Titanium Swift frame, anyone interested?
Old 06-28-14, 09:35 PM
  #76
jur
Quoted: 321 Post(s)
Liked 7 Times in 6 Posts
Originally Posted by maunakea
jur, sign me up for the next batch of Ti Swifts. Alfine 11 IGH with mechanical disc brakes. Hydraulic disc brakes have more stopping power and about 1000x more maintenance problems.
In addition to the longer maintube, did you opt for the 12" handlepost?
Ah, I thought I saw a post from you about this but couldn't find it again.
For this bike which is aimed at replacing my Swift, I had an integrated stem plus riser made:
I also asked for a bullhorn:
That will be used with shims.
jur is offline
Old 06-28-14, 11:47 PM
  #77
smallwheeler
smallwheeler's Avatar
Quoted: 151 Post(s)
Liked 10 Times in 8 Posts
current envy level - 9.6/10
smallwheeler is offline
Old 06-29-14, 12:34 PM
  #78
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
I will have to assess the ride quality, and based on that, might start a second version.
I already have some ideas for improvement. Disc brake mounts might be one of them, so wheel size is an easy choice.
In addition to brake reach.. Id suggest S bending the chainstay tubes for more tire clearance
for say a a 406 big apple Type tire clearance ..5~6cm
though then there starts to be big chain ring tooth clearances to be pressed into the outside of that DS tube.
fietsbob is offline
Old 07-01-14, 05:22 AM
  #79
jur
Quoted: 321 Post(s)
Snake stays are one of the enhancements in mind. In fact I tried to change the stays after building started but they were to far advanced to do it.
jur is offline
Old 07-02-14, 12:53 PM
  #80
itsmoot
in cog neato
itsmoot's Avatar
Been away for awhile and just now saw this thread. Man oh man is that frame beautiful. Great job there Jur.
I had a problem with my Xootr frame with the chain hitting the seatstay in lowest gear. Admittedly the setup it happens with has a wide q-factor, i.e. 135mm Deore hubs, front derailleur, bottom bracket with outboard bearings. So curved stays would be nice, as well as those extra cable guides for the front der.
I was thinking a bracket for a braze-on front der would be great, but then I thought about the folks running 60+tooth big rings....guess Xootr's clamp-on monstrosity is still neccessary for a front der setup. But wait, is that a boss for a cable pulley I see on the back of the seat tube? Does that mean theres a ti derailleur clamp in the works too?
itsmoot is offline
Old 07-02-14, 06:22 PM
  #81
jur
Quoted: 321 Post(s)
I was unwilling to commit to a front derailer braze-on because of the problems with huge chainrings, but also that the Xootr bracket is for a much wider seat tube so that wouldn't work either except shimming it - fugly.
So I thought that since the seat tube is a standard diameter at 34.9mm, standard clamps can be used. Still not nice though. My Moulton has a braze-on and I use that with a FD and 60T, plus a small spacer to get it set slightly backwards. So it works, hence a braze-on might be included next round. For now, I will hunt around for a suitable clamp bracket. There are some sleek carbon ones, but Ti would be much nicer. So far I am doing Ti everything. Almost.
[edit] Ah yes that is a pulley boss. So bottom pull can be done that way, plus there is an angled cable stop that might work for top-pull.
jur is offline
Old 07-03-14, 11:35 AM
  #82
fietsbob
Bikes: 8
Given the BB is in line with the seat tube the regular band on to Braze on FD bracket works fine, I'd expect ..
The bikes where the seat post passes behind the BB as the seat post is telescoped down ,
present different issues..
Then the FD has to be behind the seat tube , since the crank axis is behind the seat tube .
brackets are made to clamp on the tube , then..
fietsbob is offline
Old 07-06-14, 09:38 AM
  #83
LittlePixel
Raleigh20 PugFixie, Merc
LittlePixel's Avatar
Bikes: 1982 Raleigh Twenty Hotrod Fixie; 1984 Peugeot Premier Fixie, 2007 Merc Lightweight folder
Liked 4 Times in 4 Posts
Just seen this Jur - what amazing 'never need another bike again' project. [envy]
LittlePixel is offline
Old 07-06-14, 05:42 PM
  #84
jur
Quoted: 321 Post(s)
Hey LP, I actually meant to tap your store of experience regarding slim mudguards. Its winter here, so mudguards are an essential item to avoid getting splattered. I want to make this Ti Swift my everyday bike, so for that, will need mudguards.
