Brake Noodle Quality Comparison - What's good?
You mean the piece of plastic on v-brakes? The only function I've seen them serve is to stop gunk from getting on the cable into the housing since it is where the dirt gets kicked up. Anything will do there.
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
Not sure there is any great variation in quality; they all seem to be just a metal tube with a plastic liner.
Quoted: 2026 Post(s)
Liked 1,095 Times
I wasn't sure what the OP was describing. Why would anyone buy those lined metal noodles in a pack of 10? The $6 each seemed more reasonable for them. The 10 for $10 probably are just thin plastic liner pieces.
Quoted: 567 Post(s)
Liked 563 Times
I have used Shimano and Jagwire and IIRC they are only a few bucks. Eventually the plastic liner fails and they needed replacement and I would doubt any major component manufacturer has a significantly better liner material. Useful life by a major brand is probably determined by cable smoothness and cleanliness rather than liner material.
Likes For bpcyclist:
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 211 Post(s)
Liked 43 Times
One difference is some noodles have an integral adjusting barrel, and others don't. Those with the barrel will be more expensive (I assume). So if you don't have an adjusting barrel elsewhere in your housing run, then you might want to get a noodle with the integral adjusting barrel.
SE Wis
Quoted: 2742 Post(s)
Liked 3,389 Times
I don't know that there is a major difference in quality. Most of the braqnd name ones are stainless. There are differences in degree of bend, adjusters, color etc.
Quoted: 1438 Post(s)
Liked 1,092 Times
Likes For dsbrantjr:
And the plastic thingy keeps the dirt out of that... I guess I'm not up on the terminology, by the time I got my first bike with v-brakes they'd moved on to disc.
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times
Just make sure to not get noodles with modulator springs in them (usually intended for the front brake of entry level bikes intended for novice riders) if you don't want them. I don't commonly see these in the aftermarket, but I imagine they are out there.
Likes For hokiefyd:
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Sounded reasonable but found this ebay advert for flexible brake noodles. This is apparently the Chinese marketing approach: offer un-needed quantities (say 10) of an item that they could only sell for a buck each each and maximize revenue to $8.89.
https://www.amazon.com/Yuauy-Flexibl...SIN=B078HRK55F
Quoted: 576 Post(s)
Liked 1,001 Times
Likes For DorkDisk:
Liked 759 Times
Yeah, those flexible ones intrigue me. I've never used them before, but I guess they must work well.
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
Liked 759 Times
The "power modulators" are actually the genesis of me buying a 10-pack of the Jagwire noodles. At the time, I had two Trek hybrids with linear pull brakes, both with modulators on the front. One of the bikes was two years old and the other one was about 12 years old. So I just refreshed all the brake cables and noodles at once. Rather than buying four individual noodles, I figure I'd be able to use the other six eventually, so I bought the pack of 10. I think I have two left.
The modulators, in theory, prevent a front wheel lock-up. And I guess they did, but I'm a pretty heavy guy (240 pounds) and I'm not in the habit of even trying to lock my wheel (out of respect for my cycling equipment!). I don't know if I could have done it with the modulators or not, but they definitely added "squish" to the front brake.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,204 Times
$6 for a noodle is a bit steep. They go for about $2 each. There are some ones from Avid that are a little bit better in the locking mechanism but they are still only about $5. $10 for 10 of them is about right.
Stuart Black
Stuart Black
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
I do a lot of charity repairs and never know how long these bikes will be around (stolen, sold, etc.). Yes I buy multiple bags of 10 or 20 at a time, The quality is what it is and they seem to function fine and help restore a bike to usefulness. We probably go through about 100 per year easily. That's why!
Liked 927 Times
Cheers
