Which Garmin HRM strap?
Bikes: 2018 Trek Emonda SL w/Vision metron 40 wheelset, ultegra gruppa. 2010 Intense Tracer VP
Quoted: 69 Post(s)
So Garmin sells three HRM straps that are compatible with my Edge 820.
Basic unit $50 CAD
Soft strap unit $75 CAD
Dual transmission unit $100 CAD
I don't really need the dual transmission, so that leaves the first two. Are there any differences between the first two besides the soft strap? Is the soft strap better on the skin than the base model? What are people using/what are your experiences?
Matt
Basic unit $50 CAD
Matt
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
the soft strap or their premium strap its sometimes called I think is awesome. I have used both and the comfort on the soft strap is excellent! I would go for that. I think its worth the cash!
Quoted: 18883 Post(s)
Liked 10,646 Times
If the basic one is plastic, it works great and lasts many years, but it's much less comfortable than your other options. Speaking of which, Garmin makes 3 more that would work with your Edge too. Specialization in the extreme.
Quoted: 6193 Post(s)
Liked 4,809 Times
I use the Garmin premium soft strap. Some don't like them and have issues, others don't. I'm on my second strap now. The first lasted six or seven years, more than enough for me. Just rinse it off after every ride. Don't know about up there in Canada, but here in the US I was able to nab my second at Best Buy online for $50 US and pick up in store same day. My son was able to do the same last year.
Quoted: 1020 Post(s)
Liked 463 Times
It may be a case of stating the obvious, but if you are going to throw the strap in the wash, be sure to remove the sensor first.
Depending on your own perspiration patterns, you may only need to wash the strap every 4th ride or so.
One more piece od advice. You will eventually need to change the battery. Unlike other systems that use a twist-off battery cover, the Garmin system uses four, tiny retaining screws. I highly suggest buying a set of small screwdrivers to do the job and avoid damaging the screw head.
These are the ones that I use. You can get them from Amazon.
Good luck.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Agree 100%.
Good luck.
I wash my strap every 6 rides.....and I have had my strap now for 3 years. No issues.
Liked 463 Times
Just wanted add a quick note Garmin calls for a phillps #0 for the battery cover. If you go Garmin route get the right screwdriver before you try anything else...I didn't on my first sensor and never again. Everyone complains about the 4 screws but the sensor is pretty darn water tight when installed properly...its a design feature.
My set of screwdrivers are JIS standards. I am not sure if that makes a difference; the ones made by Moody have a very strong tip and a great grip.
Liked 10,646 Times
Sometimes I just get right in the shower still wearing mine. Instead of having to wash it separately.
I've given up on Garmin straps as I've lost count how many have stopped working between myself and my wife.
We are now using the Wahoo Tickr strap. Lasts longer - about 3 years of regular use and the bluetooth lets it connect directly to our Direto without the need of an ANT dongle thingy
CanadianBiker32
0
11-26-13 06:32 PM
tafkam
3
11-01-10 03:18 PM
