on it not to mess with it, and no instructions in the manual how to adjust to rider weight, so we just have to live with it....
Old 04-02-19, 07:50 AM
BromptonINrio
Stardust
Quoted: 161 Post(s)
there is no logic.
its easy to ajust the shock.
no one care if there is or isnt manual, you show be responsible for your safety and go look for information
technical_tim
Folding Bikes
9
05-11-18 08:13 AM
bikeviking
Mountain Biking
2
02-28-18 03:23 AM
Garandman
Mountain Biking
5
10-05-15 08:20 PM
specialized1987
Bicycle Mechanics
4
07-26-11 02:46 PM
chagzuki
Folding Bikes
11
07-26-10 08:38 PM
