Estate Sale Bag-O-Bike-Tools Any Guesses??
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
Grab bag of vintage bike tools from an estate sale. Haven’t opened it yet, but I thought it might be a fun guessing game. What’s in there?!?!
p.s. I bought this up the street from where I found my ‘71 International for $25. It’s some sort of vintage vortex.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
I spy a seat wrench, universal bicycle wrench, a few socket wrenches (can't make out the sizes) a T wrench and a 15mm wrench.
Can't make out the rest bags a bit greasy....but still a nice fun bag of stuff
Ben
P.S. What street do you live on...I'm up for a CV vortex.
Ben
Quoted: 18376 Post(s)
Liked 4,511 Times
There's a spoke wrench in the middle under that T-wrench.
I'm curious about the "T" connected to a screw. Cotter extractor? We need better photos. Left threads?
I think those multi-wrenches used to be popular for compact do-everything tools, but have fallen out of favor, especially as bikes have moved more towards Allen wrenches than hex bolts/nuts.
Quoted: 3810 Post(s)
Liked 6,699 Times
That stamped steel multi-tool spanner above the spoke wrench, 2nd column. from the left, is for Raleigh-specific, i.e., Whitworth, nuts and bolts.
Liked 6,699 Times
You can try--though I find those open-ended fittings have a tendency to slip!
mycocyclist
Quoted: 910 Post(s)
Liked 816 Times
Everything Old Is New Again
One row down, second in from the left. At first I thought it was a bladed jockey wheel replacement from the all bicycle reboot of the chariot scene from Ben Hur.
Do I win a Stronglight 23.35 crank puller/dust cap and bolt remover? (I could really use a Stronglight crank puller.)
framebuilder
The Park tool at the middle top is their copy of a Campy tool designed for adjusting the bolts on classic Campy seat posts after or while the seat is being attached. The open end is for the nut on the front of Brooks saddles. The Campy T tool has 6mm hexs and a 10 mm socket. Just above it is the Campy crank puller. Usually it is paired with a "peanut butter" 15mm box wrench that fits both crank bolts as well as the crank puller. One of the others is probably for TA cranks.
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Aha, stronglight crank puller, I was wondering about that little thing.
I wouldn’t even have bought the bag ($8) if I hadn’t spotted Brev. Camp. on the T wrench. I figured there had to be cool stuff in there!
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Top left, stamped open ended wrench is from a dremel tool.
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Yeah, definitely some crap in there!
I wonder if these two have met before?
Thanks nlerner , I never would have figured that out!
Quoted: 3464 Post(s)
Liked 2,829 Times
The Park tool at the middle top is their copy of a Campy tool designed for adjusting the bolts on classic Campy seat posts after or while the seat is being attached. The open end is for the nut on the front of Brooks saddles. The Campy T tool has 6mm hex and a 10 mm socket. Just above it is the Campy crank puller. Usually it is paired with a "peanut butter" 15mm box wrench that fits both crank bolts as well as the crank puller. One of the others is probably for TA cranks.
The Campagnolo "T" wrench is a classic. There needs to be a 9mm version for Mafac brakes. Writing of which, there is a Japanese tool for holding the business end of Mafac brake pad holders secure while adjusting the position nut. Nice, but not $55. nice.
Will see if I can create my own. An excellent idea.
I think the French puller is Stronglight, note the secondary socket for that to use with a tommybar.
The stamped "multi-tool" wrenches are not useless, but not what I would buy.
Sugino, Stronglight, Campagnolo crank pullers. the mechanic worked on various bikes. This is kind of the tool kit I would expect to see additional tools to go with and this fellow may have been the local Bikeman.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Besides the obvious cone wrenches and such, there are a few interesting tools:
Quoted: 1829 Post(s)
Liked 3,376 Times
the little wrench/screwdriver in the lower right corner looks an awful lot like the tool that came in an old Erector set! If the wrench is 1/4", then that's probably what it is.
The Stronglight crank extractor might be the neatest thing in the bag, imho.
The Sugino extractor might be 2nd best... I still use mine much more than my Park extractor.
Steve in Peoria
Steve in Peoria
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
“The Sugino extractor might be 2nd best... I still use mine much more than my Park extractor.”
Here’s the one I found today, above the one I bought in 1986. Old one is a little longer and says Japan. Mine is mushroomed and doesn’t say Japan. When I was 16, I pulled my Sugino crank so often that I wore out the taper and had to replace it. I liked it clean, I guess.
Quoted: 3811 Post(s)
Liked 3,339 Times
does anyone recognize the two curved items with the bluish paint in the lower left corner?
am thinking that if they really are bicycle related they might be part of a HOZAN tool...
wylde speculation
wylde speculation
Quoted: 1303 Post(s)
Liked 1,911 Times
The clamp on weight second row 1st item looks like the weight for an original Brunswick golf shaft frequency meter. The racheted end tyre lever next to it seems to have some pretty decent chrome left on it. Smiles, MH
Liked 1,911 Times
The two blue blocks may be the opposing sides of a wheel rim clamp for straightening curb dents in steel rims. MH
Liked 4,511 Times
Those spoke wrenches can work well.
I like it, two of the multi-tools even have tire levers.
It looks like you've come up with a couple of useful bits, and a lot of stuff to fill up the Junk Drawer.
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Yes, I had a feeling that round chrome thing is not a bike tool, so a golf club weight makes sense. The ratcheted thing, I think, is one arm off a waiters corkscrew. The estate sale folks had thrown all this stuff in a bag and taped it shut, so it’s kinda funny to see what qualifies as a bike tool.
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
That would make sense! I feel like I’ve seen clamps like this before, so I’ll keep an eye out for the rest of the parts. Not like I want anything to do with steel rims, but still.
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
There are two multi tools marked F&S, which I just looked up as Fichtel & Sachs. German. I wonder what that little lockring tooth is for?
And I guess the Mafac wrenches are pretty common?
I used to have one of those Campagnolo crank extractors (black, 3rd column from left).
It broke in use one day, while pulling a crank. As I screwed the bolt inwards, the body just peeled apart into two pieces, separating where the large outer threads taper down to meet the smaller diameter shank. It broke right where you might think, despite the large, tapered radius where the two meet.
I still have the Campagnolo "peanut butter" wrench that was its mate but the extractor is gone.
I was amazed.
P.S. - Is there a reason you have it labeled as "Maxy-type" instead of Campagnolo?
I was amazed.