However, it deserves some slimline mudguards that hug the tyres.
Any advice?
jur is offline
Old 07-06-14, 06:21 PM
  #85
LittlePixel
Ok so I made some slim mudguards for my Mercton last summer; Recipe went something like this:
1) Buy some black PVC pipe - mine was about 2mm thick and maybe 2" round - sink tubing basically.
2) Cut it to a length that will fit diagonally into a domestic oven, and then in half along the length so you have two trough-like mudguard blanks
3) Heat up the oven to something low. I can't remember the temp but it was definitely lower than combustable temperature - something like UK gas mark 2 I think.
4) Put one of the blanks in. I put it on something flat and metallic so it didn't start to fall through the bars
5) When it seemed fully pliable (mine basically went flat and then started to curl up after maybe 10 mins) I pulled it out with some pretty sturdy gardening gloves and stretched it over a de-biked wheel with it's tyre fully inflated. My tyre was slick, but if it's grippy you might want to cover it with foil or something before using it as a forming jig.
6) Smooth the floppy bendy hot plastic over the tyre and keep it stretched with one glove at either end
7) Hold it in place until it's cooled. This is boring and easy to half-as$ but it will go out of shape if you give up too early. 10 mins should be fine - put on some music first
8) You now have your first mudguard blank. Mine was way too snug at the sides, so I put painters tape on it then put both it and the wheel in a truing device. Using a pen it was easy to rotate the wheel, find the centre, and then mark a good place on both sides to trim the guard to the required width, which I then did away from the truing device with a Dremel / Superfine glass paper.
9) Fit to your bike with hardware stolen from other mudguards, or if you're a particular glutton for punishment, with parts you designed in Sketchup and got 3d printed.
Old 07-06-14, 06:28 PM
  #86
LittlePixel
Oh and PS - my new ride-to-work-along-the-canal-or-chuck-it-on-the-train bike - bargain echobay TSR27.
In battleship grey.
Old 07-06-14, 06:44 PM
  #87
BruceMetras
Quoted: 113 Post(s)
Liked 8 Times in 6 Posts
LittlePixel!!! you absolutely win!!! and really nice Moulton beater bike you have there for the canal paths!
BruceMetras is offline
Old 07-07-14, 01:10 AM
  #88
jur
Quoted: 321 Post(s)
Wow, with one post you shot back to number one on the list! Thanks a mill! I have been pondering PVC tubing but not fleshed out any details. Now I won't have to - handed to me on a plate in bite-sized pieces.
jur is offline
Old 07-07-14, 06:20 AM
  #89
dezzie
Bikes: Xootr swift, Moulton Speed, Moulton Major.
Quoted: 18 Post(s)
Liked 11 Times in 10 Posts
sorry to go off topic but littlepixel this is for you - I have been looking at your link for Raleigh twentys etc, I work in Newcastle upon tyne for a charity that recycle bikes, recyke-y-bike.org and we send bikes to Africa from public donations, we fix them up and send them over but also we sell decent bikes to the public and we get many old bikes in, currently we have a few twentys, stowaways and a nice dawes kingpin in there, most of them shoved in the piles with the rest but lots of nice examples that need tlc to get them back to great condition, currently there an afterthought but I love the 20 inch wheel bikes in general so feel that someone into these types of bikes should know whats there if I get the chance tomorrow I will get some pics as I volunteer there one day a week to do rebuilds and scrapping.
dezzie is offline
Old 07-07-14, 06:35 PM
  #90
LittlePixel
@dezzie - sounds interesting- they're selling for quite a lot again (mainly to shoreditch media types) down here in london - maybe they need a quick fix up and a train to Kings Cross via ebay?
