Garmin Edge 520 battery life
Anyone here uses Garmin Edge 520? I love it but it's been a headache when planning longer rides. The battery died soon. How long is yours?
Did it die, or give you a low battery warning? Sometimes mine will give a false low battery warning, but go for hours more. I think there's an issue with the battery warning system that maybe has been updated. I'd say I get at least 12 hours out of a charge, maybe more.
If it did die within 6 hours of having a full charge, or even 8, I'd check the display settings and see if it's on constant bright or something.
Quoted: 1186 Post(s)
Liked 289 Times
I've seen battery life issues with the 520 with new firmware revisions. Recently version 12.9 seemed very bad for me so I rolled it back to 12.6. Performance seems better but the battery fuel gauge is atrocious. I've had it operate for 5-6 hrs after the fuel gauge hits 0%. I think cold temps wreak havoc with the fuel gauge. I think I'm getting 10+ hrs these days.
Non omnino gravis
Gravel Rocks
don't try this at home.
Quoted: 964 Post(s)
Liked 495 Times
My Garmin 705 started showing "low battery" after 2 or 3 hours when it was about 4 years old. I never tested it to see if it could actually run for hours with the warning, perhaps the older battery just had a slightly lower voltage, making the "low" warning show up sooner.
Replacement battery
I got a newpower99.com battery almost 5 years ago. I didn't expect it to last as many years as the original, but it's still good, lasting at least 6 or 7 hours after all these years. I recharge after most rides.
Some Garmins are welded/glued shut, and not replaceable. My 705 was quite easy, with 4 small screws and a ribbon connector. The newpower99 video was useful. They supplied a tiny screwdriver and a plastic tool to pull the connector.
They have your 520 battery.
but it's more complicated than my 705, needing to strip some wires, etc.
Replacement battery
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Mine is good for about 5-7 as I currently have it set up with brighter back light and all the sensors and screens rolling. I am ok with it. I am going to get the 1030 for the larger screen this spring because I need a larger dang screen! Getting old suck!
Quoted: 3185 Post(s)
Liked 2,020 Times
Also look at the Edge Explore. It’s the size of the discontinued 1000, doesn’t have all the bells and whistles for Workouts and other fitness related stuff. More a replacement for the Touring line. $249
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I do like that unit but it won't connect to a power meter according to DC Rainmaker. No go...ugg
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 549 Post(s)
Liked 721 Times
3 years old and I got 11 hrs to 20% today. Backlight and bluetooth off, not much map use or scrolling. It's pretty warm down here though 60-80*F, expect worse in winter.
Bikes: Bianchi Infinito CV disk, and rim brake
Quoted: 29 Post(s)
Liked 89 Times
Good luck with your Garmin 520. I've used Garmin for years including the 520. I recently switched to the Wahoo Element Bolt for ease of use, and battery life and couldn't be happier.
Non omnino gravis
I should point out that lifespan for the battery isn’t determined by age, but charge cycles. I ride 5-6 days a week, totalling around 700 hours a year. My 520 is well past the charge threshold, so battery life is only going to get worse. That said, I never got anything like 11 hours out of my 520.
My wife has an Edge 500 that was bought refurbished in 2015, and it could probably run for 20+ hours on a single charge. If you ride a typical amount, 5+ years out of a GPS unit shouldn’t be a problem.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I don't mind only getting 7ish hours out of a unit. I mean people complain about charging it every 2-3 rides or so if you ride a lot but most people have to charge the cell phone every night and don't even think twice about it.
If your a person who rides long distances and out on the trail for days on end yes, it would be super annoying. But really short of that anything I can stretch over 7 hours will do me fine if I would change my power settings. I just don't see this as a huge complaint or downfall of what we expect this little computer to do.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
spot on...this is why my old 500 was doing awesome for so long. Wasn't using it as much as I use my 520. My 500 seemed to last forever before the battery started to fail and the charging port got wanky. I don't expect that kind of life of my 520.
Erect member since 1953
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times
My 520 was used so much the battery life became annoyingly short. I bought a 520 plus partly because I wanted more memory for maps and partly fr teh battery. At the time I couldn't find instructions fo replacing the 520 battery.
That said, when I rode doubles I usually used a battery extender. I had a "Minty Boost" I soldered myself. With lithium batteries I was good forever. Later I got a small usb brick I velcroed to the stem. The Garmin will use it while running. That may be your best and cheapest option for long rides. Good luck.
I've had mine for 2+ years. I power off at stops of more than 30min, it will suck the juice in sleep mode. I also keep the backlight at 0 or 20%, which is plenty to see while night riding. I haven't done an actual test, but I haven't heard the low battery warning since taking these precautions. I charge it once a week if I'm just commuting, and make sure there's a full charge if going on a long weekend ride.
Bikes: Salsa Marrakesh, Cannondale CAAD10 5
I have been able to manage 6-8 hours if the Bluetooth connection to my phone is off. I usually sync everything to my phone now after a ride.
Quoted: 1020 Post(s)
Liked 462 Times
A software update fixed the problem.
The Crank
I get a false low battery warning on my 520-plus from time to time. At the moment it gives this alert on startup, even though the battery is at 100%. I've keep the software updated.
Even though I 'know' is a false warning, it still causes a little anxiety - 'is it really?'
Anyone else have this problem, or a fix?
full discharge even with the garmin edge 520 turned off
After charging 100% the battery will full discharge even with the garmin edge 520 turned off after a few hours.
Does anyone have any idea what the problem might be?
Rgds
Ivan
Rgds
Ivan
