Brake bridge sleeve
Brake bridge sleeve
Old 01-05-20, 03:51 PM
Ol Danl
Bikes: 1977 Raleigh Record, 1987 Schwinn Prelude, 1971 Raleigh Record, 1988 Schwinn Traveller, 1967 (?) Carlton Super Course, 1959 Huffy Sportsman 3 speed, 1972 Raleigh Super Course
Quoted: 35 Post(s)
Brake bridge sleeve
I'm trying to re-animate a Raleigh Super Course frame I bought. Tried mounting the rear brake caliper, and the bolt wouldn't go through the hole in the bridge. Then I saw that the tube, or ferrule, or whatever, through the bridge is not brazed to the bridge, but loose. And the end near the seat tube is crimped. Is the looseness of this tube an acceptable thing? I've got several other bikes -- 3 are Raleighs and one is Carlton-made, and I don't recall ever seeing the tube through the brake bridge not brazed solid. Is it going to work like this -- will the rear brake be jittery?
Ol Danl is offline
Old 01-05-20, 04:06 PM
3speedslow
3speedslow's Avatar
Bikes: A few
Quoted: 1402 Post(s)
Liked 185 Times in 142 Posts
Pics please. Off hand, I would say that will not be a stable area to clamp your rear brake to.
3speedslow is offline
Old 01-05-20, 04:31 PM
Ol Danl
Quoted: 35 Post(s)
Pictures from both sides of the bridge. The tube just moves a little bit. Is the clamping to the bridge itself enough to make the caliper's mount solid?
Ol Danl is offline
Old 01-05-20, 04:36 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 972 Post(s)
Liked 316 Times in 230 Posts
I'd throw some of these on if the bolt is long enough
https://www.amazon.com/Dia-Compe-Con.../dp/B000AOA5OM
dedhed is offline
Old 01-05-20, 04:51 PM
Ol Danl
Quoted: 35 Post(s)
The rear brake has concave washers -- so I guess the clamping to the bridge itself is enough, then? The motion in the through tube won't be an issue?
Ol Danl is offline
Old 01-05-20, 05:00 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1980 Post(s)
Liked 325 Times in 234 Posts
Yeah, it's fine. Just make sure the mounting bolt is tight to hold it in place.
JohnDThompson is offline
Likes For JohnDThompson:
Old 01-05-20, 05:15 PM
Ol Danl
Quoted: 35 Post(s)
Thanks. The more I look at it, I believe it'll be okay as is. Just never seen one loose like that before. Have to round out that back side to get the brake bolt through.
Ol Danl is offline
Old 01-05-20, 05:52 PM
unterhausen
Randomhead
Liked 205 Times in 163 Posts
you can see evidence of concave washers in the paint. When that bike was made, that's how brakes were held on. Most bikes didn't have a sleeve in the hole.
unterhausen is offline
Likes For unterhausen:
Old 01-05-20, 05:53 PM
jackbombay
Quoted: 285 Post(s)
Liked 187 Times in 141 Posts
I currently have 2 of these Super Course frames in my garage that are identical to your, same color even, and I too noticed the back side of the sleeve through the brake bridge is a fuzz smaller than the bolt, I put a smaller drill bit through it and spun it with a drill while moving the drill in a circular motion and the brake bolt drops right through now.
jackbombay is offline
Old 01-05-20, 06:04 PM
Classtime
Classtime's Avatar
Bikes: 81 Medici, 84 Turbo, 86 IM, 2010 Milwaukee Road, 2011 RS
Quoted: 717 Post(s)
Liked 117 Times in 88 Posts
My recently acquired Competition G. S. Had the same issue. I filed the crimped end nearest the seat tube so that a curved washer could cinch up against the bridge and my brakes are tight now.
Classtime is offline
Old 01-05-20, 06:17 PM
repechage
Quoted: 1243 Post(s)
Liked 255 Times in 202 Posts
Raliegh production value engineering at it's finest, or at least hidden well enough.
repechage is offline
Old 01-05-20, 06:34 PM
3speedslow
3speedslow's Avatar
Bikes: A few
I see the problem now. No problem with the brake being loose when tightened. Concur with the shaped washer +10
Old 01-05-20, 08:15 PM
Ol Danl
Quoted: 35 Post(s)
Thanks for all your wisdom and responses, folks.
Ol Danl is offline
