Chain Slipping - only mid crank ring
Hi
Ok so I reviewed past posts on chain slipping as I have it. Happens starting under medium stress and then increases with stress. I have played with this and it only happens with the mid ring (of a triple) I have been using the high and low ring to get around - but this is getting annoying
So likely mid ring replacement? This is a vintage Nishiki Colorado mountain bike with the oval track / biopace like crank. Will it be hard to find a replacement ring? - Presuming this is the issue
Thanks
Thanks
Mid chain ring needs replacing , replace the chain at the same time...
Biopace?
Good luck , thirty years has passed, since they were discontinued , Try eBay..
Bummer - but thanks for the confirmation.
Would it be possible to replace the entire crank with just a regular crank? I have a good co-op which allows me to do work and have access to used parts for a good price ...? Or could I just replace the mid one with a round one ?
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
I have had this same issue with a bio pace crank before on another bike - and after replacing the frt derailer, playing with the rear derailer , spending time and money - it never did get fixed. Finally it was stolen - good luck to them
Is this something that the biopace cranks do, something to do with me (I tend to prefer the constant pace/spin philosophy) - or just the facct that I pick old used bikes?
Old fart
Liked 3,400 Times
It's probably just that they're old bikes. A BioPace outer ring needs a little more care in setting up the front derailleur clearance, but replacing the BioPace middle ring with a round ring of the same tooth count shouldn't affect anything.
Thanks for all the info !
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Actually, there are quite a few BioPace rings for sale on Ebay at the moment. But you might as well go ahead and replace the entire crankset.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
If OP has a bike co-op nearby, they likely have dozens of cast off Biopace rings laying around, as the rings are frequently replaced with round ones. I know I have several I don't use.
Good to know - I was planning on digging through their piles tomorrow so we will see what we can find
Why dont people like the biopace rings? personal preference?
Great info all! Thanks
