50-39-30 crank set
Liked 2,974 Times
50-39-30 crank set
Does the SHIMANOFC-2403 50/39/30T have an option to come with crank guard? Looked in a few lbs abd online & only found them without the cg.
Was thinking that or the Shimano Sora FC-R3030 Crankset as a secondary option.
-Oh Hey!
-Oh Hey!
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Are you looking for a bash ring (or bash guard) to go on the outside of the big ring? I doubt the cranks you are looking at will come stock with those. You will probably need to go with an aftermarket solution.
Quoted: 3241 Post(s)
Liked 2,086 Times
Please ignore the previous reponses. Daylight savings time makes some folks grumpy.
Quoted: 453 Post(s)
Liked 104 Times
The part is on the PDF https://si.shimano.com/pdfs/ev/EV-FC-2403-3483.pdf
part #
Y1P209000 Chain Guard (Silver)
or
Y1NB12000 Chain Guard (Black)
Quoted: 18378 Post(s)
Liked 4,512 Times
BBGBashGuard usually has a good selection, but I'm not seeing a thing on their web page.
https://bbgbashguard.com/
Liked 2,974 Times
jimc101 you are correct for the part I'm looking for to come equipped with a crankset.
If I could find a triple [50-39-30] that comes with the guard already afixed, that'd be the best route. Grinding down a bigger ring still would require a spacer in between the 50T ring as to not throw back the chain when shifting out to the 50T ring. Not that I am not able to make the parts, it just adds more complexity to it all. If a crankset already exists with the guard, then that saves for the unnecessary creativity.
same thing I was running into on that site.
-Oh Hey!
-Oh Hey!
Advanced Slacker
Liked 2,537 Times
Does this link work?
https://bbgbashguard.com/shop?olsPag...t50t54t&page=2
That looks kind of sweet,
Oops, that was 110 bcd here is 130
https://bbgbashguard.com/shop?olsPag...-465054&page=1
Quoted: 453 Post(s)
Liked 104 Times
Go to an LBS and ask them if you can. you now have all the part numbers.
A bigger question would be can you actually even order it now, it's a generation old, and has been replaced by the R2000 series, with the current triple crank offered being the FC-R2030, which is of a totally different design to the FC-2403. Would suspect the FC-2403 manufacture has stopped, and all that is available is what is still in the supply chain.
Advanced Slacker
Liked 2,537 Times
Quoted: 453 Post(s)
Liked 104 Times
Liked 2,974 Times
I ordered the crank set without guard & a la carte ordered the guard with the aforementioned p/n from the pdf.
Thank you.
Considering the ES51 Octalink V2 68x121-mm bottom bracket over the "recommended" ES25.
-Oh Hey!
-Oh Hey!
Liked 2,974 Times
Ouch for the price, maybe shop around, without trying, significantly cheaper https://www.ebay.com/p/Shimano-50t-C...pan/2215409878
-Oh Hey!
-Oh Hey!
Advanced Slacker
Liked 2,537 Times
What linked to is a one month delivery time.
Advanced Slacker
Liked 2,537 Times
Liked 2,974 Times
International shipping time has amazed me in the past with some orders. Maybe it'll be the case this time around too. haha
Thanks all for the feedback.
-Oh Hey!
-Oh Hey!
Quoted: 453 Post(s)
Liked 104 Times
I gave a suggestion, which was significantly cheaper, also saying it was a very basic search (as in the potential purchases should try to search for even cheaper), the choice of where to buy will be made by a purchaser on multiple choices, price, delivery/lead time, potential additional charges to suggest a few; from your comment, I guess you always go for the most expensive option you can with same-day delivery, and good for you, again sorry for hurting your feelings, I hope you haven't melted too much.
