Bent rear derailleur
Old 01-16-20, 01:28 PM
pe6600
Hello,
My rear derailleur got bent and my chain snapped but have no clue how to replace them and derailleurs seem quite expensive, so my question is could i put a new chain on without having it go through the rear derailleur? My bike has 3 gears in the front and 8 in the back so if i like just pick some middle-ish gears and just put a chain around them and just never switch gears could that potentialy work? Im sorry if thats a stupid idea and a stupid question but i just thought it may work. Thanks for any suggestions in advance <3
pe6600 is offline
Old 01-16-20, 01:42 PM
sour01
Rid'n Rev
sour01's Avatar
Bikes: 2007 Felt F55, Vintage Univega, 2012 Specialized Mountain Bike
Quoted: 12 Post(s)
Liked 13 Times in 4 Posts
Is the RD bent or just the hanger or the dropout? Hangers aren’t expensive. Don’t know what kind of bike you have but dropouts can be realigned on steel bikes. I’d take it to your local bike shop to get their ideas on options. I’m not so sure about your remedy.
sour01 is offline
Old 01-16-20, 01:48 PM
jbucky1
jbucky1's Avatar
Bikes: Moots Routt
Quoted: 94 Post(s)
Liked 22 Times in 20 Posts
In theory yes you could just wrap a chain around. In practice it often doesn't work that good - I have seen a lot of hobo bikes like this in the place I work.
If you have horizontal dropouts in the rear it can work but I highly doubt you do.
If you really wanted to go the single gear route toy would need something to tension the chain also. Kinda like what is in here:
https://www.amazon.com/Forte-Lightin...=fsclp_pl_dp_3
jbucky1 is offline
Old 01-16-20, 01:50 PM
jbucky1
jbucky1's Avatar
Bikes: Moots Routt
Quoted: 94 Post(s)
Assuming the frame is not bent. Best thing to do would be
1) buy a new derailleur hanger
2) if the rear derailleur mechanism is bent / trash then buy a new derailleur
3) buy a new chain
jbucky1 is offline
Old 01-16-20, 01:57 PM
pe6600
Oh wow, thank you for the quick responses. I guess i will be a normal human being and just fix it properly.
pe6600 is offline
Old 01-16-20, 02:09 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,393 Times in 1,927 Posts
In principle, it would work, but only with a single gear. In order to use multiple gears, you need the derailleur to move the chain to the new gear and accommodate any change in chain length by wrapping more or less chain.
So, pick a gear that suits your riding, trim the chain to the length needed, and ride.
N.B. this is easiest if your frame has horizontal dropouts that allow you to move the rear wheel forward or back to provide the appropriate chain tension. If your frame has vertical dropouts, you'll have to settle for a "magic gear" combination that provides a usable chain tension and replace parts as they wear, or install a chain tensioner to control the chain. But if you do that, you may as well just buy a new derailleur and get the benefit of multiple gears.
JohnDThompson is online now
Old 01-16-20, 02:56 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1786 Post(s)
Liked 1,259 Times in 868 Posts
If a RDER seems "that" expensive, you have a very low cost bike.
WHAT RDER is on it? A Shimano ALTUS?
https://www.amazon.com/SHIMANO-RD-M3...284660529&th=1
Bill Kapaun is offline
Old 01-16-20, 05:55 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2738 Post(s)
Liked 3,379 Times in 2,044 Posts
Do you have a bicycle co-op in your city/area?
Cheap used parts and the help to install it.
Something like this. Vulture Space
dedhed is offline
Likes For dedhed:
Old 01-17-20, 04:59 AM
tomtomtom123
Quoted: 350 Post(s)
Liked 122 Times in 90 Posts
Hangers can be as low as $3. Rear derailleur can be as low as $10.
tomtomtom123 is offline