I can't warrant one for myself I'm afraid - I have two already and a third frame awaiting its fate already in the tiny shed of doom
@jur - glad I could help. My 9 point version didn't quite include the one or two failures as I figured out the process but pipe is super cheap and I bet you'll get there. If you have lots of 406 tyres about it might be good to use a bigger one as a former than the one you want to use as you'll get more usable clearance without having to tension it to be a bit bigger using the stays.
@BruceMetras - You're too kind. I just couldn't spring for Moulton guards in case they didn't work so I basically had to go bespoke. I should probably go into business since Brompton refuse to do anything other than their wide silver ones which just don't look modern or sporty. (a definite mark down if you're a city boy who's just sprung for a Ti raw lacquer S model.
Old 07-08-14, 11:13 AM
  #91
kraftwerk
my nice bike is at home
kraftwerk's Avatar
Bikes: 2011 BMC Race Machine / 2012 BMC Road Machine / Trek 2300 / '90's Merlin/ '70's Raleigh 20/ Ti-'swift' folder / Erickson w/S&S couplers
Quoted: 66 Post(s)
Liked 34 Times in 24 Posts
Originally Posted by bikemig
I've been fence sitting on whether to buy a bike friday new world tourist for some time. Reading this post helped convince me that this would be a good company to buy a bike from.
Yeah, I wonder what kind of folder Thasiet ended up buying? His reasons for NOT buying a bikefriday are a bit absurd. If you don't support buying American what are the options really, something built by someone overseas who can't afford to even own a bike?
Now: back on topic.
kraftwerk is offline
Old 07-08-14, 11:16 AM
  #92
kraftwerk
kraftwerk's Avatar
Quoted: 66 Post(s)
First pics of the first Swift Ti:
Jur,
That thing is gorgeous ! Thanks for having the vision and where-with-all to have that made. Maybe we need a Folding Twenty version next?
Old 07-22-14, 08:09 AM
  #93
jur
Quoted: 321 Post(s)
Right. I got the Ti Swift in my grubby hands.
Some quick mass measurements,
Rear triangle: 0.9kg
Main frame: 1.0kg
That makes it a tad lighter than the early aluminium frame, and about 0.7kg lighter than the current aluminium frame. That is with the over-designed main frame. I am impressed.
jur is offline
Old 07-24-14, 08:30 AM
  #94
jastle
Any comments on how circular head tube is, BB easy to thread (not distorted), otherwise frame alignment? Seems like might have been a little different for them to get this on a normal jig that they'd have used for such given its sizing.
What fork are you planning to use with this? Trusting the one off fab for the frame is one thing, the fork is a little different.
Nice work.
Main frame: 1.0kg
jastle is offline
Old 07-24-14, 01:59 PM
  #95
jur
Quoted: 321 Post(s)
Nice work.
Headset went in without a hitch, as did the bottom bracket. I designed the frame around one of their standard forks, only 12mm shorter than the stock Xootr fork.
Frame alignment, well I am working on that.
Pics soon. Wheels aren't here yet. Neither are brakes and cables.
jur is offline
Old 07-24-14, 09:15 PM
  #96
tds101
55+ Club,...
tds101's Avatar
Bikes: 9+,...
Quoted: 1112 Post(s)
Liked 847 Times in 591 Posts
Oh man,... I can't wait to see your pics!
tds101 is offline
Old 07-24-14, 11:56 PM
  #97
jur
Quoted: 321 Post(s)
My new walking frame.
File Type: jpg
jur is offline
Old 07-25-14, 06:37 AM
  #98
tds101
55+ Club,...
tds101's Avatar
Bikes: 9+,...
Heh,...
tds101 is offline
Old 08-01-14, 01:20 AM
  #99
kevinjg
I feel like I am being toyed with...more please, and thank you!
kevinjg is offline
Old 08-01-14, 01:18 PM
  #100
idc
Bikes: quite a few
Love it.
idc is offline
